схема
dhcp-server <--10port vlan 11,12,20>  orion A10  <vlan 12,20 9port--26port vlan 12,20>  orion A26 <vlan 12 1port--> dhcp клиент
если на A10 просто прогнать влан то клиент получает адрес.
Но,если на a10
create vlan 11,12,20 active
interface port 1
switchport access vlan 11
switchport access egress-allowed vlan remove 1
ip dhcp snooping information option vlan-list 11
interface port 9
switchport trunk allowed vlan 12,20
switchport trunk untagged vlan remove 1
switchport mode trunk
ip dhcp snooping trust
interface port 10
switchport trunk allowed vlan 11,12,20
ip dhcp snooping
ip dhcp information option remote-id string 192.168.10.11
То клиент перестаёт получать адрес,
в дебаге на a26
DHCPS PACKET: inserted an option 82(subscriber-id 00:06:00:0C:01:00:00:01 remote
-id 31:39:32:2E:31:36:38:2E:32:30:33:2E:34:32) into this request packet(type:1), new packet length 315
%Jan 18 20:39:30 2006 DHCPS: rcv packet from client e8-11-32-67-38-0b,
 interface Ethernet1/1(portID 0x1000001), length 361,
 type DHCPDISCOVER, opcode BOOTREQUEST, stacking 0
%Jan 18 20:39:30 2006 DHCPS: flood dhcp pkt from Ethernet1/1 dst mac ff-ff-ff-ff-ff-ff
        to all up port except input port Ethernet1/1 in vlan 12
%Jan 18 20:39:30 2006 DHCPS: do binding info from client e8-11-32-67-38-0b,
        interface Ethernet1/1, type DHCPDISCOVER, flag 0
%Jan 18 20:39:31 2006 The value of the segment iph->tot_len 306 is not equal to skb->len 334
%Jan 18 20:39:31 2006 DHCPS:dhcpSnoopingCheckIPUDPheader failed, return (-4)!
При этом в логе дшсп сервера опции именно A26
Отключаю всё что касаемо DHCP snooping на a10 то на a26 всё ок:
%Jan 18 20:43:04 2006 DHCPS: rcv packet from client e8-11-32-67-38-0b,
%Jan 18 20:43:04 2006 DHCPS: flood dhcp pkt from Ethernet1/1 dst mac ff-ff-ff-ff
-ff-ff
%Jan 18 20:43:04 2006 DHCPS: do binding info from client e8-11-32-67-38-0b,
%Jan 18 20:43:05 2006 DHCPS PACKET: stripped an option 82 from this reply packet
(type:2), new packet length 300
%Jan 18 20:43:05 2006 DHCPS: rcv packet to client e8-11-32-67-38-0b,
        interface Ethernet1/26(portID 0x100001A), length 346,
        type DHCPOFFER, opcode BOOTREPLY, stacking 0
%Jan 18 20:43:05 2006 DHCPS: Get send port Ethernet1/1 for DHCP reply unicast pa
cket
       for dhcp client e8-11-32-67-38-0b in vlan 12
Ну и далее весь процес получения. Клиент получил адрес.
С A10 в 1 порту (11 влан) клиент получает адреса.
