Принесли тут на днях sce2020 мультимодовую? но она как то странно работает, при подключении портов к другому оборудованию линк загорается только на самой sce (любой порт так себя ведёт) по настройкам она в inline.
Вроде всё делал по ману (прервоначальная настройка), но не рботает - трафик через неё не проходит. Подскажите что не так я делаю?
конфиг
no management-agent notifications notification-list 1417,1418,804,815,1404,1405,1406,1407,
1408,400
no management-agent notifications notification-list 402,421,440,441,444,445,446,450,437,45
7
no management-agent notifications notification-list 3593,3594,3595,10040,4614,4615
snmp-server community "tt" ro
interface LineCard 0
aggregative-global-controllers
aggregative-global-controller-dynamic mode suspend
aggregative-global-controller-dynamic mode active
connection-mode inline on-failure bypass
no silent
no shutdown
service-bandwidth-prioritization-mode global
no protocol-pack version
flow-filter partition name "ignore_filter" first-rule 4 num-rules 32
attack-filter subscriber-notification ports 80
replace spare-memory code bytes 6291456
interface FastEthernet 0/0
ip address 192.168.4.150 255.255.255.0
interface FastEthernet 0/1
interface GigabitEthernet 0/1
interface GigabitEthernet 0/2
interface GigabitEthernet 0/3
interface GigabitEthernet 0/4
exit
ip default-gateway 192.168.4.254
line vty 0 4
exit
interface Mng 0/1
exit
interface Mng 0/2
active-port
exit
no subscriber LEG dhcp-lease-query
subscriber LEG dhcp-lease-query servers 127.0.0.1
logger device SCE-agent-Statistics-Log max-file-size 204800
management-agent property "com.pcube.management.framework.install.activation.operation" "I
nstall"
management-agent property "com.pcube.management.framework.install.activated.package" "SCA
BB"
management-agent property "com.pcube.management.framework.install.activated.version" "4.1.
0 build 90"
management-agent property "com.pcube.management.framework.install.activation.date" "Tue Ja
n 28 09:11:59 UTC 2014"
Edited by sui245
Решение найдено ))) Не внимательно читал маны. На интерфейсах к которым подключено SCE нужно дать speed nonego. То же самое, но на интерфейсах SCE результата не даёт.
Ответ нашёл вот тут http://forum.nag.ru/forum/index.php?showtopic=85616
Edited by sui245
