Всем привет, настраиваю плату ETGO  на zte c320 , ону епон не берет мой конфиг, сталкивался кто то с таким? ниже конфиг
sdisk disable
set-pnp disable
add-rack rackno 1 racktype C320Rack
add-shelf rackno 1 shelfno 1 shelftype C320_SHELF
add-subcard rackno 1 shelfno 1 slotno 4 subcardno 1 UCDC/3
add-card rackno 1 shelfno 1 slotno 1 ETGO
add-card rackno 1 shelfno 1 slotno 2 GTGH
system-monitor watchdog rackno 1 shelfno 1 slotno 1 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 1 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 1 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 1 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 1 all
system-monitor watchdog rackno 1 shelfno 1 slotno 3 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 3 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 3 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 3 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 3 all
system-monitor watchdog rackno 1 shelfno 1 slotno 4 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 4 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 4 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 4 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 4 all
system-monitor watchdog rackno 1 shelfno 1 slotno 2 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 2 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 2 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 2 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 2 all
system-monitor inner-port-check disable
his-performance sample enable
his-performance alarm enable
his-performance auto-upload disable
clock
ptp
security port-protect enable
eth-switch max-frame-length  9600
vlan database
  vlan 1,20,102,221
vlan 102
  name mgmt
vlan-smart-qinq enable
epon
  auto-dispatch-set EPON enable
  onu-sla-profile profile-name create standart
  onu-sla-profile profile-set standart upstream fixed 0 fixedpkt 64 assured 15000 maximum 1000000 maxburst 45000 priority 0
  onu-sla-profile profile-set standart downstream maximum 1000000
  onu-uni-profile profile-name create EPON
port-location access-node-identifier inband-mac
port-location flexible-syntax enable
port-location flexible-syntax add delimiter space
port-location flexible-syntax add string biryusinka
port-location flexible-syntax add variable slot
port-location flexible-syntax add variable port
port-location flexible-syntax add variable onu-id
dhcp-option82 disable
dhcp6-option18 disable
pppoe-plus disable
ndp-lio disable
igmp  enable
mld  disable
gpon
  profile tcont DBA_1000MB type 4 maximum 1024000
  profile tcont UP-1000Mb type 4 maximum 1024000
  profile tcont UP-100MB type 4 maximum 104000
  profile tcont 1000mb type 4 maximum 1024000
  profile traffic DOWN-1000Mb sir 1024000 pir 1024000
  profile traffic DOWN-100MB sir 104000 pir 108000
gpon
pon
  onu-type EPON epon description eth_0/1
  onu-type ONT_1G gpon description 1eth_1pon
  onu-type ZTE-F660 gpon description 4eth,2pots,wifi
  onu-type ZTE-F660-WIFI gpon description 4ETH,2POTS,WIFI
  onu-type-if EPON eth_0/1
  onu-type-if ONT_1G eth_0/1
  onu-type-if ZTE-F660 eth_0/1
  onu-type-if ZTE-F660 eth_0/2
  onu-type-if ZTE-F660 eth_0/3
  onu-type-if ZTE-F660 eth_0/4
  onu-type-if ZTE-F660 pots_0/1
  onu-type-if ZTE-F660 pots_0/2
  onu-type-if ZTE-F660 wifi_0/1
  onu-type-if ZTE-F660 wifi_0/2
  onu-type-if ZTE-F660 wifi_0/3
  onu-type-if ZTE-F660 wifi_0/4
  onu-type-if ZTE-F660-WIFI eth_0/1
  onu-type-if ZTE-F660-WIFI eth_0/2
  onu-type-if ZTE-F660-WIFI eth_0/3
  onu-type-if ZTE-F660-WIFI eth_0/4
  onu-type-if ZTE-F660-WIFI pots_0/1
  onu-type-if ZTE-F660-WIFI pots_0/2
  onu-type-if ZTE-F660-WIFI wifi_0/1
  onu-type-if ZTE-F660-WIFI wifi_0/2
  onu-type-if ZTE-F660-WIFI wifi_0/3
  onu-type-if ZTE-F660-WIFI wifi_0/4
  uncfg-onu-display-info model sn pw
onu-profile gpon line 1000mb
  fec upstream
  tcont 1 name T-INET profile UP-1000Mb
  gemport 1 name G-INET unicast tcont 1 dir both
  gemport 1 traffic-limit downstream DOWN-1000Mb
pon
onu-pnp
epon sla-profile standart
  onu-vlan epon-olt_1/1/1 mode transparent
  onu-vlan epon-olt_1/1/2 mode transparent
  onu-vlan epon-olt_1/1/3 mode transparent
  onu-vlan epon-olt_1/1/4 mode transparent
  onu-vlan epon-olt_1/1/5 mode transparent
  onu-vlan epon-olt_1/1/6 mode transparent
  onu-vlan epon-olt_1/1/7 mode transparent
  onu-vlan epon-olt_1/1/8 mode transparent
  enable epon-olt_1/1/1
   enable epon-olt_1/1/2
   enable epon-olt_1/1/3
   enable epon-olt_1/1/4
   enable epon-olt_1/1/5
   enable epon-olt_1/1/6
   enable epon-olt_1/1/7
   enable epon-olt_1/1/8
При таком конфиге ону регистрируется вот так
interface epon-olt_1/1/1
  p2p mode group
  auto-learning enable
  onu 1 type universalOnuType mac e0e8.e6f2.29c8 ip-cfg static
interface epon-onu_1/1/1:1
  admin enable
  ems-autocfg-request disable
  encrypt direction downstream  enable  vport 1
  switchport mode hybrid vport 1
pon-onu-mng epon-onu_1/1/1:1
auto-config
Может кто сталкивался или есть работающий конфиг для епон для этого шасси?
