День добрый. Возникла потребность настроить nat на ASA
ASA Version 8.3(1)
hostname ASA
interface GigabitEthernet0/0
nameif in
security-level 100
ip address 10.10.11.14 255.255.255.252
interface GigabitEthernet0/1
nameif out
security-level 10
ip address 10.10.11.18 255.255.255.252
same-security-traffic permit intra-interface
object network SALES_NETWORK
subnet 192.168.1.0 255.255.255.0
object network NAT_POOL_SALES
host 1.1.1.1
object network NAT_POOL_1
range 2.2.2.1 2.2.2.3
object network WORK_REAL
range 192.168.2.1 192.168.2.10
object-group network WORK_MAPPED
network-object object NAT_POOL_1
access-list ALL extended permit ip any any
pager lines 24
mtu Voltaire 1500
mtu Proxima 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (in,out) source dynamic SALES_NETWORK NAT_POOL_SALES
nat (in,out) source dynamic WORK_REAL WORK_MAPPED
access-group ALL global
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
track 11 rtr 1 reachability
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
 message-length maximum client auto
 message-length maximum 512
policy-map global_policy
class inspection_default
 inspect ftp
 inspect h323 h225
 inspect h323 ras
 inspect rsh
 inspect rtsp
 inspect esmtp
 inspect sqlnet
 inspect skinny
 inspect sunrpc
 inspect xdmcp
 inspect sip
 inspect netbios
 inspect tftp
 inspect ip-options
service-policy global_policy global
Имеются два правила для ната - для сетей SALES_NETWORK и WORK_REAL.
Сеть SALES_NETWORK работает без проблем.
Проблемы возникают с сетью WORK_REAL-перестает транслировать, в логе выводит
portmap translation creation failed for icmp src in:192.168.2.1 dst out:8.8.8.8 (type 8, code 0)
Еще при этом в логе появляется сообщение типа
Duplicate TCP SYN from out:115.135.86.131/4935 to out:192.168.3.1/3389 with different initial sequence number
При чем адреса вообще не из моих сетей. И что еще смущает - from и to указан один и тот же интерфейс - внешний.
Подскажите в чем может быть проблема.
Edited by kunla
