127.0.0.0/8 Опубликовано 19 мая, 2010 перезагружается? на ровном месте :/ с разной периодичностью (иногда пару раз в час) ... что можно сделать может выбрать другого мастера? обновить иос ? Switch Ports Model SW Version SW Image ------ ----- ----- ---------- ---------- 1 12 WS-C3750G-12S 12.2(35)SE2 C3750-IPBASEK9-M * 2 30 WS-C3750E-24TD 12.2(35)SE2 C3750E-UNIVERSALK9-M boot System image file is "flash:c3750e-universalk9-mz.122-35.SE2/c3750e-universalk9-mz.122-35.SE2.bin" C3750E-ATCXX#show platform stack-manager all Switch/Stack Mac Address : 001c.5891.1c80 H/W Current Switch# Role Mac Address Priority Version State ---------------------------------------------------------- 1 Member 000b.5f94.8f00 1 0 Ready *2 Master 001c.5891.1c80 2 1 Ready Stack Port Status Neighbors Switch# Port 1 Port 2 Port 1 Port 2 -------------------------------------------------------- 1 Ok Ok 2 2 2 Ok Ok 1 1 Stack Discovery Protocol View ============================================================== Switch Active Role Current Sequence Dirty Number State Number Bit -------------------------------------------------------------------- 1 TRUE Member Ready 078 FALSE 2 TRUE Master Ready 077 FALSE Stack State Machine View ============================================================== Switch Master/ Mac Address Version Current Number Member (maj.min) State ----------------------------------------------------------- 1 Member 000b.5f94.8f00 1.34 Ready 2 Master 001c.5891.1c80 1.34 Ready Last Conflict Parameters Switch Master/ Cfgd Default Image H/W # of Mac Address Number Member Prio Config Type Prio Members ----------------------------------------------------------------------- 1 Member 1 No 4 2 0 000b.5f94.8f00 2 Member 2 No 4 5 0 001c.5891.1c80 Stack Discovery Protocol Counters Messages Sent Messages Recvd UP DOWN UP DOWN -------------------------------------------------------- 1: 0000000382 0000000382 0000000742 0000000742 *2: 0000036200 0000036200 0000032525 0000032524 3: 0000000000 0000000000 0000000000 0000000000 4: 0000000000 0000000000 0000000000 0000000000 5: 0000000000 0000000000 0000000000 0000000000 6: 0000000000 0000000000 0000000000 0000000000 7: 0000000000 0000000000 0000000000 0000000000 8: 0000000000 0000000000 0000000000 0000000000 9: 0000000000 0000000000 0000000000 0000000000 Stack Changes: 54 Internal Stack Link changes: 0 Internal Stack Link state: 0x0 Sync Not OK Resets A: 21 B: 21 Misc Counters Counter Up Down --------------------------------------------------- Wrong Ver Number: Send: 0000000000 0000000000 Wrong Ver Number: Recv: 0000000000 0000000000 Missed Messages: 0000000000 0000000001 Orphaned Messages 0000000000 0000000000 Supressed Messages 0000003512 0000003512 No Available Messages 0000057936 0000057936 Link Present 0000000029 0000000029 Link Not Present 0000000028 0000000028 Link RxReset 0000000028 0000000028 RAC Not OK Resets: 0 Duplicates: 0000006431 0000006438 Switch Number of last duplicate: 1 Sequence Number Failures: 0000000000 Switch Number of last Failure: 256 Last Difference 0 Reciprocal Efficiency Changes: Upgrade 0 Downgrade 0 Switch Number Conflicts: 0 Resource Counters ------------------------------------------- Chunk Alloc's 0000000052 Chunk Free's 0000000051 Enqueue Failures: 0000000000 Null Queue Failures: 0000000001 Chunk Alloc Errors: 0000000000 Stack State Machine Counters Messages Sent Messages Recvd ------------------------------------------------- 1: 0000000005 0000000005 *2: 0000000001 0000000001 3: 0000000000 0000000000 4: 0000000000 0000000000 5: 0000000000 0000000000 6: 0000000000 0000000000 7: 0000000000 0000000000 8: 0000000000 0000000000 9: 0000000000 0000000000 =========config============== switch 1 provision ws-c3750g-12s switch 2 provision ws-c3750e-24td system mtu routing 1500 vtp mode transparent ip subnet-zero ip routing no ip domain-lookup ! login on-failure log login on-success log ! no mls qos rewrite ip dscp mls qos ! template 1/0/1 ! ! file prompt quiet no file verify auto ! ! spanning-tree mode pvst spanning-tree extend system-id no spanning-tree vlan 1-143,145-272,274-1000 ! ! vlan internal allocation policy ascending ! vlan 2-297 ! vlan 298 state suspend shutdown ! vlan 299-320 ! vlan 321 shutdown remote-span ! vlan 322-499 ! vlan 500-1000 shutdown ! ! class-map match-all INTERFACES-FOR-VLAN-190 match input-interface GigabitEthernet2/0/5 class-map match-all ANY match access-group 101 ! ! policy-map POLICY-FOR-INTERFACES-FOR-VLAN-190 class INTERFACES-FOR-VLAN-190 police 1024000 192000 exceed-action drop policy-map POLICY-FOR-VLAN-190 class ANY set dscp 7 service-policy POLICY-FOR-INTERFACES-FOR-VLAN-190 ! ! interface FastEthernet0 no ip address shutdown ! interface GigabitEthernet1/0/1 description CLIENT-A switchport trunk encapsulation dot1q switchport trunk native vlan 999 switchport trunk allowed vlan 101,143,342 switchport mode trunk switchport nonegotiate switchport block multicast ! interface GigabitEthernet1/0/2 description CLINENT-B switchport trunk encapsulation dot1q switchport trunk native vlan 999 switchport trunk allowed vlan 73,277,287 switchport mode trunk switchport nonegotiate switchport block multicast ! ! interface GigabitEthernet2/0/1 switchport trunk encapsulation dot1q switchport trunk allowed vlan 305 switchport mode trunk load-interval 30 spanning-tree bpdufilter enable ! interface GigabitEthernet2/0/2 switchport access vlan 30 switchport trunk encapsulation dot1q speed 10 ! interface GigabitEthernet2/0/3 switchport access vlan 400 switchport mode access ! interface GigabitEthernet2/0/4 switchport trunk encapsulation dot1q switchport trunk allowed vlan 1-189,191-400 switchport mode trunk ! interface GigabitEthernet2/0/5 switchport trunk encapsulation dot1q switchport trunk allowed vlan 147,184,190,248 switchport mode trunk load-interval 30 mls qos vlan-based spanning-tree bpdufilter enable ! interface GigabitEthernet2/0/6 switchport trunk encapsulation dot1q switchport trunk allowed vlan 1,30,38,39,50,61,73,80,89,90,101,173,1002-1005 switchport mode trunk speed 100 duplex full ! interface GigabitEthernet2/0/7 description Huawei switchport trunk encapsulation dot1q switchport trunk allowed vlan 1,10-12,30,31,36,38,39,43,50,63,70,71,73,80,83 switchport trunk allowed vlan add 85-87,89-91,96-98,101,107,117,125,136,141 switchport trunk allowed vlan add 143,148,173,178,198,203,204,207,209,210,214 switchport trunk allowed vlan add 220,223-229,235,241,242,247,248,250,252,254 switchport trunk allowed vlan add 257,260,274,288,299,304,307,310,323,402,414 switchport trunk allowed vlan add 465,467,488,493,1002-1005 switchport mode trunk load-interval 30 spanning-tree bpdufilter enable ! interface GigabitEthernet2/0/8 ! interface GigabitEthernet2/0/13 switchport trunk encapsulation dot1q switchport trunk allowed vlan 39,238,244,281,314,320,1002-1005 switchport mode trunk load-interval 30 no cdp enable spanning-tree bpdufilter enable ! interface GigabitEthernet2/0/14 ! interface GigabitEthernet2/0/15 ! interface GigabitEthernet2/0/16 switchport trunk encapsulation dot1q switchport trunk allowed vlan 30,38,80,90,91,98,220,224,250 switchport mode trunk load-interval 30 ! interface GigabitEthernet2/0/17 ! interface GigabitEthernet2/0/18 ! interface GigabitEthernet2/0/19 ! interface GigabitEthernet2/0/28 ! interface TenGigabitEthernet2/0/1 description UPLINK switchport trunk encapsulation dot1q switchport trunk native vlan 99 switchport trunk allowed vlan 1-320,322-4094 switchport mode trunk ! interface TenGigabitEthernet2/0/2 description DOWN switchport trunk encapsulation dot1q switchport trunk native vlan 99 switchport mode trunk ! interface Vlan1 no ip address shutdown ! interface Vlan99 ip address A.B.C.D 255.255.255.0 no ip redirects no ip proxy-arp arp timeout 270 ! interface Vlan190 no ip address service-policy input POLICY-FOR-VLAN-190 ! access-list 101 remark ANY access-list 101 permit ip any any ip default-gateway A.B.C.Z ip classless ip route 0.0.0.0 0.0.0.0 A.B.C.Z ip http server no ip http secure-server ! logging history debugging logging trap debugging logging facility local2 logging ZZZZZZ snmp-server community ZXCVB RO snmp-server enable traps license ================================== C3750E-ATCXX#sh sdm prefer The current template is "desktop vlan" template. The selected template optimizes the resources in the switch to support this level of features for 8 routed interfaces and 1024 VLANs. number of unicast mac addresses: 12K number of IPv4 IGMP groups + multicast routes: 1K number of IPv4 unicast routes: 0 number of IPv4 policy based routing aces: 0 number of IPv4/MAC qos aces: 0.5K number of IPv4/MAC security aces: 1K ---- C3750E-ATCXX#sh processes cpu sorted CPU utilization for five seconds: 22%/4%; one minute: 25%; five minutes: 25% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 183 231662439 423625672 546 10.38% 10.96% 10.73% 0 Spanning Tree 148 30392561 1696332 17916 1.43% 1.63% 1.65% 0 PI MATM Aging Pr 125 3898491 49426826 78 0.47% 0.19% 0.19% 0 Hulc LED Process 4 4348314 293343 14823 0.47% 0.22% 0.19% 0 Check heaps 76 1867827 1696411 1101 0.15% 0.17% 0.15% 0 HLFM aging proce 53 724002 37527229 19 0.15% 0.03% 0.00% 0 RedEarth Tx Mana 28 75655 1696538 44 0.15% 0.01% 0.00% 0 Dynamic ARP Insp 133 752299 347446 2165 0.15% 0.06% 0.02% 0 HQM Stack Proces 8 0 2 0 0.00% 0.00% 0.00% 0 License Client N 10 0 1 0 0.00% 0.00% 0.00% 0 Crash writer 9 29430 5799 5075 0.00% 0.00% 0.00% 0 Licensing Auto U 5 41 200 205 0.00% 0.00% 0.00% 0 Pool Manager 11 49325 288493 170 0.00% 0.00% 0.00% 0 ARP Input 14 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager 7 0 1 0 0.00% 0.00% 0.00% 0 Image Licensing 16 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage 6 0 2 0 0.00% 0.00% 0.00% 0 Timers 12 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT ---- по логам 2010/05/19 09:27:21.403 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN 2010/05/19 09:27:21.497 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN 2010/05/19 09:27:22.551 | %STACKMGR-4-SWITCH_REMOVED: Switch 1 has been REMOVED from the stack 2010/05/19 09:27:24.473 | %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down 2010/05/19 09:27:24.559 | %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to down 2010/05/19 09:27:24.677 | %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down 2010/05/19 09:27:24.770 | %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down 2010/05/19 09:28:19.917 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP 2010/05/19 09:28:20.002 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP 2010/05/19 09:28:47.138 | %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack 2010/05/19 09:28:49.183 | %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up 2010/05/19 09:28:49.245 | %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up 2010/05/19 09:29:00.996 | %STACKMGR-5-SWITCH_READY: Switch 1 is READY 2010/05/19 09:29:01.704 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP 2010/05/19 09:29:01.766 | %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state UP 2010/05/19 09:29:01.906 | %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack (Switch-1) 2010/05/19 09:29:02.045 | %STACKMGR-4-SWITCH_ADDED: Switch 2 has been ADDED to the stack (Switch-1) 2010/05/19 09:29:02.167 | %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan (Switch-1) 2010/05/19 09:29:02.231 | %SYS-6-CLOCKUPDATE: System clock has been updated from 0628:53 UTC Wed May 19 2010 to 0828:53 EET Wed May 19 2010, configured from console by console. (Switch-1) 2010/05/19 09:29:02.335 | %SYS-6-CLOCKUPDATE: System clock has been updated from 0828:53 EET Wed May 19 2010 to 0928:53 EDT Wed May 19 2010, configured from console by console. (Switch-1) 2010/05/19 09:29:02.481 | %SW_VLAN-4-BAD_STARTUP_VLAN_CONFIG_FILE: Failed to configure VLAN from startup-config. Fallback to use VLAN configuration file from non-volatile memory (Switch-1) 2010/05/19 09:29:02.724 | %SYS-5-CONFIG_I: Configured from memory by console (Switch-1) 2010/05/19 09:29:02.818 | %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down (Switch-1) 2010/05/19 09:29:02.922 | %STACKMGR-5-SWITCH_READY: Switch 2 is READY (Switch-1) 2010/05/19 09:29:03.038 | %STACKMGR-5-MASTER_READY: Master Switch 2 is READY (Switch-1) 2010/05/19 09:29:03.179 | %STACKMGR-5-SWITCH_READY: Switch 1 is READY (Switch-1) 2010/05/19 09:29:03.271 | %SYS-5-RESTART: System restarted -- (Switch-1) 2010/05/19 09:29:03.979 | %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down (C3750E-ATCXX) 2010/05/19 09:29:06.720 | %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up 2010/05/19 09:29:06.836 | %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up 2010/05/19 09:30:01.670 | %PLATFORM-1-CRASHED: System previously crashed with the following message: (C3750E-ATCXX) 2010/05/19 09:30:02.158 | %PLATFORM-1-CRASHED: Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(35)SE2, RELEASE SOFTWARE (fc1) (C3750E-ATCXX) 2010/05/19 09:30:02.872 | %PLATFORM-1-CRASHED: Copyright © 1986-2007 by Cisco Systems, Inc. (C3750E-ATCXX) 2010/05/19 09:30:03.019 | %PLATFORM-1-CRASHED: Compiled Tue 06-Feb-07 0507 by antonino (C3750E-ATCXX) 2010/05/19 09:30:03.178 | %PLATFORM-1-CRASHED: (C3750E-ATCXX) 2010/05/19 09:30:03.271 | %PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)! (C3750E-ATCXX) 2010/05/19 09:30:03.334 | %PLATFORM-1-CRASHED: (C3750E-ATCXX) 2010/05/19 09:30:03.484 | %PLATFORM-1-CRASHED: SRR0 = 0x006490F4 SRR1 = 0x00029210 SRR2 = 0x00647984 SRR3 = 0x00021000 (C3750E-ATCXX) 2010/05/19 09:30:03.564 | %PLATFORM-1-CRASHED: ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x10000000 (C3750E-ATCXX) 2010/05/19 09:30:03.737 | %PLATFORM-1-CRASHED: (C3750E-ATCXX) 2010/05/19 09:30:03.849 | %PLATFORM-1-CRASHED: CPU Register Context: (C3750E-ATCXX) 2010/05/19 09:30:03.944 | %PLATFORM-1-CRASHED: Vector = 0x00002000 PC = 0x0099D070 MSR = 0x00029210 CR = 0x30000005 (C3750E-ATCXX) 2010/05/19 09:30:04.055 | %PLATFORM-1-CRASHED: LR = 0x0099CF98 CTR = 0x002164A0 XER = 0xC0000063 (C3750E-ATCXX) 2010/05/19 09:30:04.146 | %PLATFORM-1-CRASHED: R0 = 0x00000000 R1 = 0x01E954F0 R2 = 0x00000000 R3 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.264 | %PLATFORM-1-CRASHED: R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x01E954C8 R7 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.358 | %PLATFORM-1-CRASHED: R8 = 0x00029210 R9 = 0x01820000 R10 = 0x01BA2DD8 R11 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.475 | %PLATFORM-1-CRASHED: R12 = 0x0000001B R13 = 0x00110000 R14 = 0x00FB9D00 R15 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.593 | %PLATFORM-1-CRASHED: R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.757 | %PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000 (C3750E-ATCXX) 2010/05/19 09:30:04.850 | %PLATFORM-1-CRASHED: R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00988828 R27 = 0x01CE1B10 (C3750E-ATCXX) 2010/05/19 09:30:04.967 | %PLATFORM-1-CRASHED: R28 = 0x00000000 R29 = 0x0165B8D4 R30 = 0x00000000 R31 = 0x07BD3784 (C3750E-ATCXX) 2010/05/19 09:30:05.082 | %PLATFORM-1-CRASHED: (C3750E-ATCXX) 2010/05/19 09:30:05.228 | %PLATFORM-1-CRASHED: Stack trace: (C3750E-ATCXX) 2010/05/19 09:30:05.291 | %PLATFORM-1-CRASHED: PC = 0x0099D070, SP = 0x01E954F0 (C3750E-ATCXX) 2010/05/19 09:30:05.430 | %PLATFORM-1-CRASHED: Frame 00: SP = 0x01E95500 PC = 0x0099CF70 (C3750E-ATCXX) 2010/05/19 09:30:05.525 | %PLATFORM-1-CRASHED: Frame 01: SP = 0x01E95520 PC = 0x00FB6F30 (C3750E-ATCXX) 2010/05/19 09:30:05.696 | %PLATFORM-1-CRASHED: Frame 02: SP = 0x01E95548 PC = 0x00FB7A64 (C3750E-ATCXX) 2010/05/19 09:30:05.807 | %PLATFORM-1-CRASHED: Frame 03: SP = 0x01E95560 PC = 0x00FB9B94 (C3750E-ATCXX) 2010/05/19 09:30:06.005 | %PLATFORM-1-CRASHED: Frame 04: SP = 0x01E95578 PC = 0x00FB9DBC (C3750E-ATCXX) 2010/05/19 09:30:06.120 | %PLATFORM-1-CRASHED: Frame 05: SP = 0x01E95580 PC = 0x0099EE18 (C3750E-ATCXX) 2010/05/19 09:30:06.238 | %PLATFORM-1-CRASHED: Frame 06: SP = 0x00000000 PC = 0x00996404 (C3750E-ATCXX) 2010/05/19 09:30:06.378 | %PLATFORM-1-CRASHED: (C3750E-ATCXX) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
