Здравствуйте!
Настраивал связку mikrotik+UTM для HotSpot по статье http://netup.ru/articles.php?n=4
Версия NetUP - 5.2.1-006
Версия mikrotik OS - 3.20
Не могу авторизоваться через utm_radius.
В Debug получаю:
?Debug : Mar 01 14:37:51 RadiusSocket: RADIUS packet successfully received
?Debug : Mar 01 14:37:51 RadiusSocket: RADIUS raw data obtained
?Debug : Mar 01 14:37:51 RADIUS Packet: Size <196>; HDR.Size <196>
?Debug : Mar 01 14:37:51 AuthServer: Recv...
?Debug : Mar 01 14:37:51 AuthServer: Packet from NAS <192.168.88.2>
?Debug : Mar 01 14:37:51 RADIUS DBA: NAS found. Data size <0>
?Debug : Mar 01 14:37:51 AuthServer: Packet from <192.168.88.2> packet dump: RPacket:
Code: 1; ID: 48
<Vendor: 0; Attr: 1>[4]: 37393831
<Vendor: 0; Attr: 3>[17]: 19f7e4903f5e7c10835cca6d473c41a75f
<Vendor: 0; Attr: 4>[4]: c0a86815
<Vendor: 0; Attr: 5>[4]: 80100032
<Vendor: 0; Attr: 6>[4]: 00000001
<Vendor: 0; Attr: 8>[4]: c0a801fe
<Vendor: 0; Attr: 30>[8]: 686f7473706f7431
<Vendor: 0; Attr: 31>[17]: 30303a34303a34353a32423a36353a3334
<Vendor: 0; Attr: 32>[8]: 4d696b726f54696b
<Vendor: 0; Attr: 44>[8]: 3830313030303332
<Vendor: 0; Attr: 60>[16]: 552691fc1fa82f6c5389bc3e9c85f508
<Vendor: 0; Attr: 61>[4]: 00000011
<Vendor: 0; Attr: 87>[7]: 686f7473706f74
<Vendor: 14122; Attr: 3>[25]: 687474703a2f2f3139322e3136382e312e312f6c6f676f7574
<Vendor: 14988; Attr: 10>[4]: c0a801fe
?Debug : Mar 01 14:37:51 AuthServer: User <7981> connecting
?Debug : Mar 01 14:37:51 AuthServer: Session for sessionid <7981> not found in <192.168.88.2> cache
ERROR : Mar 01 14:37:51 RADIUS DBA: Can't find login <7981>
?Debug : Mar 01 14:37:51 RADIUS DBA: Searching card login <000007981>
ERROR : Mar 01 14:37:51 RADIUS DBA: Can't find card login <000007981>
?Debug : Mar 01 14:37:51 AuthServer: Attempt to add new Card user: <7981>
?Debug : Mar 01 14:37:51 AuthServer: CHAP Autoadd: Challenge size: 16
?Debug : Mar 01 14:37:51 RADIUS DBA: Sending Auto-Add Request for Card-ID: 7981
?Debug : Mar 01 14:37:51 RADIUS Stream[plugin]: Got User-Autoadd id <-13> (CHAP)
?Debug : Mar 01 14:37:51 AuthServer: Got AutoAdd -13 UID from core.
ERROR : Mar 01 14:37:51 AuthServer: No data for User <7981> found.
?Debug : Mar 01 14:37:51 AuthServer: Auth reply: RPacket:
Code: 3; ID: 48
<Vendor: 0; Attr: 18>[21]: 417574686f72697a6174696f6e206661696c65642e
<Vendor: 9; Attr: 103>[19]: 683332332d72657475726e2d636f64653d2d31
?Debug : Mar 01 14:37:51 RADIUS Packet: raw data constructed! size <70>
?Debug : Mar 01 14:37:51 RadiusSocket: Moving RADIUS packet into send queue
?Debug : Mar 01 14:37:51 RadiusSocket: RADIUS raw data sent
?Debug : Mar 01 14:37:51 AuthServer: Next...
?Trace : Mar 01 14:37:51 AuthServer: Process loop step
?Debug : Mar 01 14:37:51 RadiusSocket: Waiting for RADIUS raw data
В log-файле "radius_main":
ERROR : Mar 01 14:38:58 RADIUS DBA: Can't find login <7981>
ERROR : Mar 01 14:38:58 RADIUS DBA: Can't find card login <000007981>
ERROR : Mar 01 14:38:58 AuthServer: No data for User <7981> found.
Пользователь есть точно. NAS, как видно из логов определяется.
К сожалению, поиск по форуме результатов не принёс.
Спасибо.
  • 5 weeks later...
"чудесный" netup заработал после 5-ой перезагрузки сервера. почти "чудо".
будет возможность - купим другой биллинг.
