pliskinsad Posted July 19, 2011 Posted July 19, 2011 Всем привет. Есть 7606 и asr1002. Между ними поднят port-channel ASR interface Port-channel2 description //MPLS_UPLINK// mtu 1546 ip address 10.25.10.14 255.255.255.252 ip flow ingress ip flow egress negotiation auto mpls ip ! interface GigabitEthernet0/0/0 mtu 1546 no ip address no ip redirects no ip proxy-arp load-interval 30 negotiation auto channel-group 2 mode active ! interface GigabitEthernet0/0/1 mtu 1546 no ip address no ip redirects no ip proxy-arp load-interval 30 negotiation auto channel-group 2 mode active ASR1002#sh run | i mpls no mpls ip propagate-ttl forwarded mpls label protocol ldp mpls ip 7606 interface GigabitEthernet2/20 description # Portchannel ASR1002 link 1 # mtu 1546 bandwidth 1000000 no ip address no ip redirects no ip proxy-arp load-interval 30 tag-switching ip channel-group 2 mode active ! interface GigabitEthernet2/21 description # Portchannel ASR1002 link 2 # mtu 1546 bandwidth 1000000 no ip address no ip redirects no ip proxy-arp load-interval 30 tag-switching ip channel-group 2 mode active interface Port-channel2 description # MPLS ASR1002# mtu 1546 ip address 10.25.10.13 255.255.255.252 tag-switching ip ASR1002#ping 10.25.10.13 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.25.10.13, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms ASR1002#sh mpls ldp neighbor ASR1002# Дебаг тоже ничего явного не выявил. На 7606 mpls точно рабочий, т.к. с таким же конфигом работает на других интерфейсах. За исключением того, что тут Port-Channel. Куда копать? p.s. asr1000rp1-advipservicesk9.03.01.02.S.150-1.S2.bin s72033-advipservicesk9_wan-mz.122-18.SXF17a.bin Вставить ник Quote
pliskinsad Posted July 19, 2011 Author Posted July 19, 2011 7606#sh etherchannel 2 detail Group state = L3 Ports: 2 Maxports = 16 Port-channels: 1 Max Port-channels = 16 Protocol: LACP Minimum Links: 0 Ports in the group: ------------------- Port: Gi2/20 ------------ Port state = Up Mstr In-Bndl Channel group = 2 Mode = Active Gcchange = - Port-channel = Po2 GC = - Pseudo port-channel = Po2 Port index = 0 Load = 0x55 Protocol = LACP Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs. A - Device is in active mode. P - Device is in passive mode. Local information: LACP port Admin Oper Port Port Port Flags State Priority Key Key Number State Gi2/20 SA bndl 32768 0x2 0x2 0x214 0x3D Partner's information: Partner Partner LACP Partner Partner Partner Partner Partner Port Flags State Port Priority Admin Key Oper Key Port Number Port State Gi2/20 SA bndl 32768 0x0 0x2 0x1 0x3D Age of the port in the current state: 0d:06h:15m:33s Port: Gi2/21 ------------ Port state = Up Mstr In-Bndl Channel group = 2 Mode = Active Gcchange = - Port-channel = Po2 GC = - Pseudo port-channel = Po2 Port index = 1 Load = 0xAA Protocol = LACP Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs. A - Device is in active mode. P - Device is in passive mode. Local information: LACP port Admin Oper Port Port Port Flags State Priority Key Key Number State Gi2/21 SA bndl 32768 0x2 0x2 0x215 0x3D Partner's information: Partner Partner LACP Partner Partner Partner Partner Partner Port Flags State Port Priority Admin Key Oper Key Port Number Port State Gi2/21 SA bndl 32768 0x0 0x2 0x2 0x3D Age of the port in the current state: 0d:06h:15m:32s Port-channels in the group: ---------------------- Port-channel: Po2 (Primary Aggregator) ------------ Age of the Port-channel = 0d:10h:24m:03s Logical slot/port = 14/2 Number of ports = 2 Passive port list = Gi2/20 Gi2/21 Port state = Port-channel L3-Ag Ag-Inuse Protocol = LACP Ports in the Port-channel: Index Load Port EC state No of bits ------+------+------+------------------+----------- 0 55 Gi2/20 Active 4 1 AA Gi2/21 Active 4 Time since last port bundled: 0d:06h:15m:44s Gi2/21 Time since last port Un-bundled: 0d:06h:15m:50s Gi2/21 ASR1002#sh lacp 2 neighbor detail Flags: S - Device is requesting Slow LACPDUs F - Device is requesting Fast LACPDUs A - Device is in Active mode P - Device is in Passive mode Channel group 2 neighbors Partner's information: Partner Partner Partner Port System ID Port Number Age Flags Gi0/0/0 32768,5475.d0a6.d500 0x214 5s SA LACP Partner Partner Partner Port Priority Oper Key Port State 32768 0x2 0x3D Port State Flags Decode: Activity: Timeout: Aggregation: Synchronization: Active Short Yes Yes Collecting: Distributing: Defaulted: Expired: Yes Yes No No Partner Partner Partner Port System ID Port Number Age Flags Gi0/0/1 32768,5475.d0a6.d500 0x215 25s SA LACP Partner Partner Partner Port Priority Oper Key Port State 32768 0x2 0x3D Port State Flags Decode: Activity: Timeout: Aggregation: Synchronization: Active Short Yes Yes Collecting: Distributing: Defaulted: Expired: Yes Yes No No ASR1002# Вставить ник Quote
pliskinsad Posted July 19, 2011 Author Posted July 19, 2011 upd. После ребута asr все заработало =\ Тему можно закрывать. Спасибо индусам за спокойные ночи :) Вставить ник Quote
rus-p Posted July 22, 2011 Posted July 22, 2011 Можно каверзный вопрос, зачем вам на ASR1k MPLS ? Вставить ник Quote
