здравствуйте.
подскажите, где можно слить мануалы на BCM CLI.
вижу что он используется в куче оборудования, даже в той-же циске.
но с документацией - как-то глухо.
из того что нашел
97809-SMB-QSG104-RDS.pdf
BCM CLI Quick Start Guide 1.1(BCM diagnostic shell).pdf
StrataXGS-AN300-RDSStrataXGS BCM Diag Shell Overview.pdf
и несколько sdk-xgs-robo-* но там пусто
примерный вид CLI под катом.
Скрытый текст
base>ver
Broadcom Command Monitor: Copyright (c) 1998-2010 Broadcom Corporation
Release: sdk-5.10.3 built 20121121 (Wed Nov 21 11:02:36 2012)
base>show unit
Unit 0 chip BCM56800_A0
Unit 1 chip BCM56504_B2 (current)
base>0:
fabric>ps
           ena/  speed/ link auto    STP                  lrn  inter   max  loop
      port link  duplex scan neg?   state   pause  discrd ops   face frame  back
       xe0  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe1  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe2  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe3  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe4  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe5  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe6  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe7  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe8  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
       xe9  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe10  up    10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe11  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe12  up    10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe13  down  10G FD   SW  No   Forward  TX RX   None   FA  XGMII  1518
      xe14  down  10G FD   SW  No   Forward  TX RX   None   FA  XGMII  1518
      xe15  down  10G FD   SW  No   Forward  TX RX   None   FA  XGMII  1518
      xe16  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe17  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe18  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
      xe19  down  10G FD   HW  No   Forward  TX RX   None   FA  XGMII  1518
fabric>1:
base>ps
       ge0  !ena   1G FD   SW  Yes  Forward  TX RX   None   FA   GMII  1500
       ge1  up   100M FD   HW  No   Forward  TX RX   None   FA  SGMII  1518
       ge2  down 100M FD   HW  No   Forward  TX RX   None   FA  SGMII  1518
       ge3  !ena   1G FD   SW  Yes  Forward  TX RX   None   FA   GMII  1500
       ge4  !ena   1G FD   HW  Yes  Forward  TX RX   None   FA   GMII  1518
       ge5  !ena   1G FD   HW  Yes  Forward  TX RX   None   FA   GMII  1518
       ge6  down   1G FD   HW  Yes  Forward  TX RX   None   FA   GMII  1518
       ge7  up     1G FD   HW  Yes  Forward  TX RX   None   FA   GMII  1518
       ge8  !ena   1G FD   SW  Yes  Forward  TX RX   None   FA   GMII  1500
       ge9  !ena   1G FD   SW  Yes  Forward  TX RX   None   FA   GMII  1500
      ge10  !ena    -      SW  Yes  Forward  TX RX   None   FA  SGMII  1500
      ge11  up     1G FD   HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge12  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge13  up     1G FD   HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge14  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge15  up     1G FD   HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge16  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge17  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge18  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge19  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge20  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge21  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge22  up     1G FD   HW  Yes  Forward  TX RX   None   FA  SGMII  1518
      ge23  down    -      HW  Yes  Forward  TX RX   None   FA  SGMII  1518
       xe0  up    10G FD   HW  No   Forward          None   FA  XGMII  1518
       xe1  !ena  10G FD   SW  No   Forward          None   FA  XGMII  1500
       xe2  down  10G FD   SW  No   Forward  TX RX   None   FA  XGMII  1518
       xe3  !ena  10G FD   SW  No   Forward          None   FA  XGMII  1500
base>show features
Unit 1 features:
        arl_hashed
        arl_insert_ovr
        cfap_pool
        cos_rx_dma
        dcb_type13
        fe_gig_macs
        trimac
        ingress_metering
        egress_metering
        l3
        l3_ip6
base>?
help: "??" or "help" for summary
Commands common to all modes:
?              ??             ASSert         BackGround     BCM
BCMX           break          CASE           CD             cint
CONFig         CONSole        CoPy           CPUDB          CTEcho
CTInstall      CTSetup        DATE           DBDump         DBParse
DeBug          DeBugMod       DELAY          DEVice         DIR
DISPatch       Echo           EDline         EXIT           EXPR
FLASHINIT      FLASHSYNC      FOR            Help           HISTory
IF             JOBS           KILL           LOCal          LOG
LOOP           LS             MKDIR          MODE           MORe
MoVe           NOEcho         Pause          PRINTENV       PWD
QUIT           RCCache        RCLoad         REBOOT         REName
RESET          RM             RMDIR          RPC            SAVE
SET            SETENV         SHell          SLeep          TIME
Version
Commands for current mode:
ADC            AGE            Attach         Auth           BaseBoard
BFD            BIST           BPDU           BTiMeout       BUFfer
CABLEdiag      CACHE          CellDataTest   CellHDR        CES
CHecK          CLEAR          CLOCKS         COLOR          COMBO
COS            CounTeR        CustomSTAT     DAC            DDRMemRead
DDRMemWrite    DDRPhyRead     DDRPhyTune     DDRPhyWrite    DELete
DETach         DMA            DmaRomTest     DMIRror        DMux
DPLL           DSCP           DTAG           Dump           EditReg
EGRess         EthernetAV     EXTernalTuning EXTernalTuning2EXTernalTuningSum
FieldProcessor Filter         Getreg         GlobalMeter    GPORT
H2HIGIG        H2HIGIG2       HASH           HClksel        HeaderMode
I2C            IBDump         INIT           Insert         INTR
IPFIX          IPG            IPMC           L2             L2MODE
L3             LCDMSG         LED            LINKscan       LISTmem
Listreg        LOOKup         MCAST          MCSDump        MCSLoad
MCSMsg         MemSCAN        MemWatch       MIM            MIRror
MmuConFiG      MODify         ModMap         Modreg         MPLS
MPLSER         MSPI           MTiMeout       MultiCast      MUXsel
NVram          OAM            PacketWatcher  PBMP           PCIE
PHY            POE            POESel         POP            PORT
PortPolicer    PortRate       PortSampRate   PortStat       PPDclk
PROBE          PTP            PUSH           PUTREG         PVlan
QDR            RATE           RateBw         RegCMp         REMove
RXCfg          RXInit         RXMon          SCHan          SEArch
Setreg         SFP            SFPIO          SFPMUX         SFPLED
SHOW           SOC            SRAM           STACKMode      StackPortCb
StackPortGet   StackPortSet   STG            STiMeout       STKMode
StkTask        SwitchControl  SYnth          SystemSnake    TCAM
TEMPerature    TestClear      TestList       TestMode       TestParameters
TestRun        TestSelect     TRUNK          TrunkPool      TX
TXBeacon       TXCount        TXSTArt        TXSTOp         VLAN
WARMBOOT       WLAN           Write          XAUI           XClocks
XPoe           XQDump         XQErr
  • 2 years later...
это было телеком оборудование в ATCA корзине, Люсент, Алкатель-Люсент, теперь Нокия.
локальный саппорт утверждал что это часть системы, и документации на него нет.
но удалось достать мануал на оборудование у оператора с другой страны,
и BCM CLI стал не актуален.
тут где-то было еще упоминание о BCM Strata XGS SDK, парень обещал выложить,
но не вижу в сообщениях его ответа с ссылкой. думаю у него не сложилось, а я больше не просил.
Edited by carver
