<test>display transceiver
Port Ethernet0/0/1 :Valid only on optical interface.
Port Ethernet0/0/24 :Valid only on optical interface.
Port GigabitEthernet0/0/1 :Valid only on optical interface.
Port GigabitEthernet0/0/2 :Valid only on optical interface.
--вставил модуль--
[test]
Jan 1 2008 00:11:13 test %%01SRM/3/INOUT(l)[0]:The optical module on interface GigabitEthernet0/0/1 is plugged IN.
Jan 1 2008 00:11:14 test SRM/3/PortPhysicalPortTypeChange:OID 1.3.6.1.4.1.2011.5.25.129.2.5.13 port type changed. (EntityPhysicalIndex=28, BaseTrapSeverity=4, BaseTrapProbableCause=1024, BaseTrapEventType=8, EntPhysicalName=GigabitEthernet0/0/1, BaseTrapLastPortType=1, BaseTrapCurPortType=2)
GigabitEthernet0/0/1 transceiver information:
Common information:
Transceiver Type :1000_BASE_LX_SFP
Connector Type :LC
Wavelength(nm) :1310
Transfer Distance(m) :10000(9um),550(50um),550(62.5um)
Digital Diagnostic Monitoring :NO
Vendor Name :OEM
Vendor Part Number :SFP-LH-SM
Ordering Name :
Manufacture information:
Manu. Serial Number :FNS115000188
Manufacturing Date :2008-12-01
Vendor Name :OEM
--вынул модуль--
<test>
Jan 1 2008 00:12:45 test %%01SRM/3/INOUT(l)[1]:The optical module on interface GigabitEthernet0/0/1 is plugged OUT.
Jan 1 2008 00:12:46 test SRM/3/PortPhysicalPortTypeChange:OID 1.3.6.1.4.1.2011.5.25.129.2.5.13 port type changed. (EntityPhysicalIndex=28, BaseTrapSeverity=4, BaseTrapProbableCause=1024, BaseTrapEventType=8, EntPhysicalName=GigabitEthernet0/0/1, BaseTrapLastPortType=2, BaseTrapCurPortType=1
