Исследую SNR-S2940-8G-v2 на предмет использования в качестве домового свитча.
SoftWare Version 6.2.138.103
Настраиваю DHCP Relay, вот кусок конфига.
service dhcp
ip forward-protocol udp bootps
ip dhcp server relay information enable
ip dhcp relay information option
ip dhcp relay information option subscriber-id format hex
ip dhcp relay information option self-defined subscriber-id format hex
ip dhcp relay share-vlan 120 sub-vlan 20
vlan 20
name Users
vlan 86
name PPPoE
vlan 120
name Management
Interface Ethernet1/1
switchport mode hybrid
switchport hybrid allowed vlan 20;86 untag
switchport hybrid native vlan 20
Interface Ethernet1/2
Interface Ethernet1/9
switchport mode trunk
Interface Ethernet1/10
interface Vlan120
ip address 192.168.42.133 255.255.255.252
 !forward protocol udp 67(active)!
ip helper-address 192.168.22.21
ip default-gateway 192.168.42.134
protocol-vlan etype 34915 vlan 86 priority 0
protocol-vlan etype 34916 vlan 86 priority 0
isolate-port group test switchport interface Ethernet1/8
isolate-port group test switchport interface Ethernet1/7
isolate-port group test switchport interface Ethernet1/6
isolate-port group test switchport interface Ethernet1/5
isolate-port group test switchport interface Ethernet1/4
isolate-port group test switchport interface Ethernet1/3
isolate-port group test switchport interface Ethernet1/2
isolate-port group test switchport interface Ethernet1/1
Всё хорошо, адрес получаю, но
на Uplink порту идут броадкастом DHCP Discover от абонента.
Собственно можно-ли как-то это побороть?
  • 3 weeks later...
