Добрый день. Помогите выяснить причину самопроизвольной перезагрузки Juniper MX-MPC2E-3D, установлена в MX240
Slot 1 information:
  State                               Online
  Temperature                      28
  Total CPU DRAM                 2048 MB
  Total RLDRAM                    734 MB
  Total DDR DRAM                 3108 MB
  Start time                          2019-04-10 15:21:25 MSK
  Uptime                              88 days, 22 hours, 57 minutes, 46 seconds
  Max power consumption            227 Watts
Slot 2 information:
  State                               Online
  Temperature                      28
  Total RLDRAM                    734 MB
  Start time                          2019-07-07 10:58:02 MSK
  Uptime                              1 day, 3 hours, 21 minutes, 9 seconds
GOT: System Exception: Vector/Code 0x00100, Signal 11
GOT: Event occurred at: Jul  7 07:56:11.892256
GOT:
GOT: Juniper Embedded Microkernel Version 15.1R7.9
GOT: Built by builder on 2018-09-11 04:14:48 UTC
GOT: Copyright (C) 1998-2018, Juniper Networks, Inc.
GOT: All rights reserved.
GOT: Reason string: "Critical Exception"
GOT: Context: Thread (QX Chip)
GOT: DDR SDRAM Error: Multi-bit ECC error
GOT:   at addr 0xbd488348, bad data 0xbadc0ffebac80ffe ecc 0xa5
GOT:
GOT: Registers:
GOT: R00: 0x40050510 R01: 0x4834eab0 R02: 0x4834cbf0 R03: 0x00000000
GOT: R04: 0x00000000 R05: 0x4834eb10 R06: 0x00000000 R07: 0x00000000
GOT: R08: 0x00000000 R09: 0x435d0000 R10: 0x1e13effe R11: 0x44199454
GOT: R12: 0x1e13f1a1 R13: 0xb5eff9cf R14: 0x5dfec7ce R15: 0x9ef55ffe
GOT: R16: 0xa65af7ab R17: 0xb9266b58 R18: 0xc6f2aeb4 R19: 0xf7ffbde3
GOT: R20: 0x00000001 R21: 0x48350a10 R22: 0x437b0000 R23: 0x466cdb30
GOT: R24: 0x437acbd0 R25: 0x437b0000 R26: 0x42d8d7f4 R27: 0x4834eae8
GOT: R28: 0x00000000 R29: 0x000003e8 R30: 0x00000000 R31: 0x000003e8
GOT: MSR: 0x00029200 CTR: 0x4004e97c Link: 0x42204c80 SP: 0x4834eab0
GOT:  CR: 0x44002082 XER: 0x20000000 DEAR: 0x00000000 PC: 0x4004e9a4
GOT: ESR: 0x00000000 K_MSR: 0x00001000
GOT:
GOT: Stack Traceback:
GOT: Frame 01: sp = 0x4834eab0, pc = 0x471f7b30
GOT: Frame 02: sp = 0x4834eab8, pc = 0x42204c80
GOT: Frame 03: sp = 0x4834eac0, pc = 0x4003d088
GOT: Frame 04: sp = 0x4834eae0, pc = 0x4003c128
GOT: Frame 05: sp = 0x4834eb08, pc = 0x4002ef50
GOT: Frame 06: sp = 0x4834eb30, pc = 0x40030090
GOT: Frame 07: sp = 0x4834eb90, pc = 0x40031d64
GOT: Frame 08: sp = 0x4834eba0, pc = 0x40a66d00
GOT: Frame 09: sp = 0x4834ebe8, pc = 0x40031a70
GOT:
GOT: [LOG] syslog called with interrupts off (caller pc:0x40035584)
GOT: [LOG] Dumping core-NPC2 to 1
GOT: [LOG] Coredump finished!
GOT: [LOG] chassis_db_set_dpc_simulation: options = 0!!
GOT: [LOG] Set the IP IRI for table #1 to 0x80000012
GOT: [LOG] IPV4 Init: Set the IP IRI to 0x80000012
GOT: [LOG] GN2405: JSPEC V 1.0 Module Init.
GOT: [LOG] WP module init
GOT: [LOG]  otn_priodic ON
GOT: [LOG] ddos_issu_helper_register: issu state is 0 at ddos startup
GOT: [LOG] ddos sock support init ...
GOT: [LOG] ddos sock connection proto in use 4 ...
GOT: [LOG] RSMON rsmon_msg_thread_init
GOT: [LOG] if_module_init: Zeroing out jam vectors
GOT: [LOG] pic_jam_plugin_module_init: PIC toolkit module init
GOT: [LOG] pic_jam_plugin_module_init: PIC toolkit MQ jam vector init
GOT:
GOT: MPC: Reset reason: RE Initiated Reset
GOT:
GOT: ROM NVRAM:
GOT:  0 available bytes, 0 used, 0 free
LOCAL: End of file
18 минут назад, zhenya` сказал:
в помойку..
Обоснуйте пожалуйста.
10 минут назад, vvertexx сказал:
Память. Вместо помойки - можно мне отправить
Ну судя по DDR SDRAM Error: Multi-bit ECC error я тоже подумал на память, но тогда почему карта сейчас работает без всяких проблем и трафик через неё гоняется?
@swat11
Ну так не полностью накрылась, пока туда важные данные не попадут - ничего не будет (QX вроде за QoS отвечает). Несколько раз падало - менять, однократно - забить, но быть готовым
3 минуты назад, swat11 сказал:
@vvertexx
Это уже второе падение. Получается, что проблема аппаратного характера?
Битая планка памяти.. ну или статикой подпалило
