Добрый день коллеги.
Прошу помочь гуру по gstreamer. Имею ubuntu 14.04.3 + i7-3770K + gstreamer1.0 Задача - сделать хардварное кодирование h264 с помощью vaapi encoder.
Вроде все поставилось нормально, но gst-inspect-1.0 показывает следующее:
gst-inspect-1.0 version 1.2.4
GStreamer 1.2.4
vaapi: vaapisink: VA-API sink
vaapi: vaapipostproc: VA-API video postprocessing
vaapi: vaapidecode: VA-API decoder
Encoder отсутствует в этом списке, соответственно не могу его использовать. Куда рыть?
Edited by winger
теперь такое вижу
root@ubuntu:~/gstreamer# gst-inspect-1.0 vaapi
Plugin Details:
Name vaapi
Description VA-API based elements
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvaapi.so
Version 0.6.1
License LGPL
Source module gstreamer-vaapi
Binary package gstreamer-vaapi
Origin URL gwenole.beauchesne@intel.com, sreerenj.balachandran@intel.com
vaapiencode_h264: VA-API H.264 encoder
vaapiencode_mpeg2: VA-API MPEG-2 encoder
vaapiencode_vp8: VA-API VP8 encoder
6 features:
+-- 6 elements
root@ubuntu:~/gstreamer# gst-launch-1.0 -vvv udpsrc uri=udp://233.99.61.1:5000 ! decodebin ! vaapiencode_h264 ! mpegtsmux ! rndbuffersize max=1316 min=1316 ! udpsink host=224.1.1.1 port=1234
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstVaapiEncodeH264:vaapiencodeh264-0: Could not initialize supporting library.
Additional debug info:
gstvideoencoder.c(1428): gst_video_encoder_change_state (): /GstPipeline:pipeline0/GstVaapiEncodeH264:vaapiencodeh264-0:
Failed to open encoder
Setting pipeline to NULL ...
Freeing pipeline ...
root@ubuntu:~# vainfo
error: XDG_RUNTIME_DIR not set in the environment.
error: can't connect to X server!
libva info: VA-API version 0.36.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_36
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.36 (libva 1.4.0)
vainfo: Driver version: Intel i965 driver for Intel® Ivybridge Desktop - 1.4.0
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
root@ubuntu:~#
vdpauinfo - это же вроде для radeon, нет?
