Доброго времени суток.
У меня возникла проблема с настройкой плагина nrpe c сервером nagios 3v.
Суть проблемы есть сервер Debian 6.0.5 с настроенным и работающим nagios, но нужно мониторить сервер СentOS с asteriks на борту на доступ к шлюзу.
Вроде все настроено как полагается,плагин nrpe 2.13.
Hо при запуске команды для проверки на сервере с nagios /usr/local/nagios/libexec/check_nrpe -H 192.168.12.253 -p5666 -c check_ping -H 172.0.5.1
CHECK_NRPE: Socket timeout after 10 seconds.
в iptables вот такие записи:
Chain INPUT (policy ACCEPT)
target prot opt source destination
fail2ban-BadBots tcp -- anywhere anywhere multiport dports http,https
fail2ban-FTP tcp -- anywhere anywhere tcp dpt:ftp
fail2ban-PBX-GUI tcp -- anywhere anywhere
fail2ban-SIP all -- anywhere anywhere
fail2ban-SSH tcp -- anywhere anywhere tcp dpt:ssh
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain fail2ban-BadBots (1 references)
RETURN all -- anywhere anywhere
Chain fail2ban-FTP (1 references)
Chain fail2ban-PBX-GUI (1 references)
Chain fail2ban-SIP (1 references)
Chain fail2ban-SSH (1 references)
Содержание nrpe.cfg
# NRPE Config File for Opsview
# NOTES:
# It needs to be located on the remote host that is running the NRPE
# daemon, not the host from which the check_nrpe client is being executed.
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number.  The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/usr/local/nagios/var/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
# You can either supply a username or a UID.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
# You can either supply a group name or a GID.
nrpe_group=nagios
allowed_hosts=172.16.124.99
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed.  This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=0
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo.  For this to work, you need to add
# the nagios user to your /etc/sudoers.  An example entry for alllowing
# execution of the plugins from might be:
# nagios          ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password.  If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# BASIC COMMAND DEFINITIONS
# NOTE: additional command definitions should be put into a file in
# 	/usr/local/nagios/etc/local/<config>.cfg
# with checks in
# 	/usr/local/nagios/libexec/local/xxx
# All entries should be in the following form
command[check_users]=/usr/local/nagios/libexec/check_users $ARG1$
command[check_load]=/usr/local/nagios/libexec/check_load $ARG1$
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
command[check_swap]=/usr/local/nagios/libexec/check_swap $ARG1$
command[check_procs]=/usr/local/nagios/libexec/check_procs $ARG1$
command[check_memory]=/usr/local/nagios/libexec/check_memory $ARG1$
command[check_file_age]=/usr/local/nagios/libexec/check_file_age $ARG1$
command[check_mailq]=/usr/local/nagios/libexec/check_mailq $ARG1$
command[check_hpjd]=/usr/local/nagios/libexec/check_hpjd $ARG1$
command[check_ntp]=/usr/local/nagios/libexec/check_ntp $ARG1$
command[check_snmp]=/usr/local/nagios/libexec/check_snmp $ARG1$
command[check_time]=/usr/local/nagios/libexec/check_time $ARG1$
command[check_tcp]=/usr/local/nagios/libexec/check_tcp $ARG1$
command[check_ping]=/usr/local/nagios/libexec/check_ping -H $HOSTADDRESS$
# Additional configuration files for local modifications
include_dir=/usr/local/nagios/etc/nrpe_local
Содержание nrpe
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
      	flags           = REUSE
       socket_type     = stream
port		= 5666
      	wait            = no
       user            = nagios
group		= nagios
      	server          = /usr/local/nagios/bin/nrpe
       server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
      	log_on_failure  += USERID
       disable         = no
only_from       = 172.16.124.99
nrpe 		5666/tcp
Подскажите что такое может быть? Может я просто элементарной ошибки не вижу?
А в логах что?в конфиге добавьте server_address=IP_машины где nrpe сервер. 172.16.124.99- тачка с nagios?
Edited by roysbike
Вы неверно понимаете принцип работы nrpe.
В этой строке
у вас два ключа '-H'. Второй применяется к check_nrpe, а не к check_ping как вы хотите. В итоге второй перебивает первый и nagios пытается подключиться к 172.0.5.1, а не к 192.168.12.253 как вы хотите. Можете tcpdump'ом проверить.
Аргументы команды передаются на удаленный сервер с nrpe через ключ '-a', но у вас в конфиге nrpe обработка аргументов запрещена, ибо это небезопасно, о чем и говорится CapsLock'ом
dont_blame_nrpe=0
в общем я советую сделать так:
1) На сервере с nagios использовать команду
check_nrpe -H 192.168.12.253 -p5666 -c check_gateway
2) На сервере с nrpe прописать в конфиге
command[check_gateway]=/usr/local/nagios/libexec/check_ping -H 172.0.5.1
