Всем доброго времени суток.
В связи с необходимостью использования пулов IP адресов от разных провайдеров, при отсутствии собственной AS, возникла задача настроить Source Routing.
Интернет раздается пользователям с использованием NAT на SmartEdge100.
Попытки настроить Source Routing вместе с NAT на БРАС успехом не увенчались.
Привожу тестовый конфиг:
context test1
no ip domain-lookup
ip nat pool NAPT-pool1 napt paired-mode logging
address 192.168.188.10/32 port-block 1 to 15
ip nat pool NAPT-pool2 napt paired-mode logging
address 192.168.188.20/32 port-block 1 to 15
nat policy NAT-test1 enhanced
! Default class
drop
icmp-notification
! Named classes
access-group NAT-test-acl
class TCLASS
pool NAPT-pool1 test1
inbound-refresh udp
icmp-notification
class do-not-nat-L
ignore
inbound-refresh udp
icmp-notification
nat policy NAT-test2 enhanced
! Default class
drop
icmp-notification
! Named classes
class TCLASS
pool NAPT-pool2 test1
inbound-refresh udp
icmp-notification
class do-not-nat-L
ignore
inbound-refresh udp
icmp-notification
interface testnat multibind
ip address 192.168.177.1/24
interface uplink1
ip address 192.168.190.1/24
no logging console
interface uplink2
ip address 192.168.191.1/24
no logging console
policy access-list NAT-test-acl
seq 10 permit ip any host 192.168.177.1 class do-not-nat-L
seq 20 permit ip any class TCLASS
policy access-list FWD-test-acl
seq 10 permit ip host 192.168.188.20 any class FWDCLASS
seq 20 permit ip any class LCLASS
subscriber name testnat1
ip address 192.168.177.10
nat policy-name NAT-test1
subscriber name testnat2
ip address 192.168.177.20
nat policy-name NAT-test2
ip route 0.0.0.0/0 192.168.190.10
context local
forward policy SROUTE
ip access-group FWD-test-acl test1
class FWDCLASS
redirect destination ip next-hop 192.168.191.10
class TCLASS
class do-not-nat-L
port ethernet 2/2
dot1q pvc 130
forward policy SROUTE in
service clips
clips pvc 77005
bind subscriber testnat1@test1
clips pvc 77006
bind subscriber testnat2@test1
dot1q pvc 131
bind interface uplink1 test1
dot1q pvc 132
bind interface uplink2 test1
, где
192.168.177.10 - клиент1
192.168.177.20 - клиент2
192.168.188.10 - IP, в который натится клиент1
192.168.188.20 - IP, в который натится клиент2
192.168.190.10 - шлюз по умолчанию
192.168.191.10 - шлюз, в который должны уходить все пакеты, имеющие в поле "source IP" адрес 192.168.188.20
На каждый из шлюзов (192.168.190.10 и 192.168.191.10) повесил по машине со снифером.
Стучусь с клиента1 и клиента2 на произвольный хост через tcp или icmp.
Вижу, что пакеты в любом случае приходят только на 192.168.190.10
Возможно, кто-то уже решал подобную задачу на Redback-е?
Подскажите, где у меня может быть ошибка?
Возможно ли в принципе использование Source Routing совместно с NAT на SE100 в рамках одного контекста?
