Доброго времени суток!
Имею Juniper МХ80 c прошивкой 11.4X27.68 (новее поставить не могу по причине возможного отвала 10ж портов).
Настроена схема subscrider management для Q-in-Q и DHCP.
Вот кусок конфига :
dynamic-profiles {
   qinq-int {
       interfaces {
           "$junos-interface-ifd-name" {
               unit "$junos-interface-unit" {
                   demux-source inet;
                   proxy-arp;
                   vlan-tags outer "$junos-stacked-vlan-id" inner "$junos-vlan-id";
                   family inet {
                       unnumbered-address lo0.0;
   qinq-dhcp {
       interfaces {
               inactive: unit "$junos-interface-unit" {
                   family inet {
               unit "$junos-underlying-interface-unit" {
                   family inet {
   Subscriber {
       variables {
           SPEED_IN mandatory;
           SPEED_OUT mandatory;
       interfaces {
                   family inet {
                       filter {
                           input "$SPEED_IN" precedence 10;
                           output "$SPEED_OUT" precedence 10;
   Parking {
       inactive: variables {
           SPEED_IN mandatory;
       interfaces {
                   inactive: vlan-tags outer "$junos-stacked-vlan-id" inner "$junos-vlan-id";
                   family inet {
                       filter {
                           input parking_in precedence 10;
                           output parking_out precedence 10;
   svc-ipoe-guest {
       interfaces {
                   family inet {
                       filter {
   svc-global-ipoe {
       variables {
           SPEED_IN mandatory;
           INET_IN uid;
           INET_OUT uid;
           POLICER_IN uid;
           POLICER_OUT uid;
       interfaces {
                   family inet {
                       filter {
                           input "$INET_IN";
                           output "$INET_OUT";
       firewall {
           family inet {
               filter "$INET_IN" {
                   interface-specific;
                   term 1 {
                       then {
                           policer "$POLICER_IN";
                           service-accounting;
                           accept;
               filter "$INET_OUT" {
                   interface-specific;
                   term 1 {
                       then {
                           policer "$POLICER_OUT";
                           service-accounting;
                           accept;
           policer "$POLICER_IN" {
               if-exceeding {
                   bandwidth-limit "$SPEED_IN";
                   burst-size-limit 512k;
               then discard;
           policer "$POLICER_OUT" {
               if-exceeding {
                   bandwidth-limit "$SPEED_OUT";
               then discard;
access {
   radius-server {
       x.x.x.92 {
           port 1812;
           secret "**************************"; ## SECRET-DATA
   radius-disconnect {
       x.x.x.92 secret "**************************"; ## SECRET-DATA
   profile ipoe {
       authentication-order [ radius none ];
       radius {
           authentication-server x.x.x.92;
           accounting-server x.x.x.92;
           options {
               accounting-session-id-format decimal;
       accounting {
           order radius;
           immediate-update;
           coa-immediate-update;
           update-interval 600;
           statistics volume-time;
   address-assignment {
       inactive: pool ipoe-10100 {
           family inet {
               network 10.100.0.0/16;
               range main {
                   low 10.100.0.2;
                   high 10.100.254.254;
               dhcp-attributes {
                   router {
                       10.100.0.1;
       pool ipoe-pool1 {
           family inet {
               network y.y.y.y/27;
               range main {
                   low y.y.y.y;
                   high y.y.y.y;
               dhcp-attributes {
                   maximum-lease-time 600;
                   router {
                       y.y.y.y;
       pool real-ip-1 {
           family inet {
               network z.z.z.z/23;
               range main {
                   low z.z.z.z;
                   high z.z.z.z;
               dhcp-attributes {
                   router {
                       z.z.z.z;
       pool real-ip-3 {
           family inet {
               network n.n.n.n/18;
               range main {
                   low n.n.n.n;
                   high n.n.n.n;
               dhcp-attributes {
                   name-server {
                       k.k.k.k;
                       l.l.l.l;
                   router {
                       k.k.k.k;
Так вот основная проблема в том, что при выдаче подписчику профайла svc-ipoe-guest, лайв пакеты МХ80 не отправляет биллингу и биллинг (Абиллс) по истечении времени гостевой "сессии" считает ее зависшей (помещает в ZAP) и затем удаляет. Но МХ80 продолжает выдавать лизы по запросам от клиента и держит интерфейс поднятым для этой гостевой "сессии".
Как говорит разработчик биллинга, МХ80 должен слать лайв пакеты и для гостевой сессии, а когда она закончится, должен дропнуть интерфейс на МХ80 и подписчик заново запросит айпи для гостевой сессии.
Почему МХ80 не шлет лайв пакеты для гостевого профайла svc-ipoe-guest? проблема в версии прошивки или настройке профайлов?
зы и второй небольшой вопрос: как лучше организовать перенаправление на страницу биллинга? чтобы при попытке открыть ya.ru МХ80 перенаправлял запрос на сервер биллинга? у меня имеется реализация, но она не всегда срабатывает, может быть есть лучший вариант?
Объясните , что такое лайв пакеты ?
Если вы возвращаете клиенту session-timeout то этот атрибут работает только для ppp сессий , для dhcp - это этот параметр будет использоваться как dhcp lease time. И завершать клиентскую сессию по истечении этого времени никто не будет.
Покажите какой способ редиректа у вас реализован , тогда можно будет говорить о том что у вас сделано не правильно. По идее , кроме как завернуть клиентский трафик (порт 80) к себе на сервер и отвечать редиректом , у вас вариантов нет, поэтому нужно разбираться что именно у вас не работает.
Имею ввиду Interim-Update, приходящие на сервер радиуса при при реализации IPoE.
Дело в том, что МХ80 гостю постоянно выдает заново лизу согласно настройке конфига. И этот процесс бесконечен. А хотелось бы, чтобы биллинг удалял интерфейс по окончании настроек гостевой сессии биллинга. А затем бы снова юзер запросил бы по DHCP айпи и снова поднялся бы интерфейс на МХ80.
Билинг может дропнуть "сессию" рабочую - в смысле удалить интерфейс на МХ80, но для этого он по Interim-Update понимает, что есть такой интерфейс нап МХ80. В гостевой же сессии этих пакетов нет.
На данный момент реализовано через фильтр и routing instances
filter parking_in {
           interface-specific;
           term 0 {
               from {
                   destination-port 67;
               then accept;
           term 1 {
               then {
                   routing-instance SM_Parking;
           term 2 {
               then accept;
filter parking_out {
           interface-specific;
           term 1 {
               from {
                   ttl [ 62-64 126-128 ];
               then accept;
           term 2 {
               then {
                   reject;
routing-instances {
   SM_PARKING {
       instance-type forwarding;
       routing-options {
           static {
               route 0.0.0.0/0 next-hop х.х.х.92;
Interim-update не зависит от примененного dynamic-profile, единственный вариант это что вы при авторизации абонента (он же у вас авторизируется ?) с радиуса возвращаете update-interval - какой-нибудь очень большой или равный нулю. И как следствие не видите аккаунтинга
Тут уже обсудили все работает как и должно работать . Смотри что у вас билинг возвращает при авторизации этого абонента и почему так происходит.
Покажите вывод команды show dynamic-configuration session information session-id ХХХХХ, вместо ХХХХХ подставьте Session id из вывода show subscribers detail, для этого абонента.
filter parking_in {
           interface-specific;
           term 0 {
               from {
               then accept;
           term 1 {
               then {
           term 2 {
               then accept;
           interface-specific;
           term 1 {
               from {
               then accept;
           term 2 {
               then {
                   reject;
routing-instances {
   SM_PARKING {
       routing-options {
           static {
Это какое-то безумие заворачивать в ri SM_PARKING, что-то кроме tcp port 80. В этом нет никакого смысла. Обратный трафик с src-port 80 лучше разрешить полностью , а не по ttl
В том то и дело, что это гостевая сессия, то есть еще не авторизовался юзер, а только получил по дхцп айпи и, соотвественно, поднят интерфейс и выдана лиза на мх80.
Вот для гостя вывод:
worky@gw> show dynamic-configuration session information session-id 419
Session info:
 Accounting session ID: 419
 IP address: y.y.y.152
 IP netmask: 255.255.224.0
 Logical system name: default
 Profile name: qinq-dhcp
 Session version: 1
 Physical IFD name of the interface: ae0
 MAC address: 1c:af:f7:2a:10:43
 NAS port type: 15
 Routing instance: default
 Access Profile: ipoe
 User name: 1caf.f72a.1043
 Interface name: ae0.1073741957
 Dynamic-configuration state: 2
 Client session type: 1
 IFL type: 1
 Framed Ipv4 Pool: real-ip-3
 Accounting type: 2
 Accounting interval: 36000
 Multi-client logical-interface: 2
 Underlying logical-interface: ae0.1073741957
 Client login time: 2017-04-20 13:04:20 EEST
 DHCP option: 35:01:01:3d:07:01
 VLAN tag: 153
 SVLAN tag: 2000
 Service Type: 2
 Primary DNS address: x.x.x.2
 Configuration bits: 0x80003 0 0 0 0
Dynamic configuration:
 junos-framed-route-ip-address-prefix: 0.0.0.0/8
     junos-framed-route-nexthop: 0.0.0.0
         junos-framed-route-cost: 1
     junos-subscriber-demux-ip-address: y.y.y.152/32
     junos-subscriber-demux-ip-address: 0.0.0.0/8
 junos-underlying-interface: ae0.1073741957
Service session IDs:
 420
У нас биллинг на 443 порту, на 80м висит заворот на 443. Нужно чтобы гостевой юзер мог только нашу 24х битную сеть видеть - в ней днс, сайт, биллинг.
Как это лучше реализовать? если можно - пример.
А вот процесс включения гостевого юзера со стороны радиуса:
rad_recv: Access-Request packet from host x.x.x.1 port 55099, id=226, length=190
User-Name = "1caf.f72a.1043"
Service-Type = Framed-User
Chargeable-User-Identity = ""
Acct-Session-Id = "392"
ERX-Dhcp-Options = 0x3501013d07011caff72a10430c074449522d3330303204c3e193fd37090103060f212c2e2f79
ERX-Dhcp-Mac-Addr = "1caf.f72a.1043"
NAS-Identifier = "gw"
NAS-Port = 153
NAS-Port-Id = "ae0.1073741948:2000-153"
NAS-Port-Type = Ethernet
ERX-Pppoe-Description = "pppoe 1c:af:f7:2a:10:43"
Thu Apr 13 19:43:32 2017 : Info: # Executing section authorize from file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
Thu Apr 13 19:43:32 2017 : Info: +group authorize {
Thu Apr 13 19:43:32 2017 : Info: ++[preprocess] = ok
Thu Apr 13 19:43:32 2017 : Info: ++[mschap] = noop
Thu Apr 13 19:43:32 2017 : Info: [files] users: Matched entry DEFAULT at line 38
Thu Apr 13 19:43:32 2017 : Info: ++[files] = ok
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Session-Id = 392
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-Port = 153
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Chargeable-User-Identity =
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Service-Type = Framed-User
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-Port-Type = Ethernet
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair ERX-Dhcp-Options = 0x3501013d07011caff72a10430c074449522d3330303204c3e193fd37090103060f212c2e2f79
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair ERX-Pppoe-Description = pppoe 1c:af:f7:2a:10:43
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair User-Name = 1caf.f72a.1043
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-Identifier = gw
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-IP-Address = x.x.x.1
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-Port-Id = ae0.1073741948:2000-153
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair ERX-Dhcp-Mac-Addr = 1caf.f72a.1043
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Auth-Type = Perl
Thu Apr 13 19:43:32 2017 : Info: ++[perl] = ok
Thu Apr 13 19:43:32 2017 : Info: +} # group authorize = ok
Thu Apr 13 19:43:32 2017 : Info: Found Auth-Type = Perl
Thu Apr 13 19:43:32 2017 : Info: # Executing group from file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
Thu Apr 13 19:43:32 2017 : Info: +group Perl {
aaaaaaaaaaaaaaaaaaaaaaaa/// if (ae0.1073741948:2000-153 =~ /:(d+)-(d+)
sssssssssssss<pre><code>
SELECT INET_NTOA(framed_ip_address) AS ip FROM dv_calls
      WHERE user_name=''
        AND status=11
        AND nas_id='15'
        AND framed_ip_address > 0;
</code></pre>
<pre><code>
SELECT ippools.ip, ippools.counts, ippools.id, ippools.next_pool_id,
     IF(ippools.gateway > 0, INET_NTOA(ippools.gateway), 0),
     IF(ippools.netmask > 0, INET_NTOA(ippools.netmask), ''), dns, ntp
   FROM ippools
    WHERE ippools.id='20'
    ORDER BY ippools.priority;
</code></pre>
<pre><code>
SELECT c.framed_ip_address
   FROM dv_calls c
   INNER JOIN nas_ippools np ON (c.nas_id=np.nas_id)
   WHERE np.pool_id in ( 20 )
   GROUP BY c.framed_ip_address;
</code></pre>
<pre><code>
INSERT INTO dv_calls SET started=NOW(),
      lupdated        = UNIX_TIMESTAMP(),
      status          = '11',
      acct_session_id = 'IP',
      nas_ip_address  = INET_ATON('x.x.x.1'), guest='1', CONNECT_INFO='ae0.1073741948:2000-153', nas_id='15', framed_ip_address=3169797986, CID='1caf.f72a.1043'
</code></pre>
<pre><code>
DELETE FROM dhcphosts_leases WHERE (ip=INET_ATON( ? ) AND nas_id= ? )
   OR (uid= ?  AND flag<> ? );
</code></pre>
<pre><code>
INSERT INTO dhcphosts_leases
     (start, ends, state, next_state, hardware, uid,
      circuit_id, remote_id, hostname,
      nas_id, ip, port, vlan, server_vlan, switch_mac, flag,
      dhcp_id)
   VALUES (NOW(),
     NOW() + INTERVAL ? SECOND, 2, 1,
     ?, ?, ?, ?, ?, ?, INET_ATON( ? ), ?, ?, ?, ?, ?, ?)
</code></pre>
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair NAS-IP-Address = x.x.x..1
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Reply-Message = USER_NOT_EXIST q2q: 2000-153 MAC: 1c:af:f7:2a:10:43
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair   MS-Primary-DNS-Server = x.x.x.2
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-Route = 0.0.0.0 0.0.0.0 x.x.x.1
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Session-Timeout = 900
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-IP-Netmask = 255.255.224.0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-IP-Address = x.x.x.y
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair ERX-Primary-Dns = x.x.x.2
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair   MS-Secondary-DNS-Server = x.x.x.8
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair ERX-Service-Activate:1 = svc-ipoe-guest
Thu Apr 13 19:43:32 2017 : Info: +} # group Perl = ok
Thu Apr 13 19:43:32 2017 : Info: # Executing section post-auth from file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
Thu Apr 13 19:43:32 2017 : Info: +group post-auth {
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-Route = 0.0.0.0 0.0.0.0 x.x.x.y
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-IP-Address = x.x.x.98
Thu Apr 13 19:43:32 2017 : Info: +} # group post-auth = ok
Sending Access-Accept of id 226 to x.x.x.1 port 55099
Reply-Message = "USER_NOT_EXIST q2q: 2000-153 MAC: 1c:af:f7:2a:10:43"
Framed-Route = "0.0.0.0 0.0.0.0 x.x.x.1"
Framed-IP-Address = x.x.x..98
ERX-Service-Activate:1 = "svc-ipoe-guest"
Thu Apr 13 19:43:32 2017 : Info: Finished request 15.
Thu Apr 13 19:43:32 2017 : Debug: Going to the next request
Thu Apr 13 19:43:32 2017 : Debug: Waking up in 4.9 seconds.
rad_recv: Accounting-Request packet from host x.x.x.1 port 55099, id=227, length=245
Acct-Status-Type = Start
Framed-Route = "0.0.0.0/8 0.0.0.0  1"
Acct-Authentic = RADIUS
Acct-Delay-Time = 0
Event-Timestamp = "\u0410\u043f\u0440 13 2017 19:45:53 EEST"
NAS-Port = 153
Thu Apr 13 19:43:32 2017 : Info: # Executing section preacct from file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
Thu Apr 13 19:43:32 2017 : Info: +group preacct {
Thu Apr 13 19:43:32 2017 : Info: +} # group preacct = ok
Thu Apr 13 19:43:32 2017 : Info: # Executing section accounting from file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
Thu Apr 13 19:43:32 2017 : Info: +group accounting {
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Output-Gigawords = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair OUTBYTE2 = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INTERIUM_OUTBYTE = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Authentic = RADIUS
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Calling-Station-Id =
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INTERIUM_INBYTE = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Delay-Time = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INTERIUM_OUTBYTE2 = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INTERIUM_INBYTE2 = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Status-Type = Start
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair OUTBYTE = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Framed-Route = 0.0.0.0/8 0.0.0.0  1
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INBYTE2 = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair Event-Timestamp = \ufffd?\u043f\ufffd? 13 2017 19:45:53 EEST
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: ERROR: Failed to create pair INBYTE = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Acct-Input-Gigawords = 0
Thu Apr 13 19:43:32 2017 : Debug: rlm_perl: Added pair Connect-Info =
Thu Apr 13 19:43:32 2017 : Info: +} # group accounting = ok
Sending Accounting-Response of id 227 to x.x.x.1 port 55099
Thu Apr 13 19:43:32 2017 : Info: Finished request 16.
Thu Apr 13 19:43:32 2017 : Info: Cleaning up request 16 ID 227 with timestamp +1665
Thu Apr 13 19:43:32 2017 : Debug: Waking up in 4.8 seconds.
Edited by worky
Ну и чего вы хотите ,
у вас написано же
и в конфиге
 update-interval 600
т.е. кидать аккаунтинг раз в 10 часов. Первый пакет аккаунтинга прилетает вам немедленно, т.к. у вас сконфигурен immediate-update, следующий получите через 10 часов :)
Откуда берется цифра 36000? в конфиге мх80 в секундах выставлено в настройках дхцп 600 сек.
Да, нашел - update interval в минутах выставляется.
Сейчас потестирую с другим параметром.
А по поводу перенаправления гостевой сессии можете что-то подсказать?
Передайте кроме :
Еще :
ERX-Service-Statistics:1 = time-volume
ERX-Service-Interim-Acct-Interval:1 = 600
Так это будет только сервисный аккаунтинг.
На сколько я понял ТС ему и надо сервисный, нет ?
хз, ТС так изъясняется что вообще трудно что-то понять
Об чем речь идет?
Об чем речь идет?
о том, что ТС плохо объясняет что именно он хочет.
Есть 2 вида аккаунтинга , клиентской сессии (та что поднимается через dhcp или pppoe ) или сервисная сессия (та сессия где вы ограничиваете скорость и..т.д.). У каждой из этих сессий есть свой аккаунтинг. Я конечно предположил что вам нужен аккаунтинг клиентской сессии и все что я писал касалось именно его, но возможно вам нужна информация по сервисным сессиям, как предположил h1vs2 (мы то хз что нужно вашему биллингу).
