Пытаюсь настроить немножко RSVP-TE в академических целях. Как обычно начинаются непонятки при использовании разных вендоров.
Хочу настроить чтобы LSP2 использовался как основной.
admin@mx80-pe_Himki> show configuration protocols mpls
traceoptions {
   file mpls-log size 10m files 3;
   flag cspf;
   flag error;
   flag state;
label-switched-path Ximki>M10 {
   from 172.16.16.8;
   to 172.16.16.6;
label-switched-path Ximki>M9 {
   from 172.16.16.8;
   to 172.16.16.2;
path TO_M9_MED {
   172.16.16.5 loose;
interface xe-0/0/0.78;
admin@mx80-pe_Himki> show route table inet.3
inet.3: 2 destinations, 2 routes (2 active, 0 holddown, 0 hidden)
+ = Active Route, - = Last Active, * = Both
172.16.16.2/32     *[RSVP/7/1] 00:17:24, metric 2
                   > to 185.13.115.73 via xe-0/0/0.78, label-switched-path Ximki>M9
172.16.16.6/32     *[RSVP/7/1] 8w0d 21:38:42, metric 1
                   > to 185.13.115.73 via xe-0/0/0.78, label-switched-path Ximki>M10
admin@mx80-pe_Himki> show ted database 172.16.16.6
TED database: 0 ISIS nodes 44 INET nodes
ID                            Type Age(s) LnkIn LnkOut Protocol
172.16.16.6                   Rtr  967257     6      4 OSPF(0.0.0.0)
   To: 185.13.115.73-1, Local: 185.13.115.73, Remote: 0.0.0.0
     Local interface index: 0, Remote interface index: 0
   To: 185.13.115.85-1, Local: 185.13.115.84, Remote: 0.0.0.0
   To: 95.215.98.9-1, Local: 95.215.98.9, Remote: 0.0.0.0
   To: 185.13.115.69-1, Local: 185.13.115.69, Remote: 0.0.0.0
admin@mx80-pe_Himki> show ted database 172.16.16.2
172.16.16.2                   Rtr  3577527     7      4 OSPF(0.0.0.0)
   To: 195.128.59.173-1, Local: 195.128.59.174, Remote: 0.0.0.0
   To: 185.13.115.85-1, Local: 185.13.115.85, Remote: 0.0.0.0
   To: 195.128.62.22-1, Local: 195.128.62.21, Remote: 0.0.0.0
   To: 95.215.98.182-1, Local: 95.215.98.181, Remote: 0.0.0.0
admin@mx80-pe_Himki> show ted database 172.16.16.5
172.16.16.5                   Rtr  3581494     6      4 OSPF(0.0.0.0)
   To: 185.13.115.77-1, Local: 185.13.115.77, Remote: 0.0.0.0
   To: 185.13.115.81-1, Local: 185.13.115.81, Remote: 0.0.0.0
   To: 195.128.59.173-1, Local: 195.128.59.173, Remote: 0.0.0.0
   To: 195.128.59.177-1, Local: 195.128.59.177, Remote: 0.0.0.0
Делаю Primary path через 172.16.16.5 и
admin@mx80-pe_Himki# show protocols mpls
traceoptions {
   flag cspf;
   flag error;
   flag state;
   from 172.16.16.8;
   to 172.16.16.6;
   from 172.16.16.8;
   to 172.16.16.2;
   primary TO_M9_MED;
path TO_M9_MED {
   172.16.16.5 loose;
[edit]
admin@mx80-pe_Himki> show mpls lsp name Ximki>M9 extensive
Ingress LSP: 2 sessions
172.16.16.2
 From: 172.16.16.8, State: Dn, ActiveRoute: 0, LSPname: Ximki>M9
 ActivePath: (none)
 LSPtype: Static Configured, Penultimate hop popping
 LoadBalance: Random
 Encoding type: Packet, Switching type: Packet, GPID: IPv4
 Primary   TO_M9_MED        State: Dn
   Priorities: 7 0
   SmartOptimizeTimer: 180
   Will be enqueued for recomputation in 27 second(s).
  30 Apr 14 13:51:38.796 Deselected as active
  29 Apr 14 13:51:38.795 CSPF failed: no route toward 172.16.16.2
  28 Apr 14 13:51:38.790 Clear Call
  27 Apr 14 13:42:52.133 Selected as active path
  26 Apr 14 13:42:52.133 Record Route:  185.13.115.73 185.13.115.85
  25 Apr 14 13:42:52.132 Up
  24 Apr 14 13:42:52.032 Originate Call
  23 Apr 14 13:42:52.032 CSPF: computation result accepted  185.13.115.73 185.13.115.85
  22 Apr 14 13:42:52.025 Clear Call
  21 Apr 14 13:42:52.024 Deselected as active
  20 Apr 14 13:23:36.304 Selected as active path
  19 Apr 14 13:23:36.303 Record Route:  185.13.115.73 185.13.115.85
  18 Apr 14 13:23:36.303 Up
  17 Apr 14 13:23:36.204 Originate Call
  16 Apr 14 13:23:36.204 CSPF: computation result accepted  185.13.115.73 185.13.115.85
  15 Apr 14 13:23:14.661 CSPF failed: no route toward 172.16.16.2
  14 Apr 14 13:22:44.753 Deselected as active
  13 Apr 14 13:22:44.753 CSPF failed: no route toward 172.16.16.2
  12 Apr 14 13:22:44.744 Clear Call
  11 Apr 14 13:20:04.509 Selected as active path
  10 Apr 14 13:20:04.508 Record Route:  185.13.115.73 185.13.115.85
   9 Apr 14 13:20:04.506 Up
   8 Apr 14 13:20:04.406 Originate Call
   7 Apr 14 13:20:04.406 CSPF: computation result accepted  185.13.115.73 185.13.115.85
   6 Apr 14 13:20:04.403 Clear Call
   5 Apr 14 13:19:49.330 185.13.115.73: Explicit Route: bad loose route[9 times]
   4 Apr 14 13:15:55.320 Originate Call
   3 Apr 14 13:15:32.240 CSPF failed: no route toward 172.16.16.2[7 times]
   2 Apr 14 13:13:05.241 CSPF failed: no route toward 195.128.59.177[3 times]
   1 Apr 14 13:12:07.665 CSPF failed: no route toward 172.16.16.5[42 times]
 Created: Tue Apr 14 12:52:37 2015
Total 1 displayed, Up 0, Down 1
admin@mx80-pe_Himki> show log mpls-log
Apr 14 13:51:38.697603 Allocated primary path
Apr 14 13:51:38.698653 MPLS config finished.
Apr 14 13:51:38.780433 mpls LSP update start
Apr 14 13:51:38.790026 Reconfig LSP Ximki>M10 0x270471c
Apr 14 13:51:38.790114 Reconfig LSP Ximki>M9 0x2704e38
Apr 14 13:51:38.790200 mpls LSP Ximki>M9 clearing restart flag
Apr 14 13:51:38.790263 mpls lsp Ximki>M9 primary Clear Call
Apr 14 13:51:38.791547 RPD_MPLS_PATH_DOWN: MPLS path  down on LSP Ximki>M9
Apr 14 13:51:38.791605 CSPF adding path Ximki>M9(primary TO_M9_MED) to CSPF queue 0
Apr 14 13:51:38.791630 CSPF delay CSPF job, re-configuration in progress.
Apr 14 13:51:38.791702 mpls LSP update complete
Apr 14 13:51:38.791732 CSPF creating CSPF job
Apr 14 13:51:38.795285
Apr 14 13:51:38.795323 CSPF for path Ximki>M9(primary TO_M9_MED), begin at 0000.0000.0000.00 , starting
Apr 14 13:51:38.795370  bandwidth: CT0=0bps ; setup priority: 0; random
Apr 14 13:51:38.795425 CSPF ERO 1 loose next hop to 172.16.16.5
Apr 14 13:51:38.795470 CSPF starting from 0000.0000.0000.00 (172.16.16.8) to 172.16.16.5, hoplimit 254
Apr 14 13:51:38.795553 CSPF Reached target
Apr 14 13:51:38.795589 CSPF completed in 0.000131s
Apr 14 13:51:38.795644 CSPF ERO for Ximki>M9(primary TO_M9_MED) (3 hops)
Apr 14 13:51:38.795671  node 185.13.115.73/32
Apr 14 13:51:38.795693  node 185.13.115.85/32
Apr 14 13:51:38.795714  node 195.128.59.173/32
Apr 14 13:51:38.795734 CSPF credibility 0
Apr 14 13:51:38.795755 CSPF final destination 172.16.16.2
Apr 14 13:51:38.795794 CSPF starting from 0000.0000.0000.00 (172.16.16.5) to 172.16.16.2, hoplimit 251
Apr 14 13:51:38.795850 CSPF completed in 0.000066s
Apr 14 13:51:38.795875 CSPF couldn't find a route to 172.16.16.2
Apr 14 13:51:38.795931 mpls lsp Ximki>M9 primary CSPF failed: no route toward 172.16.16.2
Apr 14 13:51:38.795957 CSPF for path Ximki>M9(primary TO_M9_MED) done!
Apr 14 13:51:38.796330 mpls lsp Ximki>M9 primary Deselected as active
Apr 14 13:51:38.797641 RPD_MPLS_LSP_DOWN: MPLS LSP Ximki>M9 down on primary(TO_M9_MED)
Apr 14 13:52:08.190991 CSPF adding path Ximki>M9(primary TO_M9_MED) to CSPF queue 0
Apr 14 13:52:08.191560 CSPF creating CSPF job
Apr 14 13:52:08.191677
Apr 14 13:52:08.191706 CSPF for path Ximki>M9(primary TO_M9_MED), begin at 0000.0000.0000.00 , starting
Apr 14 13:52:08.191754  bandwidth: CT0=0bps ; setup priority: 0; random
Apr 14 13:52:08.191809 CSPF ERO 1 loose next hop to 172.16.16.5
Apr 14 13:52:08.191854 CSPF starting from 0000.0000.0000.00 (172.16.16.8) to 172.16.16.5, hoplimit 254
Apr 14 13:52:08.192053 CSPF Reached target
Apr 14 13:52:08.192091 CSPF completed in 0.000153s
Apr 14 13:52:08.192151 CSPF ERO for Ximki>M9(primary TO_M9_MED) (3 hops)
Apr 14 13:52:08.192177  node 185.13.115.73/32
Apr 14 13:52:08.192198  node 185.13.115.85/32
Apr 14 13:52:08.192219  node 195.128.59.173/32
Apr 14 13:52:08.192238 CSPF credibility 0
Apr 14 13:52:08.192258 CSPF final destination 172.16.16.2
Apr 14 13:52:08.192299 CSPF starting from 0000.0000.0000.00 (172.16.16.5) to 172.16.16.2, hoplimit 251
Apr 14 13:52:08.192355 CSPF completed in 0.000067s
Apr 14 13:52:08.192380 CSPF couldn't find a route to 172.16.16.2
Apr 14 13:52:08.192436 mpls lsp Ximki>M9 primary CSPF failed: no route toward 172.16.16.2
Apr 14 13:52:08.192460 CSPF for path Ximki>M9(primary TO_M9_MED) done!
inet.3: 1 destinations, 1 routes (1 active, 0 holddown, 0 hidden)
172.16.16.6/32     *[RSVP/7/1] 8w0d 21:51:04, metric 1
куда копать?:)
лупбеки в мплс загоните.
from 172.16.16.8 уже давно не пишут - остатки прошлого.
ну и картинку то хорошо было бы
лупбеки куда загнать?:) если вы про OSPF они там есть, если как interface lo0.0 в контексте MPLS то я не уверен что поможет...
картинка есть, какую еще нужно?
чего посоветовать - проверяйте интерфейсы, фемели мплс. чего-то забыли
да это всё уже проверено..самое интересное что напрямую на 16.5 и 16.2 LSP поднимаются.
не работает именно rsvp ero
Тогда такой квест. Линк между .2 и .6 потушите и постройте лсп от.8 до .2
Traffic engineering в оспф прописан? Router-id везде есть?
Может быть, где-то есть router-id, где-то берется из лупбека, может они совпадают?
нашел :)
не хватало RSVP-нейбора на cat65, невнимательность :(
спасибо!
