rdntw Posted February 5, 2015 Posted February 5, 2015 Решил потестить L2VPN, собрал такую схему ПК > access port 504 SW1 trunk > MX2 > MPLS CORE > MX1 > SW2 (SVI 504) ПК 1.1.1.1/30 SW2 (SVI 504) 1.1.1.2/30 MX-1# show routing-instances L2VPN_TEST instance-type l2vpn; interface xe-0/0/2.502; route-distinguisher 172.16.16.3:50; vrf-target target:2906:151; protocols { l2vpn { encapsulation-type ethernet-vlan; no-control-word; interface xe-0/0/2.502; site Butovo { site-identifier 102; interface xe-0/0/2.502 { remote-site-id 103; } } } } [edit] MX-2# show routing-instances L2VPN_TEST instance-type l2vpn; interface ae0.502; route-distinguisher 172.16.16.4:50; vrf-target target:2906:151; protocols { l2vpn { encapsulation-type ethernet-vlan; no-control-word; interface ae0.502; site Med { site-identifier 103; interface ae0.502 { remote-site-id 102; } } } } [edit] MX-2# Магистральные линки MX-1> show configuration interfaces xe-0/0/0 mtu 1600; unit 0 { family inet { address xxxxxxxx/30; } family mpls; } MX-1> MX-2> show configuration interfaces ge-1/1/9 mtu 1600; unit 0 { family inet { address xxxxxxxx/30; } family mpls; } MX-2> Пинг между PE. MX-1> ping 172.16.16.4 source 172.16.16.3 do-not-fragment size 1488 PING 172.16.16.4 (172.16.16.4): 1488 data bytes 1496 bytes from 172.16.16.4: icmp_seq=0 ttl=62 time=1.796 ms 1496 bytes from 172.16.16.4: icmp_seq=1 ttl=62 time=1.777 ms ^C --- 172.16.16.4 ping statistics --- 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max/stddev = 1.777/1.786/1.796/0.010 ms MX-1> ping 172.16.16.4 source 172.16.16.3 do-not-fragment size 1489 PING 172.16.16.4 (172.16.16.4): 1489 data bytes ^C --- 172.16.16.4 ping statistics --- 2 packets transmitted, 0 packets received, 100% packet loss MX-1> MX-2> show interfaces ae0.502 extensive Logical interface ae0.502 (Index 5372) (SNMP ifIndex 6334) (Generation 217424) Flags: SNMP-Traps 0x0 VLAN-Tag [ 0x8100.502 ] Encapsulation: VLAN-CCC Statistics Packets pps Bytes bps Bundle: Input : 90958 0 7321598 608 Output: 2948 0 235552 0 Adaptive Statistics: Adaptive Adjusts: 0 Adaptive Scans : 0 Adaptive Updates: 0 Link: ge-1/1/0.502 Input : 61812 0 4842524 272 Output: 2885 0 231520 0 ge-1/1/1.502 Input : 29146 0 2479074 336 Output: 63 0 4032 0 Marker Statistics: Marker Rx Resp Tx Unknown Rx Illegal Rx ge-1/1/0.502 0 0 0 0 ge-1/1/1.502 0 0 0 0 Protocol ccc, MTU: 1522, Generation: 217107, Route table: 0 Flags: Is-Primary MX-2> MX-1> show interfaces xe-0/0/2.502 extensive Logical interface xe-0/0/2.502 (Index 1027) (SNMP ifIndex 2693) (Generation 1463941) Flags: SNMP-Traps 0x0 VLAN-Tag [ 0x8100.502 ] Encapsulation: VLAN-CCC Traffic statistics: Input bytes : 235552 Output bytes : 7288747 Input packets: 2948 Output packets: 90943 Local statistics: Input bytes : 0 Output bytes : 0 Input packets: 0 Output packets: 0 Transit statistics: Input bytes : 235552 0 bps Output bytes : 7288747 1576 bps Input packets: 2948 0 pps Output packets: 90943 2 pps Protocol ccc, MTU: 1522, Generation: 1464068, Route table: 0 Flags: Is-Primary На ядровых линках 1600 (на магистрали между MX-ами стоит 6509) могу оттуда что-то показать... 6509#sh run int t5/4 <<<<<<< to core interface TenGigabitEthernet5/4 to core mtu 1586 ip address xxxxxxxxxxx 255.255.255.252 load-interval 30 mpls traffic-eng tunnels mpls ip ip rsvp signalling hello end 6509#sh run int g7/23 <<<<<<< to PE_MX2 interface GigabitEthernet7/23 to PE_MX2 mtu 1586 ip address xxxxxxxxxxx 255.255.255.252 ip ospf 1 area 0 mpls traffic-eng tunnels mpls ip ip rsvp signalling hello end Скрин того сколько проходит. В какую сторону смотреть? Вставить ник Quote
rdntw Posted February 5, 2015 Author Posted February 5, 2015 с MXpe1 > 6509 > MXcore> MXpe2 MXpe1> ping mpls rsvp MXpe1>MXcore sweep 100! 5052. 2576. 1340! 2580. 1960. 1652. 1496! 1576. 1536! 1556! 1568! 1580. 1576. 1572! --- lsp ping sweep result--- Maximum Transmission Unit (MTU) is 1572 bytes MXpe1> ping mpls rsvp MXpe1>MXpe2 sweep 100! 5052. 2576. 1340! 2580. 1960. 1652. 1496! 1576. 1536. 1516! 1528. 1524. 1520. --- lsp ping sweep result--- Maximum Transmission Unit (MTU) is 1516 bytes странно. ведь между MXcore и MXpe2 MXcore> show interfaces xe-1/2/2.0 extensive | match mtu Protocol inet, MTU: 1586, Generation: 1186, Route table: 0 Protocol mpls, MTU: 1574, Maximum labels: 3, Generation: 1189, Route table: 0 Protocol multiservice, MTU: Unlimited, Generation: 1187, Route table: 0 MXpe2> show interfaces xe-0/0/0.0 extensive | match mtu Protocol inet, MTU: 1586, Generation: 1407843, Route table: 0 Protocol mpls, MTU: 1574, Maximum labels: 3, Generation: 1407936, Route table: 0 Protocol multiservice, MTU: Unlimited, Generation: 1407844, Route table: 0 Вставить ник Quote
ugluck Posted February 7, 2015 Posted February 7, 2015 Ping между PE 1488 max означает, что в ядре совсем не 1600 и не 1586, а 1524 (1488 payload+8 icmp+20 ip). При l2 VPN в ядре к полному пакету IP добавляется eth-заголовок 18 и пара-тройка меток по 4, тоесть 1500 превращается в 1526 или 1530(похоже, именно Ваш случай, как раз 6Б разница). И не пролазит в 1524. Делайте трассировки и пингуйте каждый хоп. Вставить ник Quote
rdntw Posted February 8, 2015 Author Posted February 8, 2015 Нашел затык между ядровым роутером и PE. MX_CORE <> MX1 Но ведь между ними 1600! На одном тестовом участке помогло увеличение до 9к :) Хотелось бы понять почему при 1.6 не помещается... MX_CORE> ping 172.16.16.3 source 172.16.16.2 do-not-fragment size 1488 PING 172.16.16.3 (172.16.16.3): 1488 data bytes 1496 bytes from 172.16.16.3: icmp_seq=0 ttl=64 time=2.126 ms ^C --- 172.16.16.3 ping statistics --- 1 packets transmitted, 1 packets received, 0% packet loss round-trip min/avg/max/stddev = 2.126/2.126/2.126/0.000 ms MX_CORE> ping 172.16.16.3 source 172.16.16.2 do-not-fragment size 1489 PING 172.16.16.3 (172.16.16.3): 1489 data bytes ^C --- 172.16.16.3 ping statistics --- 2 packets transmitted, 0 packets received, 100% packet loss MX_CORE> show route 172.16.16.3 table inet.0 inet.0: 536495 destinations, 1545018 routes (536006 active, 72 holddown, 1712 hidden) + = Active Route, - = Last Active, * = Both 172.16.16.3/32 *[OSPF/10] 2w2d 05:06:26, metric 1 > to xxxxxxxx via xe-1/2/2.0 MX_CORE> MX_CORE> show configuration interfaces xe-1/2/2 description to_MX1; mtu 1600; unit 0 { family inet { address xxxxxxxx1/30; } family mpls; } ====================================================== MX1> ping 172.16.16.2 source 172.16.16.3 do-not-fragment size 1488 PING 172.16.16.2 (172.16.16.2): 1488 data bytes 1496 bytes from 172.16.16.2: icmp_seq=0 ttl=64 time=4.133 ms 1496 bytes from 172.16.16.2: icmp_seq=1 ttl=64 time=2.512 ms ^C --- 172.16.16.2 ping statistics --- 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max/stddev = 2.512/3.322/4.133/0.811 ms MX1> ping 172.16.16.2 source 172.16.16.3 do-not-fragment size 1489 PING 172.16.16.2 (172.16.16.2): 1489 data bytes ^C --- 172.16.16.2 ping statistics --- 2 packets transmitted, 0 packets received, 100% packet loss MX1> show route 172.16.16.2 table inet.0 inet.0: 5787 destinations, 5792 routes (5787 active, 0 holddown, 0 hidden) + = Active Route, - = Last Active, * = Both 172.16.16.2/32 *[OSPF/10] 2w2d 05:07:14, metric 1 > to xxxxxxxxxxx via xe-0/0/0.0 MX1> MX1> show configuration interfaces xe-0/0/0 mtu 1600; unit 0 { family inet { sampling { input; output; } address xxxxxxxx2/30; } family mpls; } MX1> Вставить ник Quote
