h1vs2 Posted December 6, 2011 Posted December 6, 2011 (edited) Доброго времени суток ! Прошу помочь. Создал VR на экстриме - бгп не поднимается. configure vr VR-Default delete ports 1 create virtual-router "VR-WORLD" type vrf vr "VR-Default" configure vr VR-WORLD add protocol bgp enable vr "VR-WORLD" create vlan "ISP_backup" vr "VR-WORLD" configure vlan "ISP_backup" tag 1711 configure vlan "ISP_backup" add ports 1 tagged configure vlan "ISP_backup" ipaddress xx.xx.xx.54 255.255.255.252 enable ipforwarding vlan ISP_backup create bgp neighbor xx.xx.xx.53 remote-AS-number НННН enable bgp neighbor xx.xx.xx.53 configure bgp neighbor xx.xx.xx.53 send-community extended configure bgp neighbor xx.xx.xx.53 route-policy in bgp_ISP_world_in configure bgp neighbor xx.xx.xx.53 route-policy out bgp_ISP_world_out enable bgp neighbor xx.xx.xx.53 soft-in-reset В итоге : #sh bgp nei --cut-- Ee-- xx.xx.xx.53 YYYY 1 CONNECT 0 0 (0 ) 0:1:42:12 #sh "VR-WORLD" Virtual Router : VR-WORLD Type : Non-VPN VRF [b]Operational State : Down (Inactive Vlans)[/b] IPv4 Admin State : Enabled IPv6 Admin State : Enabled IPv4 Route Sharing : Disabled IPv6 Route Sharing : Disabled Parent VR : VR-Default Protocols Configured : -------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------- BGP bgp bgp-3 2 -------------------------------------------------------------------- VLANS : ISP_backup Virtual Router Totals : Total Protocols : 1 Max Protocols : 8 Total Ports : 0 Total Vlans : 1 Total IPv4 Vlans : 1 Total Ipv6 Vlans : 0 Active IPv4 Vlans : 0 Active Ipv6 Vlans : 0 Inactive IPv4 Vlans : 1 Inactive Ipv6 Vlans : 0 # ping vr "VR-WORLD" xx.xx.xx.53 Ping(ICMP) xx.xx.xx.53: 4 packets, 8 data bytes, interval 1 second(s). 16 bytes from xx.xx.xx.53: icmp_seq=0 ttl=64 time=9.077 ms 16 bytes from xx.xx.xx.53: icmp_seq=1 ttl=64 time=3.658 ms 16 bytes from xx.xx.xx.53: icmp_seq=2 ttl=64 time=3.774 ms 16 bytes from xx.xx.xx.53: icmp_seq=3 ttl=64 time=3.701 ms # sh vlan "ISP_backup" VLAN Interface with name ISP_backup created by user Admin State: Enabled Tagging: 802.1Q Tag 1711 Virtual router: VR-WORLD IPv4 Forwarding: Enabled Primary IP : xx.xx.xx.54/30 IPv6 Forwarding: Disabled IPv6: None STPD: None Protocol: Match all unfiltered protocols Loopback: Disabled NetLogin: Disabled QosProfile: None configured Egress Rate Limit Designated Port: None configured Flood Rate Limit QosProfile: None configured Ports: 1. (Number of active ports=1) Tag: *1(ISP) Flags: (*) Active, (!) Disabled, (g) Load Sharing port (b) Port blocked on the vlan, (m) Mac-Based port (a) Egress traffic allowed for NetLogin (u) Egress traffic unallowed for NetLogin (t) Translate VLAN tag for Private-VLAN (s) Private-VLAN System Port, (L) Loopback port (e) Private-VLAN End Point Port (x) VMAN Tag Translated port (G) Multi-switch LAG Group port В "VR-Default" все конечно-же работает. Кто сталкивался, подскажите пожалуйста. Edited December 6, 2011 by h1vs2 Вставить ник Quote
Alexandr Ovcharenko Posted December 6, 2011 Posted December 6, 2011 enable vlan "ISP_backup" enable bgp ? Вставить ник Quote
h1vs2 Posted December 6, 2011 Author Posted December 6, 2011 enable vlan "ISP_backup" enable bgp ? Это конечно-же да. В выводах по влану видно, что он включен. A bgp работает, это живой бордер, он роутит сейчас, только в дефолтном VR Вставить ник Quote
h1vs2 Posted December 7, 2011 Author Posted December 7, 2011 UP Никто не сталкивался ? У кого-то работает VRF на ExtremeOS ? Вставить ник Quote
h1vs2 Posted December 7, 2011 Author Posted December 7, 2011 (edited) Все удалил, сделал заново. Теперь показывает : # sh "VR-WORLD" Virtual Router : VR-WORLD Type : Non-VPN VRF Operational State : Up IPv4 Admin State : Enabled IPv6 Admin State : Enabled IPv4 Route Sharing : Disabled IPv6 Route Sharing : Disabled Parent VR : VR-Default Protocols Configured : -------------------------------------------------------------------- Protocol Process Configuration Protocol Name Name Module Name Instances -------------------------------------------------------------------- BGP bgp bgp-3 2 -------------------------------------------------------------------- VLANS : ISP_backup Virtual Router Totals : Total Protocols : 1 Max Protocols : 8 Total Ports : 0 Total Vlans : 1 Total IPv4 Vlans : 1 Total Ipv6 Vlans : 0 Active IPv4 Vlans : 1 Active Ipv6 Vlans : 0 Inactive IPv4 Vlans : 0 Inactive Ipv6 Vlans : 0 Но: * (vr VR-WORLD) x650 # create bgp neighbor xx.xx.xx.53 remote-AS-number YYYY Error! EBGP peer xx.xx.xx.53 not directly connected Хотя хост пингуется, все хорошо. Куда копать ? Edited December 7, 2011 by h1vs2 Вставить ник Quote
Alexandr Ovcharenko Posted December 7, 2011 Posted December 7, 2011 А если попробовать сначала создать виртуал-роутер, потом сменить контекст командой virtual-router {<vr-name>} (гляньте команд-референс), а уже потом создавать влан и все прочее? Вставить ник Quote
h1vs2 Posted December 7, 2011 Author Posted December 7, 2011 А если попробовать сначала создать виртуал-роутер, потом сменить контекст командой virtual-router {<vr-name>} (гляньте команд-референс), а уже потом создавать влан и все прочее? Так и делалось. В документации написано, что сначала надо создать виртуал-роутер, добавить в него протокол, включить его, а потом уже оперировать ним самим. В любом случае пробовал по-всякому - говорит, что не дирекли конектед и все. Хотя из контекста созданного VR прекрасно пингуется. Даже делал disable/enable bgp - не помогает. Догадки можно строить вечно. Мне бы человека, у которого данный функционал работает, чтобы подсказал... Вставить ник Quote
h1vs2 Posted December 9, 2011 Author Posted December 9, 2011 (edited) Всем спасибо! Мне подсказали, все оказалось очень просто. type vrf - указывать не надо ) Тему можно закрывать. Edited December 9, 2011 by h1vs2 Вставить ник Quote
