zippy Posted August 30, 2015 Posted August 30, 2015 Всем привет! Помогите разобраться с проблемой, не могу настроить проброс порта из внешней сети во внутреннюю. Прочитал тут много тем, сделал как описано, но ничего не выходит. Я отключил в IP->Service - > www В IP-> Firewall -> NAT прописал правило ( Chain: dstnat, Dst.Address: 31.200.238.163 Protocol: 6 (tcp), Dst. Port: 80, In. Interface: l2tp-out1 action: dst-nat to addresses: 192.168.88.2 to port 80) Ниже мой конфиг # jan/03/1970 01:08:59 by RouterOS 6.18 # software id = ZNF4-4V5L # /interface bridge add admin-mac=4C:5E:0C:B1:DA:13 auto-mac=no l2mtu=1598 name=bridge-local /interface ethernet set [ find default-name=ether1 ] name=ether1-gateway set [ find default-name=ether2 ] name=ether2-master-local set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local /ip neighbor discovery set ether1-gateway discover=no /interface wireless security-profiles add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=SweetHome supplicant-identity="" \ wpa-pre-shared-key="********" wpa2-pre-shared-key="********" /interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge security-profile=\ SweetHome ssid=SweetHome /ip pool add name=dhcp ranges=192.168.88.10-192.168.88.254 /ip dhcp-server add address-pool=dhcp disabled=no interface=bridge-local lease-time=10m name=default /interface l2tp-client add add-default-route=yes allow=pap,chap,mschap1,mschap2 connect-to=l2tp.podryad.tv default-route-distance=1 dial-on-demand=no disabled=no \ keepalive-timeout=60 max-mru=1450 max-mtu=1450 mrru=1600 name=l2tp-out1 password=******** profile=default-encryption user=******** /interface bridge port add bridge=bridge-local interface=ether2-master-local add bridge=bridge-local interface=wlan1 /ip address add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local network=192.168.88.0 /ip dhcp-client add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway /ip dhcp-server network add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1 /ip dns set allow-remote-requests=yes /ip dns static add address=192.168.88.1 name=router /ip settings set accept-redirects=yes rp-filter=loose /ip firewall filter add chain=forward dst-address=31.200.238.163 dst-port=80 in-interface=l2tp-out1 protocol=tcp add chain=input comment="default configuration" protocol=icmp add chain=input comment="default configuration" connection-state=established add chain=input comment="default configuration" connection-state=related add action=drop chain=input comment="default configuration" in-interface=ether1-gateway add chain=forward comment="default configuration" connection-state=established add chain=forward comment="default configuration" connection-state=related add action=drop chain=forward comment="default configuration" connection-state=invalid /ip firewall nat add action=dst-nat chain=dstnat dst-address=31.200.238.163 dst-port=80 in-interface=l2tp-out1 protocol=tcp to-addresses=192.168.88.2 to-ports=80 add action=masquerade chain=srcnat comment="default configuration" out-interface=l2tp-out1 src-address=192.168.88.0/24 /ip service set www disabled=yes /ip upnp set allow-disable-external-interface=no enabled=yes /tool mac-server set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local /tool mac-server mac-winbox set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local Вставить ник Quote
sangar Posted August 30, 2015 Posted August 30, 2015 Попробуй так,все должно заработать! Chain: dstnat,Protocol: 6 (tcp), Dst. Port: 80, action: dst-nat to addresses: 192.168.88.2 to port 80 Вставить ник Quote
zippy Posted August 30, 2015 Author Posted August 30, 2015 sangar, спасибо! Все работало, в заблуждение вводило то, что при попытке подключится из внутренней сети по внешнему IP ничего не происходило. При проверке через интерн с телефона все оказалось работает Вставить ник Quote
