Доброе утро, сменил VPN сервер, не режутся скоростя.
accel-ppp.conf
[modules]
log_file
pptp
pppoe
auth_mschap_v2
auth_mschap_v1
auth_chap_md5
auth_pap
radius
ippool
sigchld
shaper_tbf
[tbf]
attr-down=PPPD-Downstream-Speed-Limit
attr-up=PPPD-Upstream-Speed-Limit
[radius]
dictionary=/usr/local/share/accel-ppp/radius/dictionary
nas-identifier=VPN
nas-ip-address=192.168.0.1
gw-ip-address=172.16.0.1
auth-server=192.168.0.2:1812,rfhnjyrf
acct-server=192.168.0.2:1813,rfhnjyrf
dae-server=192.168.0.1:3799,rfhnjyrf
dm_coa_secret=rfhnjyrf
verbose=1
#timeout=3
#max-try=3
acct-timeout=0
захожу по 127.0.0.1 2000
accel-ppp#show sessions
ppp589 | ali88 | 00:15:6d:4b:04:47 | 172.16.2.4 | 800/800 | pppoe | | active | 00:00:21
/usr/local/share/acce-ppp/radius/dictionary
ATTRIBUTE Traffic-Shape-in 231 integer
ATTRIBUTE<----->PPPD-Downstream-Speed-Limit<--->230<--->integer
ATTRIBUTE<----->PPPD-Upstream-Speed-Limit<----->231<--->integer
/etc/ppp/ip-up
if [ -f /var/run/radattr.$1 ]
then
DOWNSPEED=`/usr/bin/awk '/PPPD-Downstream-Speed-Limit/ {print $2}' /var/run/radattr.$1`
UPSPEED=`/usr/bin/awk '/PPPD-Upstream-Speed-Limit/ {print $2}' /var/run/radattr.$1`
FILTERS=`/usr/bin/awk '/Filter-Id/ {print $2}' /var/run/radattr.$1`
#echo $DOWNSPEED
#echo $UPSPEED
#echo $FILTERS
/usr/sbin/tc qdisc del dev $1 root > /dev/null
/usr/sbin/tc qdisc del dev $1 ingress > /dev/null
##### speed server->client
if [ "$UPSPEED" != "0" ] ;
then
/usr/sbin/tc qdisc add dev $1 root handle 1: htb default 20 r2q 1
/usr/sbin/tc class add dev $1 parent 1: classid 1:1 htb rate ${UPSPEED}kbit burst 4k
/usr/sbin/tc class add dev $1 parent 1:1 classid 1:10 htb rate ${UPSPEED}kbit burst 4k prio 1
/usr/sbin/tc class add dev $1 parent 1:1 classid 1:20 htb rate ${UPSPEED}kbit burst 4k prio 2
/usr/sbin/tc qdisc add dev $1 parent 1:10 handle 10: sfq perturb 10 quantum 1500
/usr/sbin/tc qdisc add dev $1 parent 1:20 handle 20: sfq perturb 10 quantum 1500
/usr/sbin/tc filter add dev $1 parent 1:0 protocol ip prio 10 u32 match ip tos 0x10 0xff flowid 1:10
/usr/sbin/tc filter add dev $1 parent 1:0 protocol ip prio 10 u32 match ip protocol 1 0xff flowid 1:10
/usr/sbin/tc filter add dev $1 parent 1: protocol ip prio 10 u32 match ip protocol 6 0xff match u8 0x05 0x0f at 0 match u16 0x0000 0xffc0 at 2 match u8 0x10 0xff at 33 flowid 1:10
fi
##### speed client->server
if [ "$DOWNSPEED" != "0" ] ;
then
/usr/sbin/tc qdisc add dev $1 handle ffff: ingress
/usr/sbin/tc filter add dev $1 parent ffff: protocol ip prio 50 u32 match ip src 0.0.0.0/0 police rate ${DOWNSPEED}kbit burst 12k drop flowid :1
fi
accel-ppp# show stat
uptime: 0.00:14:52
cpu: 5%
mem(rss/virt): 34660/4341020 kB
core:
mempool_allocated: 19243427
mempool_available: 292888
thread_count: 23
thread_active: 1
context_count: 753
context_sleeping: 0
context_pending: 0
md_handler_count: 2219
md_handler_pending: 0
timer_count: 1462
timer_pending: 0
ppp:
starting: 7
active: 727
finishing: 1
pptp:
starting: 0
active: 5
pppoe:
active: 730
delayed PADO: 0
recv PADI: 8377
drop PADI: 0
sent PADO: 8377
recv PADR(dup): 8375(7)
sent PADS: 8369
radius(1, 192.168.0.2):
request count: 0
queue length: 0
auth sent: 8372
auth lost(total/5m/1m): 0/0/0
auth avg query time(5m/1m): 11/12 ms
acct sent: 753
acct lost(total/5m/1m): 0/0/0
acct avg query time(5m/1m): 4/1 ms
interim sent: 8594
interim lost(total/5m/1m): 0/0/0
interim avg query time(5m/1m): 8/7 ms
accel-ppp#
linux-f2js:/etc/ppp # tc class show dev ppp384
class htb 1:10 parent 1:1 leaf 10: prio 1 rate 400000bit ceil 400000bit burst 4Kb cburst 1600b
class htb 1:1 root rate 400000bit ceil 400000bit burst 4Kb cburst 1600b
class htb 1:20 parent 1:1 leaf 20: prio 2 rate 400000bit ceil 400000bit burst 4Kb cburst 1600b
И правило для логина с нужно скоростью
Edited by alishka
вы определитесь как вы хотите шейпить... внешними скриптами или внутренним шейпером...
а то у вас как-то сумбурно.....
