Здравствуйте!
Может кто сталкивался с проблемой, того что Cisco вставляет свои данные при relay. Проверяли на разных версиях софта (Version 03.16.02.S - Extended Support Release, Version 03.16.01a.S, Version 03.14.00.S
12.10.2016 10:38:18.828861 [0x000008e7b700] DEBUG dhcp_op82_parse:407: SubOp82: UNDEF SubOp82 ID 0x96 found. Skip.
12.10.2016 10:38:18.828864 [0x000008e7b700] DEBUG dhcp_op82_parse:430: Op82 Circuit ID :VLAN 0, Unit 0, Port 0 (l=0), Remote ID 00000A64000100000BBE (l=10)
12.10.2016 10:38:18.828870 [0x000008e7b700] DEBUG dhcp_allocate_ip:4693: lookup up client by Op.82: 0x7f4cfc002030
12.10.2016 10:38:18.828872 [0x000008e7b700] DEBUG pool_ip_entry_match_op82:153: branched by Op.82 RemoteID 00000A64000100000BBE
12.10.2016 10:38:18.828987 [0x000008e7b700] DEBUG pool_ip_entry_match_op82:179: RemoteID = 00000A64000100000BBE, record not FOUND
12.10.2016 10:38:18.828990 [0x000008e7b700] DEBUG dhcp_allocate_ip:4704: client MAC 00:11:22:33:44:55 not permitted by Op.82: 0x7f4cfc002030
12.10.2016 10:38:18.828993 [0x000008e7b700] DEBUG dhcp_device_list_lookup_op82:4498: Op.82 lookup device RemoteID 00000A64000100000BBE
12.10.2016 10:38:18.829014 [0x000008e7b700] DEBUG dhcp_device_list_lookup_op82:4525: RemoteID = 00000A64000100000BBE, record NOT FOUND
12.10.2016 10:38:18.829016 [0x000008e7b700] DEBUG dhcp_allocate_ip:4709: service hardware not found by Op.82: 0x7f4cfc002030
12.10.2016 10:38:18.829020 [0x000008e7b700] DEBUG dhcp_msg_dispatch:108: DHCPDISCOVER from unknown client HW MAC 00:11:22:33:44:55
12.10.2016 10:38:18.829022 [0x000008e7b700] DEBUG dhcp_main:293: dhcp_msg_dispatch(0x7f4cfc000a90) failed
Конфигурация следующая:
ip dhcp relay information policy keep
no ip dhcp relay information check
ip dhcp relay information trust-all
ip dhcp binding cleanup interval 10
policy-map type control ISG-CUSTOMERS-BY-MAC
class type control IP-UNAUTH-ISG event timed-policy-expiry
1 service disconnect
class type control always event session-start
10 authorize aaa list ISG-AUTH-1 password ISG identifier mac-address
20 set-timer IP-UNAUTH-TIMER 1
30 service-policy type service name SERVICE-TRUSTED
40 service-policy type service name SERVICE_L4R
class type control always event session-restart
interface GigabitEthernet0/0/0.3006
encapsulation dot1Q 3006
ip unnumbered Loopback0
ip helper-address XXX.XXX.XXX.XXX
no ip redirects
ip local-proxy-arp
ip nat inside
ip pim passive
service-policy type control ISG-CUSTOMERS-BY-MAC
ip subscriber l2-connected
initiator dhcp
ISG не умеет промежуточный relay, это в restrictions в configuration guide явно указано.
У нас абоненты авторизуются по opt82 которую вставляют коммутаторы доступа. Но возникла необходимость авторизовывать абонентов по mac, так как не во всех местах можно привязать учетную запись абонента к порту коммутатора, из-за того что их там может быть несколько. И в силу особенностей Lanbilling для привязки таким абонентам статического белого ip необходимо чтобы opt82 в DHCP пакете отсутствовала, соответственно создали отдельный интерфейс с другим policy с идентификатором mac-address. Но проблема в том, что cisco при получении dhcp пакета без opt82 вставляет свою, хотя явно указано ip dhcp relay information policy keep.
Если коммутаторы просто подставляют Option 82, то должно работать по-идее. Если giaddr меняется, то не будет работать.
Для авторизации opt82 используем mac коммутатора и номер порта
10 authorize aaa list ISG-AUTH-1 password ISG identifier remote-id plus circuit-id separator -
В том то и дело что на другой cisco все работает, а на ASR1000 почему то вставляет свое значение в DHCP пакет без opt82.
Работает на:
Cisco IOS Software, 7200 Software (C7200P-IS-M), Version 12.2(31)SB18, RELEASE SOFTWARE (fc1)
Edited by Tamplier
