allan_sundry Posted April 16, 2015 Posted April 16, 2015 Доброе время суток! Возникла проблема с Cisco SCE 8000 - при загрузке наблюдается такая картина: U-Boot 1.1.4 (May 13 2009 - 10:07:12) Freescale PowerPC CPU: Core: E600, Version: 0.2, (0x80040202) System: 8641D, Version: 2.1, (0x80900121) Clocks: CPU:1000 MHz, MPX: 400 MHz, DDR: 200 MHz, LBC: 25 MHz L2: Enabled Board: Simba (Board HW versions:99) PORICR (F80E0020) : 53000C47 PORBMSR (F80E0004) : 8E360001 PORDEVSR (F80E000C) : 02AF8347 PORPLLSR (F80E0000) : 00190008 PORIMPCR (F80E0008) : 0000007F PORDBGMSR (F80E0010) : 0E000000 CPU(local):0(0) Master(local):1(1) Tavor:1 Cofico:0 Cofico number:0 Standalone:0 U-Boot version info [FFF00000]: [uboot] ver = 2.1.0 build = 1 date = Wed May 13 10:07:13 IDT 2009 cwd = /auto/srg-sce-swinfra-usr/emb/users/gahazan/work/Emb/GPL/uboot-1.1.4-fsl/dev user = gahazan@csi-pqemb-b05 Bus I2C: init ... clear ... ready DRAM: DIMM1: 1x1024@200MHz Manf.ID: [ 7F 40 00 00 00 00 00 00 ] Manf.P/N: unavailable DIMM1: At 00000000, 1024MB, Method:1, ECC init ... filling .... done DIMM2: 1x1024@200MHz Manf.ID: [ 7F 40 00 00 00 00 00 00 ] Manf.P/N: unavailable DIMM2: At 40000000, 1024MB, Method:1, ECC init ... filling .... done Micro DRAM test 1: write ... read ... done Micro DRAM test 2: write ... read ... done DDR: 2048 MB Now running in RAM - U-Boot at: 0FFB7000. Relocation offset:EFF4B000 Initializing 8641 LBC LBCR:00000000 LCRR:80030004 LBC clock:50MHz CPLD status: ID (F9000000) : A1BC RST_SRC (F9000082) : 0080 INT_STAT (F9000006) : 0000 SMC CPLD status: ID (F9200000) : 816C PRESENT (F9200010) : C100 PWR_STAT (F9200012) : 019E LOCATION (F9200046) : 0009 RST_CAUSE (F9200052) : 2000 PWR_INT (F9200056) : 0010 Reset board devices (0608) FLASH: 64 MB Using default environment In: serial Out: serial Err: serial Net: eTSEC2: PHY is Marvell 88E1111S-Simba-direct (53410cc2) eTSEC3: PHY is Marvell 88E1111S-Simba-remote (d3410cc2) failed to read phy 03 with I2C addr 01000042 register 02. rc=1 failed to read phy 03 with I2C addr 01000042 register 03. rc=1 failed to read phy 03 with I2C addr 01000042 register 14. rc=1 eTSEC4: PHY is Marvell 88E1111S-Simba-remote (d3410cc2) eTSEC2, eTSEC3 [PRIME], eTSEC4 Hit any key to stop autoboot: 0 Importing basicdata to env ## Executing script at ffe80100 ubootscript: CF 0 Cofico power Cofico 0: installed, power OK, armed Cofico 1: installed, power OK, armed GEN_CONT1 (F920000A) : 0030 INFO: bootloc set to 0 INFO: kernel address set to ff600100 from kernel0. [kernel] ver = 2.3.0 build = 1 date = Tue May 12 16:24:53 IDT 2009 cwd = /auto/srg-sce-swinfra-usr/emb/users/gahazan/work/Emb/GPL/kernel-2.6.17-fsl/dev user = gahazan@csi-pqemb-b05 INFO: root device set to /dev/hda1 from rootdevcf0. ## Booting image at ff600100 ... Image Name: Linux-2.6.26.2 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1777587 Bytes = 1.7 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Using Simba machine description Total memory = 2048MB; using 4096kB for hash table (at cfc00000) Linux version 2.6.26.2 (gahazan@csi-pqemb-b05) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.36.0802211 2008-10-04)) #32 SMP Sun Apr 26 15:55:49 IDT 2009 simba_machine_early_init: start HW ID word:53000C47 simba_machine_early_init: Allocated 32MB at EC000000 for PCI memory buffer simba_machine_early_init: Allocated 4MB at EF800000 for slave boot buffer simba_machine_early_init: Allocated 6144KB at EF200000 for TSEC user buffer scos_allocate_master_pci_memory: master pci memory: size:32768K free:9060K simba_machine_early_init: end CPU maps initialized for 1 thread per core console [udbg0] enabled setup_arch: bootmem simba_setup_arch() INFO: simba_machine_setup_arch - start INFO: scos_flash_log_init_early: Flash log 'flash-log' initialized (early). area:0 fl_start:3E60000 fl_last:3E5FFFF console handover: boot [udbg0] -> real [flashlog0] simba_setup_arch() - end arch: exit Using Simba machine description Total memory = 2048MB; using 4096kB for hash table (at cfc00000) Linux version 2.6.26.2 (gahazan@csi-pqemb-b05) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.36.0802211 2008-10-04)) #32 SMP Sun Apr 26 15:55:49 IDT 2009 simba_machine_early_init: start HW ID word:53000C47 simba_machine_early_init: Allocated 32MB at EC000000 for PCI memory buffer simba_machine_early_init: Allocated 4MB at EF800000 for slave boot buffer simba_machine_early_init: Allocated 6144KB at EF200000 for TSEC user buffer scos_allocate_master_pci_memory: master pci memory: size:32768K free:9060K simba_machine_early_init: end CPU maps initialized for 1 thread per core console [udbg0] enabled INFO: simba_machine_setup_arch - start INFO: scos_flash_log_init_early: Flash log 'flash-log' initialized (early). area:0 fl_start:3E60000 fl_last:3E5FFFF console handover: boot [udbg0] -> real [flashlog0] console [scos-ser-1] enabled Initializing 8641 INFO: slot: 1 is_super_master: 1 TVR CPLD: ID [0000]: A1BC RST_SRC [0082]: 0080 SMC CPLD: ID [0000]: 816C PRESENT [0010]: C100 PWR_STAT [0012]: 019E RST_CAUSE [0052]: 2000 I2C early init WARNING : ' Atmel for fsl i2c bus was created ' WARNING : ' Atmel for fsl i2c bus was created ' Valid MAC 00:25:84:98:b5:64 (4) Initializing fan tray Initializing GPIO-0 to DFFF Initializing GPIO-0 to DFFF simba_machine_setup_arch: Reset Cofico boards simba_setup_arch_pcie: start simba_setup_arch_pcie: end INFO: simba_machine_setup_arch - end Zone PFN ranges: DMA 0 -> 196608 Normal 196608 -> 196608 HighMem 196608 -> 524288 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0 -> 524288 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520192 Kernel command line: root=/dev/hda1 systemid=:simba:0:ff600100:0 sysflags= console=ttyS0,9600 mpic: Setting up MPIC " MPIC " version 1.2 at f8040000, max 2 CPUs mpic: ISU size: 16, shift: 4, mask: f mpic: Initializing for 80 sources PID hash table entries: 4096 (order: 12, 16384 bytes) clocksource: timebase mult[2800000] shift[22] registered Console: colour dummy device 80x25 Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 2027372k/2097152k available (3488k kernel code, 68688k reserved, 212k data, 188k bss, 204k init) Mount-cache hash table entries: 512 mpic: requesting IPIs ... Processor 1 found. Synchronizing timebase Got ack score 299, offset 1000 score 299, offset 500 score 299, offset 250 score 299, offset 125 score 299, offset 62 score 247, offset 31 score -299, offset 15 score -139, offset 23 score -159, offset 27 score 297, offset 29 score -79, offset 28 Min 28 (score -187), Max 29 (score 297) Final offset: 28 (117/300) Brought up 2 CPUs net_namespace: 488 bytes NET: Registered protocol family 16 SKL: Creating sys - System wide SKL with 262144 bytes buffer SKL: Creating tmp - Temporary SKL with 65536 bytes buffer gfar(0) MAC 00:25:84:98:b5:64 taken from smc-eeprom gfar(1) MAC 00:14:a8:ff:48:05 self mac slot 1 gfar(2) MAC 00:25:84:98:b5:66 taken from smc-eeprom gfar(3) MAC 00:25:84:98:b5:67 taken from smc-eeprom Registering Simba devices simba_pci_arch_initcall: start SKL: Creating pci - Simba PCI with 262144 bytes buffer simba_pcie_setup_single_bridge: init PCI bridge 10:00.0 - pri_bus:10 sec_bus:18 sub_bus:3F memory:C0000000-DFFFFFFF simba_pcie_setup_single_bridge: init PCI bridge 18:00.0 - pri_bus:18 sec_bus:19 sub_bus:3F memory:C4000000-DFFFFFFF simba_pcie_setup_single_plx_bars: init PCI bridge 18:00.0 BAR at C0000000 simba_pcie_setup_single_bridge: init PCI bridge 19:04.0 - pri_bus:19 sec_bus:21 sub_bus:21 memory:C4000000-C7FFFFFF simba_pcie_setup_single_bridge: init PCI bridge 19:03.0 - pri_bus:19 sec_bus:22 sub_bus:22 memory:C8000000-CBFFFFFF simba_pcie_setup_single_bridge: init PCI bridge 19:02.0 - pri_bus:19 sec_bus:23 sub_bus:23 memory:CC000000-CFFFFFFF simba_pcie_setup_single_bridge: init PCI bridge 19:01.0 - pri_bus:19 sec_bus:28 sub_bus:3F memory:D0000000-DFFFFFFF simba_pcie_setup_single_bridge: init PCI bridge 28:00.0 - pri_bus:28 sec_bus:29 sub_bus:3F memory:D4000000-DFFFFFFF simba_pcie_setup_single_plx_bars: init PCI bridge 28:00.0 BAR at D0000000 simba_pcie_setup_single_bridge: init PCI bridge 29:04.0 - pri_bus:29 sec_bus:34 sub_bus:34 memory:D4000000-D7FFFFFF simba_pcie_setup_single_bridge: init PCI bridge 29:03.0 - pri_bus:29 sec_bus:35 sub_bus:35 memory:D8000000-DBFFFFFF simba_pcie_setup_single_bridge: init PCI bridge 29:02.0 - pri_bus:29 sec_bus:36 sub_bus:36 memory:DC000000-DFFFFFFF simba_pci_arch_initcall: end PCI: Probing PCI hardware PCI: 0000:10:00.0: class b20 doesn't match header type 01. Ignoring class. pci 0000:10:00.0: enabling device (0146 -> 0147) NET: Registered protocol family 2 IP route cache hash table entries: 32768 (order: 5, 131072 bytes) TCP established hash table entries: 131072 (order: 8, 1048576 bytes) TCP bind hash table entries: 65536 (order: 7, 524288 bytes) TCP: Hash tables configured (established 131072 bind 65536) TCP reno registered NET: Registered protocol family 1 highmem bounce pool size: 64 pages Installing knfsd (copyright (C) 1996 okir@monad.swb.de). msgmni has been set to 1401 io scheduler noop registered io scheduler deadline registered (default) Generic RTC Driver v1.07 Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0xf8004500 (irq = 42) is a 16550A console [ttyS0] enabled serial8250.0: ttyS1 at MMIO 0xf8004600 (irq = 28) is a 16550A brd: module loaded loop: module loaded Gianfar MII Bus: probed eth0: Gianfar Ethernet Controller Version 1.2, 00:14:a8:ff:48:05 eth0: Running with NAPI enabled eth0: 256/256 RX/TX BD ring size eth1: Gianfar Ethernet Controller Version 1.2, 00:25:84:98:b5:66 eth1: Running with NAPI enabled eth1: 256/256 RX/TX BD ring size eth2: Gianfar Ethernet Controller Version 1.2, 00:25:84:98:b5:67 eth2: Running with NAPI enabled eth2: 256/256 RX/TX BD ring size Uniform Multi-Platform E-IDE driver ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx ide_generic: please use "probe_mask=0x3f" module parameter for probing all legacy ISA IDE ports i2c /dev entries driver SKL: Creating i2c_mpc_skl - MPC I2C driver with 65536 bytes buffer SKL I2C MPC creation ok I2C_MPC:0 (mpc_restart_device:253) :restart device - send 16 clock Identify ds1337 RTC device create I2C 0 I2C_MPC:0 (mpc_restart_device:253) :restart device - send 16 clock create I2C 1 scos_skynet: SCOS skynet driver creates internal network over shared memory - v0.01 (Feb 15 2009 13:44:54) SKL: Creating log - SCOS skynet internal network driver with 131072 bytes buffer scos_mem_drv: SCOS memory driver - provides access to memory block - v0.01 (Dec 28 2008 09:21:42) SKL: Creating memdrv - SCOS memory access driver with 65536 bytes buffer gaccess: SCOS generic access driver - provides low access to memory, PCI & Eth phy - v0.02 (Dec 28 2008 09:21:39) SKL: Creating gaccess - Generic access driver with 65536 bytes buffer scos_virtual_phy: SCOS virtual PHY driver - v0.01 (Dec 28 2008 09:21:42) scos-virtual_mdio_bus: probed scos_serial_buf_proc_create: Registering serial buf procs scos_plx8508_pci_probe: 0000:18:00.0 - probing for PLX8508 scos_plx8508_pci_probe_proc_data_mem_regs: 0000:18:00.0 - PLX8508 proc data added successfully at c0000000 INFO: scos_reg_mon_early_init: Reg monitor hw-mon-regs early init done scos_plx8508_pci_probe: 0000:19:01.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:19:02.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:19:03.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:19:04.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:28:00.0 - probing for PLX8508 scos_plx8508_pci_probe_proc_data_mem_regs: 0000:28:00.0 - PLX8508 proc data added successfully at d0000000 scos_plx8508_pci_probe: 0000:29:00.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:29:02.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:29:03.0 - probing for PLX8508 scos_plx8508_pci_probe: 0000:29:04.0 - probing for PLX8508 scos_core_info: SCOS core info procfs - v0.01 (Dec 28 2008 09:21:44) INFO: scos_dump_init: SCOS dump init simba_mtd_init: chip probing with cfi_probe bootflash: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 bootflash: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. simba_mtd_init: name:bootflash, size:65536K Creating 14 MTD partitions on "bootflash": 0x03f00000-0x03f80000 : "uboot0" 0x03f80000-0x04000000 : "uboot1" 0x03ec0000-0x03ee0000 : "uboot-env0" 0x03ee0000-0x03f00000 : "uboot-env1" 0x03e80000-0x03ea0000 : "select0" 0x03ea0000-0x03ec0000 : "select1" 0x03e40000-0x03e60000 : "log0" 0x03e60000-0x03e80000 : "log1" 0x03e00000-0x03e20000 : "obfl0" 0x03e20000-0x03e40000 : "obfl1" 0x03600000-0x03a00000 : "kernel0" 0x03a00000-0x03e00000 : "kernel1" 0x02000000-0x03600000 : "maint" 0x00000000-0x02000000 : "spare0" INFO: simba_dump_initcall: Simba dump init scos simba i2c drivers init I2C probe tavor-mux i2c_bus: 0 mux_addr: 112 Identify ds1337 RTC device init mux i2c buses bus 0 I2C_MPC:0 (mpc_restart_device:253) :restart device - send 16 clock bus 1 I2C_MPC:0 (mpc_restart_device:253) :restart device - send 16 clock Cofico I2C bus create dev: 0 adapter : 2 Cofico I2C bus create dev: 1 adapter : 2 simba_pcie_8641_pci_probe: 0000:10:00.0 - probing for 8641 simba_pcie_8641_pci_probe: 0000:36:00.0 - probing for 8641 simba_devices_reg_remote:Registering plaform devices for remote CPU 06 at DC000000 simba_pcie_8641_pci_probe: 0000:35:00.0 - probing for 8641 simba_devices_reg_remote:Registering plaform devices for remote CPU 05 at D8000000 simba_pcie_8641_pci_probe: 0000:34:00.0 - probing for 8641 simba_devices_reg_remote:Registering plaform devices for remote CPU 04 at D4000000 simba_pcie_8641_pci_probe: 0000:23:00.0 - probing for 8641 simba_devices_reg_remote:Registering plaform devices for remote CPU 03 at CC000000 simba_pcie_8641_pci_probe: 0000:22:00.0 - probing for 8641 simba_devices_reg_remote:Registering plaform devices for remote CPU 02 at C8000000 simba_pcie_8641_pci_probe: 0000:21:00.0 - probing for 8641 scos_allocate_slave_pci_memory: slave pci memory: size:32768K free:30720K simba_devices_reg_remote:Registering plaform devices for remote CPU 01 at C4000000 simba_mdio_i2c_bus: Simba MDIO over I2C bus driver - v0.01 (Apr 26 2009 15:55:38) SKL: Creating mdio_i2c_bus - Simba MDIO I2C bus driver with 65536 bytes buffer simba-mdio_i2c: probed simba_phy_88e1111: Simba Marvell 88E1111 PHY driver - v1.0 (Apr 26 2009 15:55:38) simba_phy_e1111_probe: Probing PHY 2:01 SKL: Creating phy-2:01 - Simba 88E1111 PHY driver with 65536 bytes buffer simba_phy_e1111_probe: Probing PHY 2:02 SKL: Creating phy-2:02 - Simba 88E1111 PHY driver with 65536 bytes buffer WARNING:simba_mdio_i2c_bus_write: write error to MDIO I2C bus. phy:02 reg:5B i2c_dev:0042 i2c_reg:1B is_remote:1 rc:-1 value:8686 Simba Marvell 88E1111 - remote: probe of 2:02 failed with error -1 simba_phy_e1111_probe: Probing PHY 2:03 SKL: Creating phy-2:03 - Simba 88E1111 PHY driver with 65536 bytes buffer INFO: simba_wdog_init: Init INFO:scos_wdog_kernel_init: 'wdog-kernel' HW status: enabled:1 time left[mSec]:572960 =~9m IDE phys mem cs0: f9700000...f9701000 (size 00001000) IDE phys mem cs1: f9708000...f9709000 (size 00001000) hda: UNIGEN FLASH, CFA DISK drive ide0 at 0xf11f6000-0xf11f600e,0xf11f800c on irq 73 hda: max request size: 128KiB hda: 510976 sectors (261 MB) w/0KiB Cache, CHS=998/16/32 hda: scos_cofico_debug: SCOS cofico debug - v0.01 (Mar 3 2009 16:43:08) Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (16384 buckets, 65536 max) ip_tables: (C) 2000-2006 Netfilter Core Team ClusterIP Version 0.8 loaded successfully arp_tables: (C) 2002 David S. Miller TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. INFO: simba_pcie_e2e_crc_run_fixups: enable PCI E2E CRC VFS: Cannot open root device "hda1" or unknown-block(3,1) Please append a correct "root=" boot option; here are the available partitions: 1f00 512 mtdblock0 (driver?) 1f01 512 mtdblock1 (driver?) 1f02 128 mtdblock2 (driver?) 1f03 128 mtdblock3 (driver?) 1f04 128 mtdblock4 (driver?) 1f05 128 mtdblock5 (driver?) 1f06 128 mtdblock6 (driver?) 1f07 128 mtdblock7 (driver?) 1f08 128 mtdblock8 (driver?) 1f09 128 mtdblock9 (driver?) 1f0a 4096 mtdblock10 (driver?) 1f0b 4096 mtdblock11 (driver?) 1f0c 22528 mtdblock12 (driver?) 1f0d 32768 mtdblock13 (driver?) 0300 255488 hda driver: ide-disk Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(3,1) Rebooting in 180 seconds.. 5 Восстановить по приведенной на shop.nag.ru инструкции не получилось т.к. при отмене автозагрузки командная среда совершенно другая. Помогите восстановить работоспособность Cisco SCE 8000. Возможно кто-то может подсказать инструкцию да командного окружения которое отличается от рассмотренного тут. Буду благодарен, если кто-то поделится образом CF с работающей Cisco SCE 8000. Заранее всем спасибо! Вставить ник Quote
