Добрый день. Имеется следующая схема соединения двух удаленных роутеров wi-fi мостом.
MK RB750:
/interface ethernet print
0    ether1                                1500 D4:CA:6D:5C:36:43 enabled    none
1 RS ether2-wifi                           1500 D4:CA:6D:5C:36:44 proxy-arp  none                                        switch1
2 RS ether3-cam                            1500 D4:CA:6D:5C:36:45 proxy-arp  none                                        switch1
3 RS ether4-ttk                            1500 D4:CA:6D:5C:36:46 enabled    none                                        switch1
4 RS ether5-mts                            1500 D4:CA:6D:5C:36:47 proxy-arp  none                                        switch1
/interface vlan print
#    NAME                                                             MTU ARP        VLAN-ID INTERFACE
0 R  vlan3-ttk                                                       1500 enabled          3 ether2-wifi
1 R  vlan4-mts                                                       1500 enabled          4 ether2-wifi
interface bridge print
Flags: X - disabled, R - running
0  R name="bridge-mts" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=D4:CA:6D:5C:36:47 protocol-mode=none priority=0x8000
     auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=10 ageing-time=5m
1  R name="bridge-to-dtkms" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=D4:CA:6D:5C:36:44 protocol-mode=none priority=0x8000
2  R name="bridge-ttk" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=D4:CA:6D:5C:36:46 protocol-mode=none priority=0x8000
Mikrotik PC:
/interface print
Flags: D - dynamic, X - disabled, R - running, S - slave
#     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
0  X  ether1                              ether            1500                  D4:CA:6D:5C:36:47
1  RS ether2-server                       ether            1500  9200            C4:6E:1F:02:00:2D
2  R  ether3-l2fs                         ether            1500                  64:66:B3:05:C5:DF
3  RS ether4-wifi                         ether            1500                  64:66:B3:10:18:CD
4 DR  <pptp----->                     pptp-in          1400
5  R  bridge-to-dtkms                     bridge           1500  9200            64:66:B3:10:18:CD
6  R  mts-l2tp                            l2tp-out         1456
7  R  ttkdv-l2tp                          l2tp-out         1456
8  R  vlan3-ttk                           vlan             1500                  64:66:B3:10:18:CD
9  R  vlan4-mts                           vlan             1500                  64:66:B3:10:18:CD
Flags: X - disabled, R - running, S - slave
0 R  vlan3-ttk        1500 enabled          3 ether4-wifi
1 R  vlan4-mts        1500 enabled          4 ether4-wifi
А теперь описываю ситуацию:
Есть локалка 172.20.0.0/16: через ether5-mts на RN750 с vid 4 идет на MK PC и поднимается dhcp на vlan4-mts
Есть другая локалка, через ether4-ttk аналогично первой, vid 3.
Домашняя сетка 10.10.10.0/24 объединяет в себе оба роутера, антены, камеры и сервер, трафик не тегируется.
Доступ из инета и локалок есть до сервера, все работает.
НО есть проблемы с работой веб сервера, подозреваю что связано это с MTU на каком то узле, подключении. А где именно никак не пойму. Причем через интернет доступ нормальный, а из локалок - затруднителен.
Помогите разобраться, какие надо логи - пишите.
This topic is now closed to further replies.
