Приветствую
Странное поведение SCE2020 : пропускает IP (например ping // telnet // ssh ) но в упор не пропускает SIP (стоят цискофоны). Видно что регистрация не проходит. С самого SIP сервера телефоны по IP доступны.
В пэкедже нет вообще уже ничего, кроме default rule (allow all)
В sce-bb console даже специально разрешал bypass SIP траффика в Filtered Traffic - изменений никаких :(
При включении в обход SCE начинает все отлично работать.
SCE2000#>sh version
System version: Version 3.7.5-classic Build 412
Build time: Feb 24 2012, 20:11:12 (Change-list 696843)
Software version is: Version 3.7.5-classic Build 412
Application file: /tffs0/release_.sli
Application name: Engage SML Version 3.7.5 build 31 (Protocol Pack 29 build 23)
Using Lib - PL_V3.7.5PP_B35
Using Lib - Classifier_V3.7.5_B35
SCE2000#>sh running-config
#This is a general configuration file (running-config).
#Created on 17:26:10 KRS WED February 20 2013
#cli-type 1
#version 1
enable password level 0 0 "****"
enable password level 10 0 "****"
enable password level 15 0 "*****"
clock timezone KRS 8
ip ssh
no management-agent notifications notification-list 1417,1418,804,815,1404,1405,1406,1407,1408,400
no management-agent notifications notification-list 402,421,440,441,444,445,446,450,437,457
no management-agent notifications notification-list 3593,3594,3595,10040
interface LineCard 0
no bypass-excess-traffic
aggregative-global-controllers
aggregative-global-controller-dynamic mode suspend
aggregative-global-controller network-side 0 cir 0 pir 1000000 al 5 parent -1 name ""
aggregative-global-controller network-side 1 cir 0 pir 1000000 al 5 parent -1 name ""
aggregative-global-controller subscriber-side 0 cir 0 pir 1000000 al 5 parent -1 name ""
aggregative-global-controller subscriber-side 1 cir 0 pir 1000000 al 5 parent -1 name ""
aggregative-global-controller-dynamic mode active
connection-mode inline on-failure bypass
no silent
no shutdown
protocol-pack version 3.7.5PP29
flow-filter partition name "ignore_filter" first-rule 4 num-rules 32
flow-filter partition name "udpPortsToOpenBySw" first-rule 40 num-rules 21
no attack-filter protocol TCP
no attack-filter protocol UDP
no attack-filter protocol ICMP attack-direction single-side-both
no attack-filter protocol other attack-direction single-side-both
attack-filter subscriber-notification ports 80
replace spare-memory code bytes 3145728
interface FastEthernet 0/0
ip address 10.0.99.250 255.255.255.0
interface FastEthernet 0/1
interface GigabitEthernet 0/1
interface GigabitEthernet 0/2
interface GigabitEthernet 0/3
interface GigabitEthernet 0/4
exit
ip default-gateway 10.0.99.254
line vty 0 4
exit
interface Mng 0/1
exit
interface Mng 0/2
exit
no subscriber LEG dhcp-lease-query
subscriber LEG dhcp-lease-query servers 127.0.0.1
logger device SCE-agent-Statistics-Log max-file-size 204800
management-agent property "com.pcube.management.framework.install.activation.operation" "Install"
management-agent property "com.pcube.management.framework.install.activated.package" "SCA BB"
management-agent property "com.pcube.management.framework.install.activated.version" "3.7.5 build 92"
management-agent property "com.pcube.management.framework.install.activation.date" "Wed Jan 23 12:39:23 GMT+08:00 2013"
Edited by elcambino
This topic is now closed to further replies.
