Имеется 7609 с SUP720-3BXL:
Sh ver:
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC6, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 14:14 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
7609_Test_Belyaevo uptime is 27 minutes
Uptime for this control processor is 27 minutes
System returned to ROM by reload (SP by reload)
System restarted at 10:56:31 MSK Fri Sep 9 2011
System image file is "disk1:/c7600s72033-advipservicesk9-mz.122-33.SRC6.bin"
Last reload type: Normal Reload
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco CISCO7609 (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID FOX083606UH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
10 Virtual Ethernet interfaces
26 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Sh module:
Mod Ports Card Type                              Model              Serial No.
 1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       XXXXXXXXXXX
 5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     XXXXXXXXXXX
 8    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      XXXXXXXXXXX
Mod MAC addresses                       Hw    Fw           Sw           Status
 1  xxxx.xxxx.xxxx to xxxx.xxxx.xxxx   2.4   12.2(14r)S5  12.2(33)SRC6 Ok
 5  xxxx.xxxx.xxxx to xxxx.xxxx.xxxx   4.0   8.5(3)       12.2(33)SRC6 Ok
 8  xxxx.xxxx.xxxx to xxxx.xxxx.xxxx   2.3   12.2(18r)S1  12.2(33)SRC6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
 1  Centralized Forwarding Card WS-F6700-CFC       XXXXXXXXXXX  2.1    Ok
 5  Policy Feature Card 3       WS-F6K-PFC3BXL     XXXXXXXXXXX  1.3    Ok
 5  MSFC3 Daughterboard         WS-SUP720          XXXXXXXXXXX  2.1    Ok
 8  Distributed Forwarding Card WS-F6700-DFC3CXL   XXXXXXXXXXX  1.6    Ok
Rommon на SUP'е обновлен.
Sh module ver:
Mod  Port Model              Serial #    Versions
 1   24  WS-X6724-SFP       XXXXXXXXXXX Hw : 2.4
                                        Fw : 12.2(14r)S5
                                        Sw : 12.2(33)SRC6
                                        Sw1: 8.7(0.22)SRC20
         WS-F6700-CFC       XXXXXXXXXXX Hw : 2.1
 5    2  WS-SUP720-3BXL     XXXXXXXXXXX Hw : 4.0
                                        Fw : 8.5(3)
                                        Sw : 12.2(33)SRC6
                                        Sw1: 8.7(0.22)SRC20
         WS-SUP720          XXXXXXXXXXX Hw : 2.1
                                        Fw : 12.2(17r)SX7
                                        Sw : 12.2(33)SRC6
         WS-F6K-PFC3BXL     XXXXXXXXXXX Hw : 1.3
 8    8  WS-X6708-10GE      XXXXXXXXXXX Hw : 2.3
                                        Fw : 12.2(18r)S1
                                        Sw : 12.2(33)SRC6
                                        Sw1: 8.7(0.22)SRC20
         WS-F6700-DFC3CXL   XXXXXXXXXXX Hw : 1.6
Купили карточку Transcend на 2GB.
Sh disk1: all
-#- --length-- -----date/time------ path
1    123100196 Sep 9 2011 03:36:22 +04:00 c7600s72033-advipservicesk9-mz.122-33.SRC6.bin
1880981504 bytes available (123109376 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
  Manufacturer Name      TRANSCEND
  Model Number           TS2GCF133
  Serial Number          20100921    C613006A
  Firmware Revision      20100804
  Number of Heads        16
  Number of Cylinders    3884
  Sectors per Cylinder   63
  Sector Size            512
  Total Sectors          3915072
ATA PARTITION 1 INFO
  Start Sector           63
  Number of Sectors      3915009
  Size in Bytes          2004484608
  File System Type       FAT16
  Number of FAT Sectors  239
  Sectors Per Cluster    64
  Number of Clusters     61160
  Number of Data Sectors 3914240
  Base FAT Sector        108
  Base Root Sector       586
  Base Data Sector       618
ATA MONLIB INFO
  Image Monlib size      64632
  Disk Monlib Size       54264
  Disk Space Available   54784
  Name                   NA
  End Sector             NA
  Start sector           NA
  Updated By             NA
  Version                NA
Форматировали на софте c7600s72033-advipservicesk9-mz.122-33.SRC6.bin и s72033-pk9sv-mz.122-18.SXD6.bin. Результат один - в ИОСе флешка читается и пишется, но при загрузке получаем:
System Bootstrap, Version 8.5(3)
Copyright (c) 1994-2008 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot disk1:/c7600s72033-advipservicesk9-mz.122-33.SRC6.bin"
Loading image, please wait ...
open: read error...requested 0x4 bytes, got 0xffffffff
trouble reading device magic number
loadprog: error - on file open
boot: cannot load "disk1:/c7600s72033-advipservicesk9-mz.122-33.SRC6.bin"
Я бы согласился, что левая флешка, 2 ГБ (при рекомендованном максисуме 1ГБ), НО:
Если флешка отформатирована в 122-18.SXD6, то делаем так:
Autoboot executing command: "boot disk0:/s72033-pk9sv-mz.122-18.SXD6.bin"
monitor: command "boot" aborted due to user interrupt
Exit at the end of BOOT string
rommon 1 > boot disk1:/c7600s72033-advipservicesk9-mz.122-33.SRC6.bin
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################################################################ [OK]
Все грузится замечательно.
Если отформатирована в 122-33.SRC6, то в роммоне сначала надо сделать dir disk1:, а потом boot disk1:/c7600s72033-advipservicesk9-mz.122-33.SRC6.bin и опять получаем загруженный ИОС.
Подскажите куда копать.
  • 2 weeks later...
Большие флешки без геморроя поддерживаются только 1800/2800/3800 ISR,
остальные серии могут капризничать, аналогично вашему, сталкивались на 3725.
А что мешает купить CF на 1Gb?
Отсутствием их в продаже :) 2Гб - это минимум что нашли.
  • 1 month later...
Для истории:
Проблема решилась. Оказывается, что у SUP720 (FirmWare обновляли до последнего) есть проблемы с загрузкой из Disk1. Когда вставили флешку в Disk0, то загрузка пошла прекрасно и с 1Гб и с 2Гб, даже на старых Rommon'е и Firmwar'е. Проверяли на двух разных железках - результат одинаков.
