Здравствуйте, предоставлю тех. информацию о потоке.
Вопрос: в чём проблема? Спасибо
<?xml version="1.0" encoding="UTF-8"?>
<ffprobe>
    <streams>
        <stream index="0" codec_name="hevc" codec_long_name="HEVC (High Efficiency Video Coding)" profile="Main 10" codec_type="video" codec_time_base="1/50" codec_tag_string="[36][0][0][0]" codec_tag="0x0024" width="3840" height="2160" coded_width="3840" coded_height="2160" has_b_frames="3" sample_aspect_ratio="1:1" display_aspect_ratio="16:9" pix_fmt="yuv420p10le" level="153" color_range="tv" color_space="bt709" color_transfer="bt709" color_primaries="bt709" refs="1" id="0xc9" r_frame_rate="50/1" avg_frame_rate="50/1" time_base="1/90000" start_pts="3345607258" start_time="37173.413978">
            <disposition default="0" dub="0" original="0" comment="0" lyrics="0" karaoke="0" forced="0" hearing_impaired="0" visual_impaired="0" clean_effects="0" attached_pic="0"/>
        </stream>
        <stream index="1" codec_name="aac" codec_long_name="AAC (Advanced Audio Coding)" profile="LC" codec_type="audio" codec_time_base="1/48000" codec_tag_string="[15][0][0][0]" codec_tag="0x000f" sample_fmt="fltp" sample_rate="48000" channels="2" channel_layout="stereo" bits_per_sample="0" id="0x12d" r_frame_rate="0/0" avg_frame_rate="0/0" time_base="1/90000" start_pts="3345521890" start_time="37172.465444" bit_rate="229125">
            <tag key="language" value="eng"/>
        </stream>
    </streams>
    <format filename="udp://---:1234" nb_streams="2" nb_programs="1" format_name="mpegts" format_long_name="MPEG-TS (MPEG-2 Transport Stream)" start_time="37172.465444" probe_score="100"/>
</ffprobe>
