В принципе получилось, работает. но эти relay HEX ключи вытаскивать из дебага DHCP - гемор еще тот.
напишу для потомков. Вдруг кто будет интересоваться этим функционалом в гугле.
ip dhcp smart-relay
ip dhcp relay information option
ip dhcp relay information trust-all
no ip dhcp use vrf connected
ip dhcp pool fake
network 10.0.3.0 255.255.255.0
class 3004
address range 10.0.3.4 10.0.3.4
class 3002
address range 10.0.3.2 10.0.3.2
class 3003
address range 10.0.3.3 10.0.3.3
ip dhcp class 3004
relay agent information
relay-information hex 020c020a00000a00030101000bbc0608766c616e33303034
ip dhcp class 3002
relay-information hex 020c020a00000a00030101000bba0608766c616e33303032
ip dhcp class 3003
relay-information hex 020c020a00000a00030101000bbb0608766c616e33303033
Интерфейсы:
interface Loopback1
ip address 10.0.3.1 255.255.255.0
interface FastEthernet0/0
description ISP
ip address 83.69.44.82 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description komilink
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 2601
ip address 62.183.9.230 255.255.255.252
ip nat outside
ip virtual-reassembly
no cdp enable
interface FastEthernet0/1.3002
encapsulation dot1Q 3002
ip dhcp relay information option subscriber-id vlan3002
ip unnumbered Loopback1
ip helper-address 10.0.3.1
no ip proxy-arp
ip nat inside
no cdp enable
interface FastEthernet0/1.3003
encapsulation dot1Q 3003
ip dhcp relay information option subscriber-id vlan3003
no ip proxy-arp
ip nat inside
no cdp enable
interface FastEthernet0/1.3004
encapsulation dot1Q 3004
ip dhcp relay information option subscriber-id vlan3004
no ip proxy-arp
ip nat inside
interface Loopback1
description ISP
ip address 83.69.4.82 255.255.255.252
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip address 62.182.29.230 255.255.255.252
ip nat outside
no cdp enable
no ip proxy-arp
ip nat inside
no cdp enable
no ip proxy-arp
ip nat inside
no cdp enable
no ip proxy-arp
ip nat inside
ip default-gateway 83.69.66.81
ip forward-protocol nd
ip route 10.0.3.2 255.255.255.255 FastEthernet0/1.3002
ip route 10.0.3.3 255.255.255.255 FastEthernet0/1.3003
ip route 10.0.3.4 255.255.255.255 FastEthernet0/1.3004
Строчка дебага выглядит вот так:
Feb 21 13:54:29.135: DHCPD: input pattern 'relay-information 020c020a00000a00030101000bba0608766c616e33303032' matches class 3002
Этот хекс и вставляем в нужный класс.
Edited by Fancar
  • 3 months later...
Прошу помощи...
не получается вытащить из дебага хекс.
Делаю:
terminal monitor
debug ip dhcp server class
debug ip dhcp server events
debug ip dhcp server linkage
debug ip dhcp server packet
debug ip dhcp server redundancy
Пишу все по примеру. Ни во время конфигурации, ни во время запроса адреса хекс не вижу...
  • 1 year later...
поздно заметил, но лучше поздно чем никогда, может кому пригодиться.
Для начала нужно вставить какой-нибудь несуществующий хекс, иначе если класс будет без hex, то он будет выдаваться кому попало без оглядки на vlan
ip dhcp class 317
relay-information hex 020c020a00000a0003010100013e0603333137
дальше включаем дебаг:
undebag all
debug dhcp
clear log
sh log
ищем наш АСК DHCPD: Searching for a match to 'relay-information ТУТ ХЕКС
копируем в буфер обмена и вставляем в нужный класс вместо заглушки
ip dhcp class 317
relay-information hex --> сюда <--
Дальше вытащив несколько хексов подряд без труда проследит меняющиеся разряды и продолжить без поисков в дебаге.
незабудьте
undebug all
Ж)
