Коллеги, доброго времени суток.
На маршрутизаторе настроен файрвол:
#show configuration firewall filter accept-ssh
term accept-ssh {
   from {
       source-prefix-list {
           trusted;
       destination-prefix-list {
           LOCALS-v4;
       protocol tcp;
       destination-port ssh;
   then {
       policer management-5m;
       count accept-ssh;
       accept;
#show configuration firewall filter discard-to-locals-v4
term accept-established {
   from {
           LOCALS-v4;
       protocol tcp;
       tcp-established;
   then {
       count accept-established;
       accept;
term discard-ip-options {
   from {
           LOCALS-v4;
       ip-options any;
   then {
       count discard-ip-options;
       log;
       discard;
term discard-TTL_1-unknown {
   from {
           LOCALS-v4;
       ttl 1;
   then {
       count discard-TTL_1-unknown;
       log;
       discard;
term discard-tcp {
   from {
           LOCALS-v4;
       protocol tcp;
   then {
       count discard-tcp;
       log;
       discard;
term discard-udp {
   from {
           LOCALS-v4;
       protocol udp;
   then {
       count discard-udp;
       log;
       discard;
term discard-icmp {
   from {
           LOCALS-v4;
       protocol icmp;
   then {
       count discard-icmp;
       log;
       discard;
term discard-unknown {
   from {
           LOCALS-v4;
   then {
       count discard-unknown;
       log;
       discard;
и прикручен к интерфейсу:
show configuration interfaces xe-1/0/0
description "YYYYYY uplink";
unit 0 {
   family inet {
       filter {
           input-list [ accept-ssh discard-to-locals-v4 ];
       sampling {
           input;
       address XX.XXX.XXX.XX/30;
С удаленного хоста, не находящегося в prefix-list trusted коннекта на XX.XXX.XXX.XX порт 22/TCP - нет. Если убрать input-list [ accept-ssh discard-to-locals-v4 ] - есть.
И вот, что я наблюдаю в monitor traffic interface xe-1/0/0.0 :
15:04:55.925715  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 0
15:04:55.925787 Out IP truncated-ip - 4 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 0
15:04:56.055632  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 0
15:04:56.055657  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 23
15:04:56.105214 Out IP truncated-ip - 13 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 21
15:04:56.124942 Out IP truncated-ip - 1420 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 1428
15:04:56.239837  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 0
15:04:56.239861  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 648
15:04:56.297412  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 0
15:04:56.297468 Out IP truncated-ip - 108 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 116
15:04:56.425047  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 0
15:04:56.437239  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 272
15:04:56.530547 Out IP truncated-ip - 840 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 848
15:04:56.673915  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 16
15:04:56.773744 Out IP XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 0
15:04:56.901484  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 52
15:04:56.902119 Out IP truncated-ip - 44 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 52
15:04:57.029822  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 84
15:04:57.056223 Out IP truncated-ip - 76 bytes missing! XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 84
15:04:57.184046  In IP 104.209.190.5.2161 > XX.XXX.XXX.XX.ssh: tcp 84
15:04:57.283744 Out IP XX.XXX.XXX.XX.ssh > 104.209.190.5.2161: tcp 0
В логе:
Apr 21 15:04:33  inetd[1370]: /usr/sbin/sshd[81697]: exited, status 255
Apr 21 15:04:41  sshd: SSHD_LOGIN_FAILED: Login failed for user 'veroxcode' from host '104.209.190.5'
Apr 21 15:04:41  sshd[81699]: Failed password for veroxcode from 104.209.190.5 port 2162 ssh2
Apr 21 15:04:46  sshd[81699]: Connection closed by 104.209.190.5 [preauth]
Apr 21 15:04:46  inetd[1370]: /usr/sbin/sshd[81699]: exited, status 255
Apr 21 15:04:49  sshd[81701]: Failed password for veroxcode from 104.209.190.5 port 2160 ssh2
Apr 21 15:04:49  sshd: SSHD_LOGIN_FAILED: Login failed for user 'veroxcode' from host '104.209.190.5'
Apr 21 15:04:49  sshd[81701]: Connection closed by 104.209.190.5 [preauth]
Apr 21 15:04:49  inetd[1370]: /usr/sbin/sshd[81701]: exited, status 255
Apr 21 15:04:57  sshd: SSHD_LOGIN_FAILED: Login failed for user 'vyatta' from host '104.209.190.5'
Apr 21 15:04:57  sshd[81705]: Failed password for vyatta from 104.209.190.5 port 2161 ssh2
Как, почему и как это прекратить?
Пока сделал:
inactive: term accept-established {
   from {
           LOCALS-v4;
       protocol tcp;
       tcp-established;
   then {
       accept;
так, как есть подозрение, что через этот term попадают данные пакеты. Но скан уже кончился, не ясно, изменилась ситуация или нет.
Спасибо за внимание.
Не совсем понятно, куда коннектишься. Если к самому джуне - примени фильтр на loopback интерфейс (lo0)
Коннекчусь к одному из внешних адресов маршрутизатора.
А если loopback несконфинурирован?
user@J> show interfaces lo0
Physical interface: lo0, Enabled, Physical link is Up
 Interface index: 6, SNMP ifIndex: 6
 Type: Loopback, MTU: Unlimited
 Device flags   : Present Running Loopback
 Interface flags: SNMP-Traps
 Link flags     : None
 Last flapped   : Never
   Input packets : 40640
   Output packets: 40640
 Logical interface lo0.16384 (Index 320) (SNMP ifIndex 21)
   Flags: SNMP-Traps Encapsulation: Unspecified
   Input packets : 6714
   Output packets: 6714
   Protocol inet, MTU: Unlimited
     Addresses
       Local: 127.0.0.1
 Logical interface lo0.16385 (Index 321) (SNMP ifIndex 22)
   Input packets : 33628
   Output packets: 33628
user@J> show configuration interfaces lo0
user@J>
Edited by mse.rus77
