Подскажите в чем может быть дело.
Если терминация происходит на физическом интерфейсе
interface Gi4/0/0.8
description ONLY_FOR_TEST
encapsulation dot1Q 8
pppoe enable group testme
end
- То все работает,
если на портченале - не может согласовать IPCP, CCP - вываливается по timeout ppp (718 ошибка в виндовс)
interface Port-channel2.8
end
в чем может быть косяк?
Со стороны свича (4948)
description -- PPPoE_in
switchport
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 8
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/7(8)
logging event link-status
load-interval 30
speed 1000
duplex full
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
channel-group 2 mode on
W1#sh etherchannel load-balance
therChannel Load-Balancing Operational State (src-dst-ip):
on-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
W1#sh etherchannel detail
Ports in the group:
Port: Gi1/7
Port state = Up Mstr In-Bndl
Channel group = 2 Mode = On/FEC Gcchange = -
Port-channel = Po2 GC = - Pseudo port-channel = Po2
Port index = 0 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:05h:30m:43s
Port: Gi1/8
Port index = 1 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:05h:30m:40s
Port-channels in the group:
Port-channel: Po2
Age of the Port-channel = 06d:01h:33m:27s
Logical slot/port = 11/2 Number of ports = 2
GC = 0x00000000
Port state = Port-channel Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi1/7 On/FEC 0
1 00 Gi1/8 On/FEC 0
Time since last port bundled: 00d:05h:30m:49s Gi1/8
Time since last port Un-bundled: 00d:07h:15m:48s Gi1/8
W1#sh etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
2 Po2(SU) - Gi1/7(P) Gi1/8(P)
со стороны роутера
interface GigabitEthernet5(6)/0/0
no ip address
negotiation auto
channel-group 2 mode active
cdp enable
hold-queue 4096 in
hold-queue 4096 out
end
description DOWNLINK
no ip address
negotiation auto
lacp max-bundle 2
lacp fast-switchover
end
Port-channel2 is up, line protocol is up
Hardware is GEChannel, address is 0012.7f40.4078 (bia 0000.0000.0000)
Description: DOWNLINK
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
ARP type: ARPA, ARP Timeout 04:00:00
No. of active members in this channel: 2
Member 0 : GigabitEthernet5/0/0 , Full-duplex, 1000Mb/s
Member 1 : GigabitEthernet6/0/0 , Full-duplex, 1000Mb/s
No. of PF_JUMBO supported members in this channel : 0
Last input 00:00:05, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/8192/0/0 (size/max/drops/flushes); Total output drops: 0
Interface Port-channel2 queueing strategy: PXF Class-based
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
176564 packets input, 10798568 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
65611 packets output, 4536206 bytes, 0 underruns
bba-group pppoe testme
virtual-template 3
sessions per-mac limit 2
sessions per-vlan limit 65530
sessions per-mac throttle 10 60 180
sessions auto cleanup
interface Virtual-Template3
mtu 1492
ip unnumbered Loopback0
ip verify unicast reverse-path allow-self-ping
no ip redirects
no ip proxy-arp
ip tcp adjust-mss 1452
no logging event link-status
peer default ip address pool pppoe pppoe1 pppoe2 pppoe3 pppoe4 pppoe5
keepalive 15 3
ppp max-bad-auth 3
ppp mtu adaptive
ppp lcp predictive
ppp authentication ms-chap chap ms-chap-v2
ppp authorization pppoe
ppp accounting pppoe
ppp pap refuse
ppp ipcp dns X
ppp ipcp predictive
ppp ipcp address required
ppp timeout retry 3
ppp timeout authentication 45
ppp timeout idle 3600
Все верно, на GEC может быть только 1 активный линк для терминации PPPoE
Почитайте документик http://www.cisco.com/en/US/docs/routers/10...roadband/bb.pdf
так что не собирайте GEC на Downlink, проще раскидать vlanы по интерфейсам для балансировки нагрузки.
спасибо, почитаю
но вопрос остается открытым - даже если один линк в горячем резерве - и работает только по активному - почему авторизация проходит (обмер кадрами src-bras<->client ?) а дальше не идет? это так оно ограничивается со стороны циски что ли ?
Edited by 127.0.0.0/8
