waspagv Posted March 17, 2022 Posted March 17, 2022 Добрый день! Впервые пробуем ASR 9006 в качестве BNG. Настраиваю подключение по технологии IPoE. Пока не касался создания сессий, авторизации и пр. Нужно выдать клиенту адрес со стороннего DHCP-сервера. Не работает с Ambiguous VLAN interface. По порядку. DHCP Proxy настроен так: dhcp ipv4 vrf main proxy profile IPoE_DHCP profile IPoE_DHCP proxy helper-address vrf main 192.168.2.228 giaddr 192.168.2.55 lease proxy client-lease-time 300 broadcast-flag policy unicast-always relay information policy keep relay information option allow-untrusted ! interface Bundle-Ether19.3333 proxy profile IPoE_DHCP ! Сабинтерфейс: interface Bundle-Ether19.3333 vrf main ipv4 address 10.0.1.3 255.255.255.0 arp learning disable ipsubscriber ipv4 l2-connected initiator dhcp initiator unclassified-source ! encapsulation ambiguous dot1q 3333 second-dot1q 1405-1420 При поступлении DHCP-пакета DISCOVER от клиента вижу в отладке RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP1955: FSM called for chaddr 201a.0676.00ff with event PACKET_DISCOVER state INIT RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP1903: Process packet event in INIT state called for chaddr 201a.0676.00ff RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP1955: FSM called for chaddr 201a.0676.00ff with event DPM_SUCCESS state INIT_DPM_WAIT RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP2739: Dropping DISCOVER for 201a.0676.00ff received on ambiguous VLAN interface for standalone proxy RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP3647: FSM call returned error for chaddr_string: 201a.0676.00ff, msg_type:1, mode: 4, event: 27 RP/0/RSP0/CPU0:Mar 17 19:45:01.696 SAMST: dhcpd[1097]: DHCPD PROXY: TP1665: Proxy process client request packet failed for chaddr 201a.0676.00ff Ключевое здесь, как мне кажется, вот это: Dropping DISCOVER for 201a.0676.00ff received on ambiguous VLAN interface for standalone proxy Если исключить на интерфейсе всякое ambiguous, записать так encapsulation dot1q 3333 second-dot1q 1420 то DHCP-запрос прекрасно транслируется на сервер, клиент получает адрес. На данном форуме нашел сходную ситуацию, где ambiguous не мешал: Но там сервер был локальным. Собственно, в чем тут проблема? Вставить ник Quote
waspagv Posted March 18, 2022 Author Posted March 18, 2022 Проверил вариант с сервером DHCP вместо прокси. Совершенно аналогичная ошибка. Что-то у меня не так, по сравнению с теми, у которых получилось. Не могу понять, что именно. Вставить ник Quote
BurtW Posted March 19, 2022 Posted March 19, 2022 Добрый вечер. А почему вы для установки сессии используете initiator dhcp и unclassified source? Как бы они имеют разные механизмы работы. Вставить ник Quote
waspagv Posted March 21, 2022 Author Posted March 21, 2022 В 20.03.2022 в 02:07, BurtW сказал: Добрый вечер. А почему вы для установки сессии используете initiator dhcp и unclassified source? Как бы они имеют разные механизмы работы. До сессии дело даже не дошло. Я уже исправил этот косяк, теперь так: interface Bundle-Ether19.3333 vrf main ipv4 point-to-point ipv4 unnumbered Loopback50 arp learning disable ipsubscriber ipv4 l2-connected initiator dhcp ! encapsulation ambiguous dot1q 3333 second-dot1q 1405-1420 ! Поведение совершенно аналогично описанному: на ambiguous VLAN не работает с той же отладкой. Вставить ник Quote
