Добрый день!
Есть сервер на freebsd 8.2(x64), на нем установлен freeradius2 и mysql5.5 , к freeradius-у прикручен rlm_perl! Ниже конфиг radiusd.conf
prefix = /usr/local
exec_prefix = ${prefix}
sysconfdir = ${prefix}/etc
localstatedir = /var
sbindir = ${exec_prefix}/sbin
logdir = /var/log
raddbdir = ${sysconfdir}/raddb
radacctdir = ${logdir}/radacct
name = radiusd
confdir = ${raddbdir}
run_dir = ${localstatedir}/run/${name}
db_dir = ${raddbdir}
libdir = /usr/local/lib/freeradius-2.2.0
pidfile = ${run_dir}/${name}.pid
user = freeradius
group = freeradius
max_request_time = 30
delete_blocked_requests = no
cleanup_delay = 5
max_requests = 1024
listen {
type = auth
ipaddr = *
port = 0
listen {
ipaddr = *
port = 0
type = acct
hostname_lookups = no
allow_core_dumps = no
regular_expressions = yes
extended_expressions = yes
log {
destination = files
file = ${logdir}/radius.log
syslog_facility = daemon
stripped_names = no
auth = no
auth_badpass = no
auth_goodpass = no
checkrad = ${sbindir}/checkrad
security {
max_attributes = 200
reject_delay = 1
status_server = yes
proxy_requests = no
$INCLUDE clients.conf
thread pool {
start_servers = 5
max_servers = 32
min_spare_servers = 3
max_spare_servers = 10
max_requests_per_server = 0
modules {
perl {
module = ${confdir}/auth.pl
max_clones = 48
start_clones = 48
files {
usersfile = ${confdir}/users
compat = no
$INCLUDE sites-enabled/
Все прекрасно работало около 3-x месяцев, сегодня смотрю чё то база тормозит, и freeradius вылетел, в логи радиуса постоянно пишет следующее:
Mon Jan 21 14:56:09 2013 : Error: Request 162 has been waiting in the processing queue for 5 seconds. Check that all databases are running properly!
Mon Jan 21 14:56:27 2013 : Error: Received conflicting packet from client 10.0.1.1 port 1646 - ID: 195 due to unfinished request 146. Giving up on old request.
Mon Jan 21 14:56:29 2013 : Info: WARNING: Module rlm_perl became unblocked for request 145
Mon Jan 21 14:56:33 2013 : Info: WARNING: Child is hung for request 148 in component accounting module perl.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 354 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 307 in component accounting module perl.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 355 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 356 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 357 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 367 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 337 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 338 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 311 in component accounting module perl.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 312 in component accounting module perl.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 358 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 368 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 359 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 360 in component <core> module <queue>.
Mon Jan 21 14:57:08 2013 : Info: WARNING: Child is hung for request 369 in component <core> module <queue>
вот сам perl модуль
use DBI;
use POSIX;
use vars qw(%RAD_REQUEST %RAD_REPLY %RAD_CHECK);
use Data::Dumper;
use constant RLM_MODULE_REJECT=> 0; #
use constant RLM_MODULE_FAIL=> 1; #
use constant RLM_MODULE_OK=> 2; #
use constant RLM_MODULE_HANDLED=> 3; #
use constant RLM_MODULE_INVALID=> 4; # Code errors
use constant RLM_MODULE_USERLOCK=> 5; #
use constant RLM_MODULE_NOTFOUND=> 6; #
use constant RLM_MODULE_NOOP=> 7; #
use constant RLM_MODULE_UPDATED=> 8; #
use constant RLM_MODULE_NUMCODES=> 9; #
# DB connection
sub db_connect {
$db = "isg";
$host = "localhost";
$user = "******";
$pass = "******";
$dbh = DBI->connect("DBI:mysql:$db:$host", $user, $pass);
# Log burner
sub logger {
$log_query = $dbh->do("INSERT INTO radius(date,login,errors)
VALUES ('$_[0]','$_[1]','$_[2]')");
$dbh->disconnect();
# Authorization
sub authorize {
if ($RAD_REQUEST{'User-Name'}=="SERVICE_L4R")
return 2;
if (($RAD_REQUEST{'User-Name'}=="U100") || ($RAD_REQUEST{'User-Name'}=="W1") || ($RAD_REQUEST{'User-Name'}=="W2") || ($RAD_REQUEST{'User-Name'}=="W3") || ($RAD_REQUEST{'User-Name'}=="W5") || ($RAD_REQUEST{'User-Name'}=="W10") || ($RAD_REQUEST{'User-Name'}=="W20") || ($RAD_REQUEST{'User-Name'}=="W30") || ($RAD_REQUEST{'User-Name'}=="W50"))
return 2;
db_connect();
$auth_query = $dbh->prepare("SELECT c.login,i.mac,i.active,i.packet_id,i.packet_id_ua,i.tp_count FROM (internet i, clients c)
WHERE i.mac='$RAD_REQUEST{'Calling-Station-Id'}' AND i.client_id=c.id;");
$auth_query->execute();
$auth_row=$auth_query->fetchrow_hashref();
if ($auth_row > 0 ) {
$username = $auth_row->{'login'};
$mac = $auth_row->{'mac'};
$status = $auth_row->{'active'};
$tp_count = $auth_row->{'tp_count'};
$packet = $auth_row->{'packet_id'};
$packetua = $auth_row->{'packet_id_ua'};
$curdate = strftime "%Y%m%d-%H:%M:%S", localtime;
$auth_query->finish();
else {
#logger($curdate,$username,"MAC: $RAD_REQUEST{'Calling-Station-Id'} not found![$RAD_REQUEST{'User-Name'}]");
&radiusd::radlog(4,"MAC: $RAD_REQUEST{'Calling-Station-Id'} not found![$RAD_REQUEST{'User-Name'}]");
return 0;
if ($status ne "1") {
logger($curdate,$username,"User: $username disable!");
#&radiusd::radlog(4,"User: $username disable!");
return 0;
if ($tp_count == 1 ) {
$tg_query = $dbh->prepare("SELECT tg.speed_down,tg.speed_up FROM (packets tg, internet ig)
WHERE tg.id='$packet';");
$tg_query->execute();
$tg_row=$tg_query->fetchrow_hashref();
$speed_in = $tg_row->{'speed_up'};
$speed_out = $tg_row->{'speed_down'};
$tg_query->finish();
$RAD_REPLY{'Cisco-Service-Info'} = "QU;".($speed_in *1000).";".((($speed_in *1000)*1.5)/8).";".((($speed_in *1000)*3)/8).";"."D;".($speed_out *1000).";".((($speed_out *1000)*1.5)/8).";".((($speed_out *1000)*3)/8);
if ($tp_count == 2 ) {
$tu_query = $dbh->prepare("SELECT speed_world, speed_ua FROM packets_ua WHERE id='$packetua';");
$tu_query->execute();
$tu_row=$tu_query->fetchrow_hashref();
$speed_world = $tu_row->{'speed_world'};
$speed_ua = $tu_row->{'speed_ua'};
$tu_query->finish();
push @{ $RAD_REPLY{'Cisco-Account-Info'} }, ("A$speed_world");
push @{ $RAD_REPLY{'Cisco-Account-Info'} }, ("A$speed_ua");
push @{ $RAD_REPLY{'Cisco-AVPair'}}, ("subscriber:accounting-list=ISG-AUTH-1");
$RAD_REPLY{'Session-Timeout'} = "86400";
$RAD_REPLY{'Idle-Timeout'} = "200";
$RAD_REPLY{'User-Name'} = "$username";
logger($curdate,$username,"Login OK: $username [($RAD_REQUEST{'User-Name'}/$mac)]");
#&radiusd::radlog(2,"Login OK: $username [($RAD_REQUEST{'User-Name'}/$mac)]");
return 2;
$dbh->disconnect;
# Accounting
sub accounting {
db_connect();
$ipaddr = $RAD_REQUEST{'Framed-IP-Address'};
$user = $RAD_REQUEST{'User-Name'};
$sessid = $RAD_REQUEST{'Acct-Session-Id'};
$in = $RAD_REQUEST{'Acct-Input-Octets'};
$out = $RAD_REQUEST{'Acct-Output-Octets'};
$time = $RAD_REQUEST{'Acct-Session-Time'};
$cid = $RAD_REQUEST{'Calling-Station-Id'};
$error = $RAD_REQUEST{'Acct-Terminate-Cause'};
if ($RAD_REQUEST{'Acct-Status-Type'} eq "Start") {
$start_query = $dbh->do("INSERT INTO acct(username,mac,ip,session_id,date_start)
VALUES ('$user','$cid','$ipaddr','$sessid','$curdate')");
$dbh->disconnect();
if ($RAD_REQUEST{'Acct-Status-Type'} eq "Interim-Update") {
$update_query = $dbh->do("UPDATE acct SET upload='$in', download='$out',
session_time='$time' WHERE session_id='$sessid'");
$dbh->disconnect();
if ($RAD_REQUEST{'Acct-Status-Type'} eq "Stop") {
$stop_query = $dbh->do("UPDATE acct SET upload='$in', download='$out', error='$error',
session_time='$time', date_stop='$curdate' WHERE session_id='$sessid'"); # If recived "STOP"
$dbh->disconnect();
$dbh->disconnect();
return 2;
Абонентов около 200, в mysql значение max_connections=500 !
Edited by scream
скорее всего разрослась таблица acct и операции с ней не укладываются в положенное время. Сколько в ней строк? Для session_id есть индекс? Сделайте analyze над таблицей, не повредит в любом случае.
mysql> SELECT COUNT(*) FROM acct;
| COUNT(*) |
| 193239 |
1 row in set (3 min 20.57 sec)
mysql> ANALYZE TABLE acct;
| Table | Op | Msg_type | Msg_text |
| isg.acct | analyze | status | OK |
1 row in set (43.48 sec)
Edited by scream
у вас сервер слабый или загружен чрезмерно или еще какая проблема с базой. Для 200К строк в таблице 3 минуты на подсчет их количества - это запредельно много.
После analyze не стало легче? Всетаки есть индекс для session_id ?
После analyze не стало легче, а вот индекса не было. Создал индекс для для session_id, и еще для username , и все начало летать ))
Большое спасибо, а то я целый день крутил радиус, а оказалось что проблема с базой ))
