Users Posted October 26, 2023 Posted October 26, 2023 (edited) Не грузится. Подозрение на то, что вышли из строя флешки. Ставил их на матеренку тоже не определятюся. Как определить что 100% проблема в них ? U-Boot 1.1.6 (Feb 3 2010 - 11:57:02) CPU: 8572, Version: 2.1, (0x80e00021) Core0: E500, Version: 3.0, (0x80210030) Clock Configuration: CPU0:1333 MHz, CPU1:1333 MHz, CCB: 533 MHz, DDR: 267 MHz (533 MT/s data rate) (Synchronous), LBC: 33 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: MX80 1.9 CPLD: Version 0x1d DRAM: Initializing - DDR: 2048 MB Testing DRAM from 0x00000000 to 0x80000000 DRAM test phase 1: DRAM test phase 2: DRAM test passed. Now running in RAM - U-Boot at: 0ffa0000 Enable CPLD Watchdog POST: U-boot memory location PASSED Scaning PCIE bus: Scanning PCI Express` Bus .. for bus 0 Found(0.0.0), (0x1957,0x41) Class(0xb20) :MPC8572 PCIE Controller BAR0 = 0xc0000000 Scanning PCI Express` Bus .. for bus 1 Found(1.0.0), (0x10b5,0x8112) Class(0x604) :PEX8112 PCIe-to-PCI Bridge BAR0 = 0xc0100000 BAR1 = 0x0 Scanning PCI Express` Bus .. for bus 2 Found(2.1.0), (0x1033,0x35) Class(0xc03) :uPD720101/2 USB(OHCI) Controller BAR0 = 0xc0200000 Found(2.1.1), (0x1033,0xe0) Class(0xc03) :uPD720101/2 USB(EHCI) Controller BAR0 = 0xc0201000 ----------- PCIE scan complete, last bus = 2 ------------ FLASH: 8 MB L2 cache 1MB: enabled In: serial Out: serial Err: serial USB: scanning bus for devices... 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found Net: fxp0: PHY is Marvell 88E1112S (1410c97) me0, em0, fxp0 [PRIME], em1 ELF file is 32 bit Loading .text @ 0x00010080 (176156 bytes) Loading .rodata @ 0x0003b09c (14008 bytes) Loading .rodata.str1.4 @ 0x0003e754 (15716 bytes) Loading set_Xcommand_set @ 0x000424b8 (88 bytes) Loading .rodata.cst4 @ 0x00042510 (12 bytes) Loading .data @ 0x00043000 (13896 bytes) Loading .sdata @ 0x00046648 (80 bytes) Clearing .sbss @ 0x00046698 (264 bytes) Clearing .bss @ 0x000467a0 (9232 bytes) ## Starting application at 0x00010080 ... Consoles: U-Boot console Will try to boot from USB nand-flash0 nand-flash1 FreeBSD/PowerPC U-Boot bootstrap loader, Revision 2.2 (vaidyasd@svl-junos-pool69.juniper.net, Wed Feb 3 09:50:07 PST 2010) Memory: 2048MB can't load '/kernel' can't load '/kernel.old' Type '?' for a list of commands, 'help' for more detailed help. loader> Edited October 26, 2023 by Users Вставить ник Quote
