Здравствуйте, столкнулся с проблемой, не пингуется белый ip адрес, с компьютеров, подверженных правилам Mangle.
Mangle:
/ip firewall mangle
add action=mark-routing chain=prerouting comment=Asterisk dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.247
add action=mark-routing chain=prerouting comment="Evgeniy Panov" dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.24
add action=mark-routing chain=prerouting comment=Docker dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=192.168.0.239
add action=mark-routing chain=prerouting comment="WiFi users" dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=no src-address=10.1.0.0/16
add action=mark-routing chain=prerouting comment="Sergey Morev" dst-address-list=!WorkSpace new-routing-mark=DOMRU-routing passthrough=no src-address=192.168.0.111
add action=mark-routing chain=prerouting comment=Users dst-address-list=!WorkSpace new-routing-mark=DOMRU-routing passthrough=no src-address=192.168.0.20-192.168.0.110
add action=mark-connection chain=input in-interface=WAN-if1 new-connection-mark=ABV-con passthrough=no
add action=mark-connection chain=input in-interface=WAN-if2 new-connection-mark=DOMRU-con passthrough=no
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ATC passthrough=no src-address=192.168.0.191
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ATC passthrough=no src-address=192.168.0.192
add action=mark-routing chain=prerouting dst-address-list=!WorkSpace new-routing-mark=ABV-routing passthrough=yes src-address=192.168.0.24
add action=mark-routing chain=output connection-mark=ABV-con new-routing-mark=ABV-routing passthrough=no
add action=mark-routing chain=output connection-mark=DOMRU-con new-routing-mark=DOMRU-routing passthrough=no
При попытке пинга с хоста 192.168.0.247 белого ip адреса 89.185.94.241 получаем:
--- 89.185.94.241 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 1999ms
При попытке трассировки с хоста 192.168.0.247 до белого ip адреса получаем:
traceroute to 89.185.94.241 (89.185.94.241), 30 hops max, 60 byte packets
1  * * *
2  * * *
3  * * *
4  * * *
5  * * *
6  *^C
Трассировка с белого ip адреса Микротика до 192.168.0.247 улетает в интернет:
 tool traceroute src-address=89.185.94.241 address=192.168.0.247
# ADDRESS                          LOSS SENT    LAST     AVG    BEST   WORST STD-DEV STATUS
1 89.185.94.254                      0%    1   0.7ms     0.7     0.7     0.7       0
2 89.185.92.33                       0%    1   1.1ms     1.1     1.1     1.1       0
3 10.221.221.1                       0%    1   0.7ms     0.7     0.7     0.7       0
4 37.60.16.186                       0%    1   0.6ms     0.6     0.6     0.6       0
5 195.218.253.241                    0%    1   1.7ms     1.7     1.7     1.7       0
6 79.104.245.102                     0%    1  29.6ms    29.6    29.6    29.6       0
7 79.104.250.66                      0%    1    36ms      36      36      36       0 <MPLS:L=407874,E=0>
8 79.104.226.254                     0%    1  32.8ms    32.8    32.8    32.8       0
9                                  100%    1 timeout
10                                    0%    1     0ms
Отмечу, что маршрут в подсеть 192.168.0.0 имеется на самом Микротике и имеет состояние DAC.
При отключении правил, находящихся в ip route rule
ip route rule print
Flags: X - disabled, I - inactive
0   src-address=89.185.94.241/32 dst-address=0.0.0.0/0 action=lookup table=ABV-routing
1   src-address=89.185.94.175/32 dst-address=0.0.0.0/0 action=lookup table=ABV-routing
2   src-address=109.194.175.23/32 dst-address=0.0.0.0/0 action=lookup table=DOMRU-routing
Довелось увидить вот такой результат:
tool traceroute 192.168.0.247 src-address=89.185.94.241
1 192.168.0.247                      0%    5   0.2ms     0.3     0.2     0.6     0.1
С маршрутизатора стал доступен адрес в локальной сети, ровно как и с адреса 192.168.0.247 стал доступен белый адрес по трассировке:
1  89.185.94.241 (89.185.94.241)  0.195 ms  0.258 ms  0.166 ms
При этом не идет пинг
4 packets transmitted, 0 received, 100% packet loss, time 2998ms
Однако, если в добавок еще выключить правило:
То пинг будет успешен:
ping 89.185.94.241
PING 89.185.94.241 (89.185.94.241) 56(84) bytes of data.
64 bytes from 89.185.94.241: icmp_seq=1 ttl=64 time=0.318 ms
64 bytes from 89.185.94.241: icmp_seq=2 ttl=64 time=0.169 ms
64 bytes from 89.185.94.241: icmp_seq=3 ttl=64 time=0.200 ms
Как можно понять проблема кроется в мангле, только вопрос где ?
Добавлю, что пинг начинает успешно идити только когда отключены ip route rule и правило в Mangle.
Edited by Konev
Вы бы описали общую ситуацию, что есть, что нужно и для чего
Возможно есть другие способы решения вопроса, например управление маршрутизацией на основании src-address возможно в Rules, не прибегая при этом к маркировке соединений и пакетов в Mangle и т.д.
Для чего необходимо из локальной сети пинговать внешний адрес? Вы хотите организовать что-то типа Hairpin NAT?
Вижу 2 провайдера, 2 локальных сети, что нужно? доступ из глобальной сети к сервисам локальной сети через разных провайдеров? доступ к маршрутизатору через разных провайдеров?
или просто SIP отправить через определенного провайдера и пару пользователей через него же?
Да, мы планируем сделать видео трансляцию на сайте и будем использовать hairpin NAT.
Отмечу, нужен доступ к белому ip с пользовательских подсетей, для того, что бы в дальнейшем они просматривали видеотрансляцию.
а где этот веб сервер, внутри сети?
возможно я излишне упрощаю, но вариант прописать статическую запись в DNS на доменное имя с указанием локального адреса сервера не подходит?
в варианте Hairpin NAT будет излишняя нагрузка на сеть, с ПК на маршрутизатор, с маршрутизатора обратно в сеть на сервер, при этом вы не будете видеть кто из локальной сети зашел на сервер а будете видеть только лишь адрес маршрутизатора
если веб сервер внутри сети, планируется ли доступ к нему через разных провайдеров или вообще доступ из глобальной сети?
Да, веб сервер находится внутри сети, и уже успешно работает через интернент.
Веб сервер находится в подсети 192.168.0.0, имеет адрес 192.168.0.239, обозначен как докер
тяжело составить общую картину когда информация подается мелкими порциями инет ответов на заданные вопросы
понятно что: есть 2 провайдера, есть сервер внутри сети, нужен доступ извне и из локальной сети к серверу по доменному имени
непонятно:
у одного из провайдеров 2 (несколько адресов), для каких целей? доступ к серверу нужен по обоим адресам?
доступ к серверу должен быть через одного провайдера или через обоих?
нужен ли failover (переключение интернета на другого провайдера в случае недоступности основного) или балансировка между провайдерами?
есть какие-то особенности сети при которых необходимо настраивать Hairpin NAT? вариант с DNS не подходит? если не подходит то почему?
