Есть PBI подключен в 6509 с sup2 пытаюсь настроить multicast routing в цепочке 6509 - ProCurve 6200 - NetIron, что-то ничего не выходит с NetIron, по моему он не знает маршрутов для групп. Хотя цепочка 6509 - ProCurve 6200 - 6509 прекрасно работает.
NetIron
vlan 900 смотрит на абонентов
telnet@NetIron#sh ver
SW: Version 09.4.00bT53 Copyright © 1996-2006 Foundry Networks, Inc.
Compiled on Apr 10 2008 at 11:34:53 labeled as N2P09400b
(2953956 bytes) from Flash card
HW: NetIron 800 Router, SYSIF version 21, Serial #: Non-exist
SL 1: B4GMR4 M4 Management Module, SYSIF 2, M4, ACTIVE
ip multicast-routing
ip multicast-perf
router pim
rp-address 10.17.0.1 25 override
spt-threshold 1000
vlan 125 by port
tagged ethe 2/1
router-interface ve 2
no spanning-tree
vlan 410 by port
tagged ethe 2/2
router-interface ve 3
no spanning-tree
vlan 900 by port
tagged ethe 6/1 to 6/2
router-interface ve 60
no spanning-tree
interface ve 2
ip address 192.168.255.137/30
ip pim-sparse
ip ospf area 0.0.0.0
ip ospf md5-authentication key-id 25 key 2 ==
ip ospf auth-change-wait-time 0
ip ospf mtu-ignore
interface ve 3
ip address 192.168.251.102/30
ip pim-sparse
ip ospf mtu-ignore
interface ve 60
ip address 10.17.0.254/30
ip pim-sparse
access-list 25 permit 239.255.0.0/22
После включения pim и ip multicast-perf ребутил.
HP 6200
ip routing
router pim
  rp-address 10.17.0.1 239.255.0.0 255.255.252.0 override
  exit
vlan 125
  ip ospf 192.168.255.138 area backbone
  ip ospf 192.168.255.138 md5-auth-key-chain "ospf"
  ip pim-sparse
     ip-addr any
     exit
  exit
vlan 410
  ip ospf 192.168.251.101 area backbone
  ip ospf  192.168.251.101 md5-auth-key-chain "ospf"
  ip pim-sparse
     ip-addr any
     exit
  exit
С нетайрона
telnet@NetIron#sh ip pim nbr
Total number of neighbors: 2 on 2 ports
Port Phy_p Neighbor Holdtime Age UpTime
sec sec sec
v2 e2/1 192.168.255.138 105 60 60
sec sec sec
v3 e2/2 192.168.251.101 105 0 0
Маршрут до источника
telnet@NetIron#sh ip pim rpf 192.168.253.18
upstream neighbor=192.168.251.101 on v3 using ip route
telnet@NetIron#sh ip pim mcache
Total 2 entries
(S G) in v40 (e2/3) cnt= : e2/3 is phy. of input v40, cnt: SW hit incl. drop
HW: CAM switched, SW: cpu switched, OAR: SW one-arm-routing, VL: vlan
trunking: TR(e3/3,e3/4): e3/3 is primary trunk port, e3/4 is real out p.
FLAGS: fast/slow: could be HW switched or not
pru: OIF (output-interface) empty, could send prune
frag: packet fragmented, SW forwarded unless multicast-perf configured
tag/tnl: OIF has tagged/tunnel ports
swL2/hwL2: SW or HW L2 forwarding
ag: send 1 pkt to cpu from HW switch to reset age
ClSr: has client on input port, never send prune when OIF empty
1 (* 239.255.1.1) RP 10.17.0.1, in v3, cnt=0
Sparse Mode, RPT=1 SPT=0 Reg=0
num_oifs = 1 (v60,e6/2)
L3 (SW) 1: tag e6/2(VL900)
fast=0 slow=1 pru=0 frag=0 tag=1 tnl=0 swL2=0 hwL2=0 OAR=0 ag=0 ClSr=0
age=0s up-time=0m no fid, no flow,
2 (* 239.255.1.2) RP 10.17.0.1, in v3, cnt=0
telnet@NetIron#sh ip mroute
Total number of Mroutes: 0
Id IP Address Subnet Mask RPF Address Port Distan
Идей у меня уже нет, может кто-то подскажет в какую сторону копать?
Edited by caz
включил netiron 1 линком в циску, все сразу заработало..
telnet@NetIron#mtraceroute source 10.17.0.1 group 239.255.1.1
Type Control-c to abort
Tracing the route for tree 10.17.0.1
1Mtrace Result Source 10.17.0.1 Group 239.255.1.1
- 192.168.255.137
0 192.168.255.137 Thresh 0
1 192.168.255.138 Thresh 0
2 10.17.0.1
Что не так с HP6200 я как-то слабо понимаю, ведь связка cisco - HP - cisco прекрасно работает...
