Добрый день.
Есть проблема с настройкой DHCP relay на:
SNR-S2950-24G Device, Compiled on Oct 31 00:40:31 2011
SoftWare Version 6.2.138.58
BootRom Version 4.10.1
HardWare Version 1.0.1
CPLD Version N/A
Device serial number A200053R2L
Copyright © 2011 NAG LLC
All rights reserved
Last reboot is cold reset.
Uptime is 0 weeks, 0 days, 0 hours, 11 minutes.
Настройка DHCP на комумтаторе:
ip forward-protocol udp bootps
ip dhcp relay information option
ip dhcp relay information option self-defined remote-id string 10.3.0.66
ip dhcp relay share-vlan 2 sub-vlan 200
ip dhcp snooping enable
ip dhcp snooping vlan 2;200
ip dhcp snooping binding enable
ip dhcp snooping information enable
ip dhcp snooping information option subscriber-id format hex
ip dhcp snooping information option self-defined remote-id string 10.3.0.66
interface Vlan2
description MANAGEMENT-INTERFACE
ip address 10.3.0.66 255.255.255.0
!forward protocol udp 67(active)!
ip helper-address 10.3.0.3
Порты 1/1 - аплинк, 1/2 на доступ:
Interface Ethernet1/1
description TEST-INTERFACE
switchport mode trunk
switchport trunk allowed vlan 2;200
ip dhcp snooping trust
Interface Ethernet1/2
description TEST-PORT-VLAN-200
switchport access vlan 200
loopback-detection specified-vlan 1
loopback-detection control block
igmp snooping drop query
Настройка DHCP сервера (isc-dhcp-server) описание класса:
#class "vlan200" { match if binary-to-ascii (10, 8, "", substring(option agent.circuit-id, 2, 2))="200"; }
class "vlan200" { match if (binary-to-ascii(10, 16, "", substring(option agent.circuit-id, 2, 2)) = "200"
and binary-to-ascii(10, 16, "", substring(option agent.circuit-id, 10, 2)) = "2"
and substrin (option agent.remote-id, 2, 15) = "10.3.0.66");}
subnet 193.210.161.0 netmask 255.255.255.0 {
option routers 193.210.161.1;
option subnet-mask 255.255.254.0;
pool { range 193.210.161.20; allow members of "vlan200"; }
Подозреваю что проблема именно в описании класса, так как если включить закомментированное описание, то ip адрес получает и сразу же появляется записть в /var/log/ о том, что ip получен,
а вот в данной конфигурации никаких записей - нет. Варианты "выловить" и отдать ip по нужным мне критериям привели к Wireshark-у и tcpdump, запрос был перехвачен, но ничем не помог, правильное смещение так и не удалось выставить, еще и приходит запрос странноватого формата, при переводе из 10-ой в 16-ю систему например vlan 200 (C8) - в визуализированном dhcp запросе wireshark - С8 просто НЕТ, в перехваченном пакете он почему то выглядит как E2 E0 E0, либо я не совсем понимаю идеологию перехваченного пакета. Таким же образом в пакете выглядят и другие данные option 82.
Может кто то уже встречался с формированием подобного DHCP конфига и может подсказать заветные три строки с описанием класса?
Edited by minimyaf
  • 1 month later...
а где бы найти полное рисание сего формата?
Вот у меня
binary-to-ascii(10, 8, ":", option agent.circuit-id) возвращает
0:6:0:3:1:0:0:13
последнее понятно порт. А остальное?
Добрый день,
Расшифровка circuit-id на коммутаторах SNR на примере 00:06:00:c9:01:00:00:03
00 - номер сабопции
06 - длина сабопции в байтах
00c9 - VLAN ID
01 - номер слота (не имеет реального значения)
00 - номер модуля (не имеет реального значения)
0003 - номер порта
