OKyHb Posted February 13, 2012 Posted February 13, 2012 Есть cisco 7606 с 12.2(33)SRE5 и такими модулями: core#sh module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1243XXXX 2 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1245XXXX 3 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1431XXXX 4 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1434XXXX 5 5 Route Switch Processor 720 10GE (Hot) RSP720-3CXL-10GE JAE1451XXXX 6 5 Route Switch Processor 720 10GE (Activ RSP720-3CXL-10GE JAE1227XXXX Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 Centralized Forwarding Card WS-F6700-CFC SAL1245XXXX 4.1 Ok 2 Centralized Forwarding Card WS-F6700-CFC SAL1245XXXX 4.1 Ok 3 Distributed Forwarding Card WS-F6700-DFC3CXL SAL1429XXXX 1.6 Ok 4 Distributed Forwarding Card WS-F6700-DFC3CXL SAL1435XXXX 1.6 Ok 5 Policy Feature Card 3 7600-PFC3CXL-10GE JAE1449XXXX 1.2 Ok 5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1451XXXX 2.2 Ok 6 Policy Feature Card 3 7600-PFC3CXL-10GE JAE1228XXXX 1.1 Ok 6 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1227XXXX 2.0 Ok Резко стало нехватать 10G портов, решили задействовать uplink порты на резервном супервизоре. Вместо дефолтного RPR режима просто поставили SSO. core#sh run | sec redundancy redundancy main-cpu auto-sync running-config mode sso core#sh fabric switching-mode Global switching mode is Compact dCEF mode is not enforced for system to operate Fabric module is not required for system to operate Modules are allowed to operate in bus mode Truncated mode is allowed, due to presence of DFC, CEF720, Standby supervisor module Module Slot Switching Mode 1 Crossbar 2 Crossbar 3 dCEF 4 dCEF 5 dCEF 6 dCEF Всё отлично, нужных 2 шт. 10G портов работают, трафик ходит. Но при этом стало залипать IPTV. На tcpdump это выглядит след. образом - подписываемся на мультикаст группу, поток начинает приходить, и каждую минуту сразу после получения IGMP Query general поток пропадает на несколько секунд (на этой 76й включен ip pim passive для мультикастового влана). Из-за чего может быть такая проблема? У кого-то успешно используется такой режим резервирования (SSO)? Какие дополнительные настройки используются? Вставить ник Quote
