Проблема состоит в следующем при физическом разрыве PPPoE тунеля, NAS в виде Cisco 10008 не формирует stop пакет RADIUS.
При этом сессии нет, биллинг думает что аббонент активен, и начинает тикать таймер по наличию alive.
Хотелось бы видеть stop.
Судя по документации подобных глюков быть не должно. SMART отсутвует.
Cisco 10008
Version 12.2(33)SB11, RELEASE SOFTWARE (fc1)
Cisco C10008 (PRE3-RP) processor (revision V02 ) with 1933311K/163839K bytes of memory.
Processor board ID NWG124208LQ
SB-1 CPU at 800Mhz, Implementation 0x401, Rev 0.2, 512KB L2 Cache
Backplane version 1.0, 8 slot
NAME: "module 3/0", DESCR: "4 bay Cisco 10000 SPA Jacket Card"
PID: 10000-SIP-600 , VID: 1.0, SN: CAT1415F0PU
NAME: "SPA subslot 3/0", DESCR: "1-port 10 Gigabit Ethernet Shared Port Adapter XFP based"
PID: SPA-1X10GE-L-V2 , VID: V02, SN: JAE14070NVZ
NAME: "subslot 3/0 transceiver 0", DESCR: "OC192 + 10GBASE-L"
PID: XFP-10GLR-OC192SR , VID: 03 , SN: ONT140410LJ
Настройки
aaa group server radius group1
server 10.10.xx.254 auth-port 1812 acct-port 1815
aaa authentication login local_log local
aaa authentication login rad group group1 local
aaa authentication login ISG group radius
aaa authentication ppp local_ppp local
aaa authentication ppp rad group group1 local
aaa authentication ppp ISG group radius
aaa authorization network default group group1 local
aaa authorization network ISG group radius
aaa authorization subscriber-service default local group group1
aaa accounting delay-start all
aaa accounting update periodic 1
aaa accounting exec rad start-stop group radius group group1
aaa accounting network rad start-stop group group1
aaa accounting network ISG start-stop group radius
aaa attribute list ISG
aaa nas port extended
bba-group pppoe global
virtual-template 1
sessions max limit 4000
sessions per-mac limit 4
sessions per-mac iwf limit 4
sessions auto cleanup
interface TenGigabitEthernet3/0/0.818
description PPPoE for Lenina75
encapsulation dot1Q 818
pppoe enable group global
interface Virtual-Template1
description USED FOR VPN_Session
ip unnumbered Loopback50
ip tcp adjust-mss 1300
load-interval 30
peer default ip address pool vpn_pool
ppp mtu adaptive
ppp authentication chap pap ms-chap ms-chap-v2 callin ISG
ppp accounting ISG
