Добрый день!
Подскажите будет работать такой конфиг.?
Пробую Vlan на абонента.
#display current-configuration
{ <cr>|ont<K>|port<K>|section<K>|service-port<K>|simple<K>||<K> }:
  Command:
[MA5600V800R015: 5800]
[sysmode]
  <sysmode>
 switch adsl mode to rfc2662 vdsl mode to tr129
 xpon mode switch-to profile-mode
 voice-spec set vag-num 8
 voice-spec set sip-account-num 2048
 protocol support h248
 system ex-mode backup
 router mode basic
[global-config]
  <global-config>
 sysname Bir_GPON_5608T
 terminal user name buildrun_new_password root *J$1a$@NL]#-IYhH$244_RkpH6HpnvT+ 9x4@7r:X,5o;56H`)a**z&Z^+$* 7 0000:00:00
:00:00:00 0000:00:00:00:00:00 root 1 "
-----" 0
 terminal user name buildrun_new_password ansanz *[$1a$JS4]C1WjSW$HYx4%rJ.K'
3JLH/=56T2YErP<(lU/<!Q&w4kYb5Q$* 0 2017:11:23:10:17:36 2017:11:23:10:17:36 root 2 "Admin" 0
 dba-profile add profile-id 20 profile-name "dba-profile_20" type4 max 1024000
 ont-srvprofile gpon profile-id 0 profile-name "srv-profile_default_0"
  ont-port eth 1
  port vlan eth 1 translation 100 user-vlan 100
  commit
 ont-srvprofile gpon profile-id 100 profile-name "srv-profile_100"
  ont-port eth 1
  commit
 ont-srvprofile gpon profile-id 101 profile-name "srv-profile_101"
  ont-port eth 1
  port vlan eth 1 translation 101 user-vlan 101
  commit
 ont-lineprofile gpon profile-id 0 profile-name "line-profile_default_0"
  tcont 0 dba-profile-id 2
  tcont 1 dba-profile-id 0
  commit
  quit
 ont-lineprofile gpon profile-id 100 profile-name "LINE_GPON"
  tcont 4 dba-profile-id 0
  gem add 100 eth tcont 4
  gem mapping 100 0 vlan 100
  commit
  quit
 ont-lineprofile gpon profile-id 101 profile-name "line-profile_101"
  tcont 4 dba-profile-id 20
  gem add 101 eth tcont 4
  gem mapping 101 0 vlan 101
  commit
  quit
[device-config]
  <device-config>
 board add 0/1 H807GPBH
 board add 0/4 H801MPWC
 board add standby sub0 CPCA
[public-config]
  <public-config>
 snmp-agent local-engineid 800007DB03BC9C31B8321001
[vlan-config]
  <vlan-config>
 vlan 100 to 102 smart
 vlan desc 100 description "TEST1"
 vlan desc 101 description "TEST2"
 port vlan 100 to 101 0/2 0
 port vlan 100 to 101 0/2 1
 port vlan 100 to 101 0/2 2
 port vlan 100 to 101 0/2 3
[mcu]
  <mcu-0/2>
interface mcu 0/2
 mdi 0 normal
 speed 0 1000
 speed 1 1000
 speed 2 1000
 mdi 3 normal
 speed 3 1000
[gpon]
  <gpon-0/1>
 interface gpon 0/1
 port 0 ont-auto-find enable
 port 1 ont-auto-find enable
 port 2 ont-auto-find enable
 port 3 ont-auto-find enable
 port 4 ont-auto-find enable
 port 5 ont-auto-find enable
 port 6 ont-auto-find enable
 port 7 ont-auto-find enable
 ont add 0 0 sn-auth "48575443AE25B484" omci ont-lineprofile-id 100
ont-srvprofile-id 0 desc "TEST1"
 ont add 0 1 sn-auth "48575443E9AF8547" omci ont-lineprofile-id 101
ont-srvprofile-id 101 desc "ONT_NO_DESCRIPTION"
 ont port native-vlan 0 0 eth 1 vlan 100 priority 0
 ont port native-vlan 0 1 eth 1 vlan 101 priority 0
[emu-config]
  <emu-config>
 emu add 0 fan 0 1  "H831FCBB"
[bbs-config]
  <bbs-config>
 service-port 100 vlan 100 gpon 0/1/0 ont 0 gemport 100 multi-service user-vlan 100 user-encap ipoe tag-transform transl
ate
 service-port 101 vlan 101 gpon 0/1/0 ont 1 gemport 101 multi-service user-vlan 101 user-encap ipoe tag-transform transl
ate
[config]
  <config>
 mpls label start 8192
[meth]
  <meth0>
interface meth0
 ip address 172.17.1.112 255.255.255.0
[null]
  <null0>
interface null0
[aaa]
  <aaa>
aaa
 authentication-scheme "default"
 authorization-scheme "default"
 accounting-scheme "default"
 domain "default"
[post-system]
  <post-system>
ip route-static 0.0.0.0 0.0.0.0 172.17.1.1
 undo ssh server compatible_ssh1x
 ssh user root authentication-type password
 ssh user ansanz authentication-type password
return
