semnik Posted March 12, 2024 Posted March 12, 2024 (edited) Проблема такая что когда клиент запрашивает ip один покет проходит широковещательный, а второй проходит от reley агента, кто встречал такое, подскажите как боролись, или проблема в настройках. !version 10.3.0D build 120603 service timestamps log date service timestamps debug date logging buffered 100000 ! mirror session 1 destination interface g0/2 mirror session 1 source interface g0/1 both ! port-protected 1 ! ! ! ! lldp run ! ! ! spanning-tree mode rstp ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! aaa authentication login default local aaa authentication enable default none aaa authorization exec default local ! username admin password 0 admin ! ! ! ! ! gpon profile onu-rate-limit ratelimit-default id 1 gpon-profile pir 1244160 cir 1244160 ! gpon profile onu-uni MTU id 2 gpon-profile max-frame-size 1550 ! gpon profile onu-tcont tcont-default id 1 gpon-profile tcont-type 4 pir 102400 ! gpon profile onu-virtual-port virtual-port-default id 1 gpon-profile encryption disable gpon-profile upstream queue 8 gpon-profile downstream queue 8 ! gpon profile onu-tcont-virtual-port-bind tvbind-default id 1 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default ! gpon profile onu-flow-mapping flow-mapping-default id 1 gpon-profile entry 1 uni type eth-uni all gpon-profile entry 1 virtual-port 1 ! gpon profile onu-flow-mapping flow-mapping-default-hgu id 2 gpon-profile entry 1 uni type veip all gpon-profile entry 1 virtual-port 1 ! gpon profile onu-flow-mapping vlan7 id 3 gpon-profile entry 1 uni type eth-uni all gpon-profile entry 1 vlan 700 gpon-profile entry 1 virtual-port 1 ! gpon profile onu-vlan vlav7 id 3 gpon-profile vlan mode tag gpon-profile vlan pvid 700 0 ! gpon profile onu-vlan teg_vlan7 id 4 gpon-profile vlan mode trunk gpon-profile vlan pvid 700 0 gpon-profile vlan trunk vlan-allowed 247 ! ! gpon onutype-template onutype-default-hgu gpon-onutype match ctc-onu-type HGU gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default-hgu ! gpon onutype-template onutype-default gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default ! gpon onu-config-template int cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tvbind-default cmd-sequence 002 gpon onu flow-mapping-profile vlan7 cmd-sequence 003 gpon onu uni 1 vlan-profile teg_vlan7 cmd-sequence 004 gpon onu uni 1 uni-profile MTU ! ! interface Null0 ! interface GigaEthernet0/0 ip address 192.168.0.1 255.255.255.0 ! !!slot 0 1 GP3600-08B mother card interface GigaEthernet0/1 description uplink switchport trunk vlan-allowed 700,1000 switchport mode dot1q-tunnel-uplink dhcp snooping trust ip-source trust storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ip access-group test ! ! interface GPON0/1 gpon onu-authen-method sn gpon pre-config-template int bind-onuid 1-128 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 filter dhcp switchport trunk vlan-allowed 247,700 switchport trunk vlan-untagged none switchport mode trunk switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 ip access-group test ! ! !!slot end ! interface VLAN700 ip address 192.168.7.2 255.255.255.0 no ip directed-broadcast ip helper-address 192.168.1.9 ! interface VLAN1000 ip address 172.16.20.253 255.255.252.0 no ip directed-broadcast ! ! ! vlan 700 name vlan7 ! vlan 1000 name manage ! vlan 1,700,1000 ! ! ! ! ip dhcpd enable ! ip dhcp-relay snooping ip dhcp-relay snooping vlan 247,700,1000 ! ! ! ! ! ! ! ip route default 172.16.20.1 ip exf ! ipv6 exf ! ip telnet attack-defense ! ip http server ! ! snmp-server community 0 nmscloud RW ! ! ! ! !Pending configurations for absent linecards: ! !No configurations pending global Edited March 12, 2024 by semnik Вставить ник Quote
