Продаю коммутатор Cisco Catalyst WS-C3750G-12S-S (12 GbE SFP). В комплекте стандартные (где-то лежат и т.н. углублённые - recessed) уши, кабель питания и консольник, крепёж для ушей и в стойку. Коммутатор исправен, продут, конфиг сброшен в дефолт. Залью любой IOS из тех, что есть у меня.
Москва, могу отправить в регионы (терминал "Деловых Линий" в 15-минутной доступности). Оплата нал либо безнал на карту или счёт (обсуждаемо - в ЛС).
Цена - 18000 руб., обсуждаема.
Контакты - ЛС или andris -at- aernet -dot- ru .
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(44)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 05-Jan-08 00:29 by weiliu
Image text-base: 0x00003000, data-base: 0x01440000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE3, RELEASE SOFTWARE (fc1)
Switch uptime is 4 minutes
System returned to ROM by power-on
System image file is "flash:/c3750-ipbasek9-mz.122-44.SE.bin."
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3750G-12S (PowerPC405) processor (revision R0) with 118784K/12280K bytes of memory.
Processor board ID ***********
Last reset from power-on
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : *****************
Motherboard assembly number     : 73-9678-07
Power supply part number        : 341-0048-03
Motherboard serial number       : ***********
Power supply serial number      : ***********
Model revision number           : R0
Motherboard revision number     : B0
Model number                    : WS-C3750G-12S-S
System serial number            : ***********
Top Assembly Part Number        : 800-25856-04
Top Assembly Revision Number    : A0
Version ID                      : V06
CLEI Code Number                : CNM81V0GRB
Hardware Board Revision Number  : 0x06
Switch Ports Model              SW Version            SW Image
*    1 12    WS-C3750G-12S      12.2(44)SE            C3750-IPBASEK9-M
Configuration register is 0xF
Switch#
Switch#
Switch#sh post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Edited by Andris
  • 2 weeks later...
