Продаю Cisco 7204VXR - полностью готовый к работе, в отличном состоянии.
В составе:
Шасси Cisco 7204VXR - 1шт.
Модуль NPE-G1 512MB RAM - 1шт.
PA-2FE-TX - 2шт.
Блок питания - 1шт.
Интерфейсы:
3 комба порта:
-3 x 1000BaseT RJ 45
-3 x GBIC 1000BaseX
4 x FastEthernet
Цена за все: 7000$
Наличный/Безналичный расчет.
Гарантия 1ГОД!!!
Доставка в регионы РФ.
NG-IT, Юрий
corp@ng-it.ru
сот. +7-914-707-49-78
ICQ 31400821
sh ver
Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(8), RELEASE SOFT
WARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2006 by Cisco Systems, Inc.
Compiled Mon 15-May-06 20:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System returned to ROM by power-on
System image file is "bootflash:c7200-kboot-mz.124-8.bin"
Cisco 7204VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memor
y.
Processor board ID 34870785
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 400 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
4 FastEthernet interfaces
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2142
Router(boot)#sh diag
Slot 1:
Dual Port FastEthernet (RJ45) Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:01:28 ago
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
PCB Serial Number : JAE1008W5V2
Part Number : 73-5419-07
Board Revision : A0
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : PA-2FE-TX
Top Assy. Part Number : 800-08350-07
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 24 41 01 01 C1 8B 4A 41 45 31 30 30
0x10: 38 57 35 56 32 82 49 15 2B 07 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 50 41 2D
0x30: 32 46 45 2D 54 58 20 20 20 20 20 20 20 20 20 20
0x40: 20 C0 46 03 20 00 20 9E 07 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 2:
Port adapter insertion time 00:01:45 ago
PCB Serial Number : JAE1007W22F
Board Revision : A0
RMA History : 00
0x10: 37 57 32 32 46 82 49 15 2B 07 42 41 30 03 00 81
