Есть железка Foundry ( Brocade) BigIron BI-RX4.
telnet@BigIron RX-4 Router>sh ver
HW: BigIron RX Router
BigIron RX-4 CHASSIS (Serial #: SA23050013, Part #: 31550-000B)
RX-BI-SFM1 Switch Fabric Module 1 (Serial #: SA15072005, Part #: 35548-000D)
FE 1: Type fe200, Version 2
RX-BI-SFM1 Switch Fabric Module 2 (Serial #: SA04071707, Part #: 35548-000D)
RX-BI-SFM1 Switch Fabric Module 3 (Serial #: SA07071216, Part #: 35548-000D)
SL M1: RX-BI-MR2 Management Module (High Value) Active (Serial #: SA12061609, Part #: 31524-000B):
Boot : Version 2.7.3T145 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Aug 30 2010 at 16:10:26 labeled as rmb02703
(439582 bytes) from boot flash
Monitor : Version 2.7.3T145 Copyright © 1996-2010 Brocade Communications Systems, Inc.
(439582 bytes) from code flash
IronWare : Version 2.7.3T143 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Aug 30 2010 at 16:16:10 labeled as rmpr02703
(4538608 bytes) from Primary
Board ID : 00 MBRIDGE Revision : 21
916 MHz Power PC processor (version 8003/0101) 166 MHz bus
512 KB Boot Flash (AM29LV040B), 32 MB Code Flash (MT28F128J3)
2048 MB DRAM
Active Management uptime is 3 hours 25 seconds
SL M2: RX-BI-MR2 Management Module (High Value) Standby (Serial #: SA18071046, Part #: 35524-001C):
2048 MB DRAM
Standby Management uptime is 2 hours 59 minutes 42 seconds
SL 1: RX-BI-24C 24-port 1 GbE Copper Module (Serial #: SA04080474, Part #: 35521-003B)
Boot : Version 2.7.2fT155 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Mar 22 2010 at 23:08:06 labeled as rlb02702f
(306154 bytes) from boot flash
Monitor : Version 2.7.3T155 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Aug 30 2010 at 16:10:20 labeled as rlb02703
(307473 bytes) from code flash
IronWare : Version 2.7.3T157 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Aug 30 2010 at 16:19:52 labeled as rlp02703
(2333806 bytes) from Primary
FAP 1 version: 3
FAP 2 version: 3
FAP 3 version: 0
FAP 4 version: 0
660 MHz Power PC processor 440GP (version 8020/0020) 330 MHz bus
512 KB Boot Flash (AM29LV040B), 16 MB Code Flash (MT28F640J3)
512 MB DRAM, 8 KB SRAM, 0 Bytes BRAM
LP Slot 1 uptime is 2 hours 59 minutes 42 seconds
SL 2: RX-BI-24F 24-port 1 GbE Module (Serial #: SA09060532, Part #: 31520-102C)
Boot : Version 2.4.0eT155 Copyright © 1996-2010 Brocade Communications Systems, Inc.
Compiled on Jan 31 2008 at 14:55:32 labeled as rlb02400e
(249179 bytes) from boot flash
FAP 1 version: 2
FAP 2 version: 2
FAP 3 version: 0
FAP 4 version: 0
LP Slot 2 uptime is 2 hours 59 minutes 43 seconds
All show version done
И есть потребность на этой железке нарезать полосу жирным и не только клиентам по их vlan-id.
Но при попытке сконфигурить это в транковом порту, через который проходят пакеты с указанным vlan-id, наткнулись на вот такие грабли:
зашли на требуемый транковый порт и пытаемся организовать нарезку на входе от клиента
telnet@BigIron RX-4 Router(config-if-e1000-2/14)#rate-limit input vlan-id ?
DECIMAL VLAN ID
Это работает. Но при попытке сделать нарезку к клиенту получаем отлуп:
telnet@BigIron RX-4 Router(config-if-e1000-2/14)#rate-limit output ?
DECIMAL Average rate in bits/sec
Подскажите, плз, какие варианты возможны в данной ситуации для достижения озвученного ранее требования по нарезке клиенту в обе стороны, если речь идет о транковом порту.
Попутно хочу поинтересоваться, есть ли у HP на сайте софт под мою железку, и как она называется по версии HP.
Заранее всем спасибо.
