Всем доброго времени суток.
Есть софтовый бридж:
linux debian 6.0.4
kernel 2.6.33.20
проц core-i5
шейпер на tc
Сетевая 4-портовая, по 2 интерфейса объединены в бонды.
auto eth0
iface eth0 inet manual
bond-master bond0
auto eth1
iface eth1 inet manual
bond-master bond0
auto eth2
iface eth2 inet manual
bond-master bond1
auto eth3
iface eth3 inet manual
bond-master bond1
auto bond0
allow-hotplug bond0
iface bond0 inet manual
   bond_mode 802.3ad
   bond_miimon 100
   bond_downdelay 200
   bond_updelay 200
   bond_primary eth0 eth1
auto bond1
allow-hotplug bond1
iface bond1 inet manual
   bond_mode 802.3ad
   bond_miimon 100
   bond_downdelay 200
   bond_updelay 200
   bond_primary eth2 eth3
auto br0
allow-hotplug br0
iface br0 inet static
   address 192.168.1.123
   netmask 255.255.255.0
   network 192.168.1.0
   broadcast 192.168.1.255
   gateway 192.168.1.254
   bridge_ports bond0 bond1
   bridge_maxwait 0
Небольшой тюнинг сетевухи:
echo 'Привязка очередей сетевых интерфейсов к ядрам'
ifconfig eth0 up
echo 1 > /proc/irq/`cat /proc/interrupts | grep 'eth0-TxRx-0' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 2 > /proc/irq/`cat /proc/interrupts | grep 'eth0-TxRx-1' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 4 > /proc/irq/`cat /proc/interrupts | grep 'eth0-TxRx-2' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 8 > /proc/irq/`cat /proc/interrupts | grep 'eth0-TxRx-3' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
ifconfig eth1 up
echo 8 > /proc/irq/`cat /proc/interrupts | grep 'eth1-TxRx-0' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 4 > /proc/irq/`cat /proc/interrupts | grep 'eth1-TxRx-1' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 2 > /proc/irq/`cat /proc/interrupts | grep 'eth1-TxRx-2' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 1 > /proc/irq/`cat /proc/interrupts | grep 'eth1-TxRx-3' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
ifconfig eth2 up
echo 1 > /proc/irq/`cat /proc/interrupts | grep 'eth2-TxRx-0' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 2 > /proc/irq/`cat /proc/interrupts | grep 'eth2-TxRx-1' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 4 > /proc/irq/`cat /proc/interrupts | grep 'eth2-TxRx-2' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 8 > /proc/irq/`cat /proc/interrupts | grep 'eth2-TxRx-3' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
ifconfig eth3 up
echo 8 > /proc/irq/`cat /proc/interrupts | grep 'eth3-TxRx-0' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 4 > /proc/irq/`cat /proc/interrupts | grep 'eth3-TxRx-1' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 2 > /proc/irq/`cat /proc/interrupts | grep 'eth3-TxRx-2' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 1 > /proc/irq/`cat /proc/interrupts | grep 'eth3-TxRx-3' | awk -F \: '{printf $1}'| tr -d ' '`/smp_affinity
echo 'Установка дополнительных параметров сетевых интерфейсов'
ethtool -G eth0 rx 2048
ethtool -G eth0 tx 2048
ethtool -G eth1 rx 2048
ethtool -G eth1 tx 2048
ethtool -G eth2 rx 2048
ethtool -G eth2 tx 2048
ethtool -G eth3 rx 2048
ethtool -G eth3 tx 2048
ethtool -A eth0 autoneg off rx off tx off
ethtool -A eth1 autoneg off rx off tx off
ethtool -A eth2 autoneg off rx off tx off
ethtool -A eth3 autoneg off rx off tx off
ifconfig eth0 txqueuelen 10000
ifconfig eth1 txqueuelen 10000
ifconfig eth2 txqueuelen 10000
ifconfig eth3 txqueuelen 10000
Параметры sysctl:
#Увеличиваем максимальный размер памяти отводимой для TCP буферов
net.core.wmem_max = 16777216
net.core.rmem_max = 16777216
#Тюнинг буферов для TCP и UDP соединений (min, default, max bytes)
net.ipv4.tcp_rmem = 8192 8388608 16777216
net.ipv4.tcp_wmem = 8192 4194394 16777216
#Запрещаем кеширование статуса ssthresh
net.ipv4.tcp_no_metrics_save = 1
#размер backlog
net.core.netdev_max_backlog = 1000
#Увеличиваем число входящих соединений, которые могут стоять в очереди, прежде чем будут отброшены
net.core.somaxconn = 262144
#Размер буферов по умолчанию для приема и отправки данных через сокеты
net.core.wmem_default = 4194394
net.core.rmem_default = 8388608
net.ipv4.tcp_max_tw_buckets = 1440000
Сервак прогоняет около 1.5ГБ трафика.
Сегодня столкнулись со странной проблемой: сервак начал тупить (при этом процессор и память в норме), и периодически перестал пропускать через себя трафик.
Пустил трафик в обход бриджа, но тормоза остались.
При этом также тупил SSH-доступ и JAVA-консоль через KVM
При этом в логах есть такое:
Jan 20 20:04:09 linbridge2 kernel: [ 1141.059747] CE: hpet2 increasing min_delta_ns to 33750 nsec
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132790] tail          D ffff880203a90de0     0 13883  13851 0x00000004
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132793]  ffff880008e75840 0000000000000046 0000000000000000 0000000000000002
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132795]  0000000000000000 0000000000000000 ffff880203a90de0 ffff88021f076f00
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132819]  0000000100113f47 0000000000015840 0000000000015840 000000000000fa10
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132821] Call Trace:
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132827]  [<ffffffff812f4cc5>] ? schedule_timeout+0x2d/0xd7
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132829]  [<ffffffff812f4b48>] ? wait_for_common+0xd1/0x14e
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132832]  [<ffffffff8103e83f>] ? default_wake_function+0x0/0xe
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132835]  [<ffffffff810901bc>] ? synchronize_sched+0x0/0x52
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132836]  [<ffffffff81090208>] ? synchronize_sched+0x4c/0x52
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132839]  [<ffffffff8105aa60>] ? wakeme_after_rcu+0x0/0x10
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132842]  [<ffffffff8106050e>] ? __synchronize_srcu+0x2d/0xaa
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132845]  [<ffffffff8110fd14>] ? fsnotify_put_group+0x6a/0x8d
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132846]  [<ffffffff81111999>] ? inotify_release+0x24/0x2f
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132849]  [<ffffffff810e94b1>] ? __fput+0x100/0x1b4
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132851]  [<ffffffff810e68ad>] ? filp_close+0x5f/0x6a
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132853]  [<ffffffff81045b02>] ? put_files_struct+0x67/0xbf
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132854]  [<ffffffff810473b6>] ? do_exit+0x24a/0x6f4
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132857]  [<ffffffff810075c8>] ? __switch_to+0x12f/0x21b
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132858]  [<ffffffff810478d3>] ? do_group_exit+0x73/0x9b
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132860]  [<ffffffff810551b7>] ? get_signal_to_deliver+0x353/0x375
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132862]  [<ffffffff81007f4b>] ? do_signal+0x6c/0x68b
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132863]  [<ffffffff81112362>] ? inotify_read+0x26d/0x297
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132865]  [<ffffffff8105ca39>] ? autoremove_wake_function+0x0/0x2a
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132867]  [<ffffffff8100858f>] ? do_notify_resume+0x25/0x67
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132868]  [<ffffffff810e89bc>] ? sys_read+0x5f/0x6b
Jan 20 20:11:06 linbridge2 kernel: [ 1557.132870]  [<ffffffff81008cce>] ? int_signal+0x12/0x17
Jan 20 20:17:59 linbridge2 kernel: [ 1969.431662] CE: hpet5 increasing min_delta_ns to 33750 nsec
С чем может быть связано такое поведение?
Есть аналогичный сервак (но на core-i7), который обрабатывает чуть больше трафика, с ним таких проблем нет.
Это может помочь от
Но в инете не нашёл информацию, чтобы эта "ошибка" приводила к таким симптомам.
И остаётся еще куча других ошибок, которые пока не понятно как исправлять.
