Pronin Posted June 21, 2010 Posted June 21, 2010 Господа, может кто-то сталкивался с подобной проблемой или может направить на путь ее решения.. Есть роутер Linksys WRT55AG, который вроде как умеет PPPoE... Но при попытке приконнектиться к авторизатору ничего не выходит.. Логи mpd говорят следующее: Accepting PPPoE connection Link: OPEN event LCP: Open event LCP: state change Initial --> Starting LCP: LayerStart PPPoE: connection successful Link: UP event LCP: Up event LCP: state change Starting --> Req-Sent LCP: SendConfigReq #44 MRU 1492 MAGICNUM 8fd7f782 AUTHPROTO CHAP MSOFTv2 LCP: rec'd Configure Request #200 (Req-Sent) MRU 1492 LCP: SendConfigAck #200 MRU 1492 LCP: state change Req-Sent --> Ack-Sent LCP: rec'd Configure Ack #44 (Ack-Sent) MRU 1492 MAGICNUM 8fd7f782 AUTHPROTO CHAP MSOFTv2 LCP: state change Ack-Sent --> Opened LCP: auth: peer wants nothing, I want CHAP CHAP: sending CHALLENGE #1 len: 21 LCP: LayerUp rec'd proto IPCP during authenticate phase LCP: rec'd Protocol Reject #201 (Opened) LCP: protocol CHAP was rejected CHAP: sending CHALLENGE #2 len: 21 LCP: rec'd Protocol Reject #202 (Opened) LCP: protocol CHAP was rejected rec'd proto IPCP during authenticate phase CHAP: sending CHALLENGE #3 len: 21 LCP: rec'd Protocol Reject #203 (Opened) LCP: protocol CHAP was rejected rec'd proto IPCP during authenticate phase CHAP: sending CHALLENGE #4 len: 21 LCP: rec'd Protocol Reject #205 (Opened) LCP: protocol CHAP was rejected CHAP: sending CHALLENGE #5 len: 21 LCP: rec'd Protocol Reject #206 (Opened) LCP: protocol CHAP was rejected rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase rec'd proto IPCP during authenticate phase LCP: authorization timer expired LCP: authorization failed LCP: parameter negotiation failed LCP: state change Opened --> Stopping LCP: SendTerminateReq #42 LCP: LayerDown LCP: SendTerminateReq #43 PPPoE: connection closed Судя по всему mpd и роутер не могут договориться о протоколе авторизации. в mpd.conf следующее: pppoe_standart_link: set link no acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 60 180 set link max-redial -1 set link mtu 1492 set link enable incoming set link no multilink set link disable multilink девайс крутить бесполезно - логов у него нет, прошивка последняя.. может можно что-то покрутить в mpd? Вставить ник Quote
photon Posted June 22, 2010 Posted June 22, 2010 А у роутера разве нет каких-либо настроек по поводу поддержки CHAP? Вставить ник Quote
Pronin Posted June 22, 2010 Author Posted June 22, 2010 (edited) А у роутера разве нет каких-либо настроек по поводу поддержки CHAP? нет, ничего такого. все [три] настройки роутера, касающиеся pppoe уже были покручены и не принесли никаких результатов. теперь пытаемся зайти с обратной стороны - покрутить что-то в mpd... (исходим из теории, что раз linksys by cisco сделали именно такую имплементацию pppoe/chap в серийном устройстве, значит с кем-то/чем-то/какими-то_настройками_pppoe_сервера оно все-таки должно коннектится без применения плоскогубцев) меня лично смущают вот эти строки: CHAP: sending CHALLENGE #1 len: 21 LCP: LayerUp rec'd proto IPCP during authenticate phase LCP: rec'd Protocol Reject #201 (Opened) LCP: protocol CHAP was rejected т.е. сервер пытается предложить мини-роутеру авторизоваться по CHAP, на что тот говорит "нет" и пытается поднять IPCP .. возможно я что-то неправильно понимаю? Edited June 22, 2010 by Pronin Вставить ник Quote
