Vladimir_BG
Пользователи-
Публикации
9 -
Зарегистрирован
Посещение
О Vladimir_BG
Звание
Абитуриент
Контакты
ICQ
Array
SASC-NG Problem
тему ответил в Vladimir_BG пользователя Vladimir_BG в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
Do you think that we should change something?? -
SASC-NG Problem
We are connecting to CCAM server or NewCS server.. So no key files, just a CardServer in LAN -
SASC-NG Problem
As in the tutorial keys are in: /etc/camfiles/cardclient.conf Is this what u ment or not? -
SASC-NG Problem
Hi there.. We do not use OSCAM but NewCS and CCCAM.. It is in local network.. The path for the cccam and newcs server is defined like this in cardclient.conf file: cccam2:192.168.1.92:12000:0:test1:test1 newcamd:192.168.1.92:34000:0:test2:test2:01020304050607080910111213141516 One more time.. I think that there is nothing wrong with the server or configs because it works for 5 - 10 minutes and then stops for 10 seconds.. After that it works again without problem for the next 5 or 10 minutes.. Funny thing is that when we put 2 servers, and give them to do the same streaming one stops and other works.. That means, that it has nothing to do with servers nor connection but just with some other thing.. Dont know.. :( Once more with other types of encription it works without problem.. Maybe sasc-ng has a problem with NDS? Thank you.. -
SASC-NG Problem
So here is the log from sasc-ng Jan 11 09:46:41.198 : Version: 0.0.2-61975953edd0+ Jan 11 09:46:41.223 CAM: initializing plugin: SoftCam (1.0.0pre-HG-61975953edd0+): A software emulated CAM Jan 11 09:46:41.257 [general.info] SC version 1.0.0pre-HG-61975953edd0+ initializing (VDR 1.6.0) Jan 11 09:46:41.290 CAM: starting plugin: Jan 11 09:46:41.332 [general.info] SC version 1.0.0pre-HG-61975953edd0+ starting (VDR 1.6.0) Jan 11 09:46:41.366 [core.load] ** Plugin config: Jan 11 09:46:41.399 [core.load] ** Key updates (AU) are enabled (active CAIDs) (no prestart) Jan 11 09:46:41.433 [core.load] ** Local systems DON'T take priority over cached remote Jan 11 09:46:41.466 [core.load] ** Concurrent FF recordings are NOT allowed Jan 11 09:46:41.499 [core.load] ** Force transfermode with digital audio Jan 11 09:46:41.533 [core.load] ** ECM cache is set to enabled Jan 11 09:46:41.566 [core.load] ** ScCaps are 1 2 0 0 0 0 0 0 0 0 Jan 11 09:46:41.600 [general.info] loading cardclient config from /etc/camfiles//cardclient.conf Jan 11 09:46:41.634 [cardclient.newcamd] now using protocol version 525 (cdLen=8) Jan 11 09:46:41.667 [cardclient.core] hostname=192.168.1.92 port=34000 emm=0 emmCaids 1700/ff00 Jan 11 09:46:41.701 [cardclient.core] Newcamd: username=XXXX password=XXXX key=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Jan 11 09:46:41.734 [cardclient.core] client 'Newcamd' ready Jan 11 09:46:41.768 [core.net] connecting to 192.168.1.92:34000/tcp (192.168.1.92) Jan 11 09:46:41.807 [cardclient.login] Newcamd: CaID=091f admin=1 srvUA=0000000000016B43 provider 000000/0000000000016B00 Jan 11 09:46:41.845 [cardclient.emm] Newcamd: EMM disabled from config Jan 11 09:46:41.878 [general.error] failed open /etc/camfiles//SoftCam.Key: No such file or directory Jan 11 09:46:41.903 [general.info] loading ecm cache from /etc/camfiles//ecm.cache Jan 11 09:46:41.960 [general.error] failed open /etc/camfiles//smartcard.conf: No such file or directory Jan 11 09:46:42.012 [general.error] failed open /etc/camfiles//cardslot.conf: No such file or directory Jan 11 09:46:42.054 [general.error] failed open /etc/camfiles//override.conf: No such file or directory Jan 11 09:46:42.096 [general.error] no keys loaded for softcam! Jan 11 09:46:42.138 [core.load] ** registered systems: Jan 11 09:46:42.180 [core.load] ** Cardclient (pri -15) Jan 11 09:46:42.205 [core.load] ** Conax (pri -10) Jan 11 09:46:42.230 [core.load] ** ConstCW (pri -20) Jan 11 09:46:42.255 [core.load] ** Cryptoworks (pri -10) Jan 11 09:46:42.280 [core.load] ** Irdeto (pri -10) Jan 11 09:46:42.306 [core.load] ** Irdeto2 (pri -8) Jan 11 09:46:42.331 [core.load] ** Nagra (pri -10) Jan 11 09:46:42.356 [core.load] ** Nagra2 (pri -10) Jan 11 09:46:42.381 [core.load] ** Fake-NDS (pri -12) Jan 11 09:46:42.406 [core.load] ** SC-Conax (pri -5) Jan 11 09:46:42.431 [core.load] ** SC-Cryptoworks (pri -5) Jan 11 09:46:42.456 [core.load] ** SC-Irdeto (pri -5) Jan 11 09:46:42.482 [core.load] ** SC-Nagra (pri -5) Jan 11 09:46:42.515 [core.load] ** SC-Seca (pri -5) Jan 11 09:46:42.549 [core.load] ** SC-Viaccess (pri -5) Jan 11 09:46:42.582 [core.load] ** SC-VideoGuard2 (pri -5) Jan 11 09:46:42.616 [core.load] ** Seca (pri -10) Jan 11 09:46:42.649 [core.load] ** @SHL (pri -10) Jan 11 09:46:42.683 [core.load] ** Viaccess (pri -10) Jan 11 09:46:43.717 frontend: Starting thread on /dev/dvb/adapter1/frontend1 The thread scheduling parameters indicate: policy = 0 priority = 0 Jan 11 09:46:43.755 demux: Starting thread on /dev/dvb/adapter1/demux1 The thread scheduling parameters indicate: policy = 0 priority = 0 Jan 11 09:46:43.755 dvr: Starting thread on /dev/dvb/adapter1/dvr1 The thread scheduling parameters indicate: policy = 1 priority = 99 Jan 11 09:46:43.817 : Listening on port 5456 Jan 11 09:47:49.051 CHANNEL: Clearing tuning cache due to switch cmd Jan 11 09:47:49.082 CHANNEL: Clearing tuning cache due to switch cmd Jan 11 09:47:49.116 CHANNEL: Tuning frontend Jan 11 09:47:49.149 CAM: Got MSG_RESETSID Jan 11 09:47:49.183 CSA: Got command(1): I idx: 0 pid: 0 Orbit: 00000160E Jan 11 09:47:53.069 [core.pids] 0: now tuned to source 88a0(S16.0E) transponder 33e79 Jan 11 09:47:53.125 CAM: SC completed Tune cmd Jan 11 09:47:53.167 CAM: Adding pid 301 for sid 1101 to pidlist Jan 11 09:47:53.200 CAM: Adding pid 401 for sid 1101 to pidlist Jan 11 09:47:53.242 [core.pids] 0: update SID 1101 (zero=0 noshift=0) Jan 11 09:47:53.284 [core.pids] 0: pids typ5=012d typ5=0191 Jan 11 09:47:53.317 [core.pids] SimplyCa entry pidCa=0 Jan 11 09:47:53.351 [core.pids] prgca: 09 04 09 1F E3 21 Jan 11 09:47:53.384 [core.pids] pidca 012d: <empty> Jan 11 09:47:53.418 [core.pids] pidca 0191: <empty> Jan 11 09:47:53.451 [core.pids] SimplyCa exit pidCa=0 Jan 11 09:47:53.485 [core.pids] prgca: 09 04 09 1F E3 21 Jan 11 09:47:53.518 [core.pids] pidca 012d: <empty> Jan 11 09:47:53.543 [core.pids] pidca 0191: <empty> Jan 11 09:47:53.568 [core.pids] 0: SID=1101 zero=0 | sid=-/-/- zero=-/-/- idle=-/-/- Jan 11 09:47:53.594 [core.pids] 0: found handler for SID 1101 (0.1 idle=1 idx=1) Jan 11 09:47:53.619 [core.ecm] 0.1: setting new SID 1101 Jan 11 09:47:53.644 [core.pids] 0.1: pids on entry Jan 11 09:47:53.671 [core.pids] 0.1: pids after delete Jan 11 09:47:53.696 [core.pids] 0: descrambling pid 012d on index 1 Called cSascDvbDevice::SetCaPid Jan 11 09:47:53.771 CAM: Sending (1) key P 1 PID: 301 Jan 11 09:47:53.796 CSA: Got command(1): P idx: 1 pid: 301 Jan 11 09:47:53.822 [core.pids] 0: descrambling pid 0191 on index 1 Called cSascDvbDevice::SetCaPid Jan 11 09:47:53.922 CAM: Sending (1) key P 1 PID: 401 Jan 11 09:47:53.955 CSA: Got command(1): P idx: 1 pid: 401 Jan 11 09:47:53.989 [core.pids] 0.1: pids after add typ5=012d typ5=0191 Jan 11 09:47:54.022 [core.ecm] 0.1: is no longer idle Jan 11 09:47:54.056 MSG: Got unprocessed message type: 1 Jan 11 09:47:54.089 CAM: Adding pid 302 for sid 1102 to pidlist Jan 11 09:47:54.165 CAM: Adding pid 405 for sid 1102 to pidlist Jan 11 09:47:54.198 CAM: Adding pid 502 for sid 1102 to pidlist Jan 11 09:47:54.232 [core.pids] 0: update SID 1102 (zero=0 noshift=0) Jan 11 09:47:54.265 [core.pids] 0: pids typ5=012e typ5=0195 typ5=01f6 Jan 11 09:47:54.299 [core.pids] SimplyCa entry pidCa=0 Jan 11 09:47:54.332 [core.pids] prgca: 09 04 09 1F E3 22 Jan 11 09:47:54.366 [core.pids] pidca 012e: <empty> Jan 11 09:47:54.399 [core.pids] pidca 0195: <empty> Jan 11 09:47:54.433 [core.pids] pidca 01f6: <empty> Jan 11 09:47:54.466 [core.pids] SimplyCa exit pidCa=0 Jan 11 09:47:54.500 [core.pids] prgca: 09 04 09 1F E3 22 Jan 11 09:47:54.533 [core.pids] pidca 012e: <empty> Jan 11 09:47:54.575 [core.pids] pidca 0195: <empty> Jan 11 09:47:54.617 [core.pids] pidca 01f6: <empty> Jan 11 09:47:54.117 [core.ecm] 0.1: triggered SID -1/1101 idx -1/1 mode -1/0 - Jan 11 09:47:54.692 [core.ecm] 0.1: new caDescr: 09 04 09 1F E3 21 Jan 11 09:47:54.726 [core.ecm] from cache: system Cardclient (091f) id 0000 with ecm 321/80 Jan 11 09:47:54.759 [core.ecm] 0.1: CA descriptors for SID 1101 (len=6) Jan 11 09:47:54.792 [core.ecm] 0.1: descriptor 09 1f e3 21 Jan 11 09:47:54.834 [core.ecm] 0.1: found 091f(0000) (Fake-NDS) id 0000 with ecm 321/80 (already present) Jan 11 09:47:54.726 [core.pids] 0: SID=1102 zero=0 | sid=-/-/- zero=-/-/- idle=-/-/- Jan 11 09:47:54.901 [core.pids] 0: found handler for SID 1102 (0.2 idle=1 idx=2) Jan 11 09:47:54.935 [core.ecm] 0.2: setting new SID 1102 Jan 11 09:47:54.968 [core.pids] 0.2: pids on entry Jan 11 09:47:54.993 [core.pids] 0.2: pids after delete Jan 11 09:47:55.019 [core.pids] 0: descrambling pid 012e on index 2 Called cSascDvbDevice::SetCaPid Jan 11 09:47:55.094 CAM: Sending (1) key P 2 PID: 302 Jan 11 09:47:55.119 CSA: Got command(1): P idx: 2 pid: 302 Jan 11 09:47:55.144 [core.pids] 0: descrambling pid 0195 on index 2 Called cSascDvbDevice::SetCaPid Jan 11 09:47:55.220 CAM: Sending (1) key P 2 PID: 405 Jan 11 09:47:55.245 CSA: Got command(1): P idx: 2 pid: 405 Jan 11 09:47:55.270 [core.pids] 0: descrambling pid 01f6 on index 2 Called cSascDvbDevice::SetCaPid Jan 11 09:47:55.347 CAM: Sending (1) key P 2 PID: 502 Jan 11 09:47:55.381 CSA: Got command(1): P idx: 2 pid: 502 Jan 11 09:47:55.414 [core.pids] 0.2: pids after add typ5=012e typ5=0195 typ5=01f6 Jan 11 09:47:55.448 [core.ecm] 0.2: is no longer idle Jan 11 09:47:55.481 MSG: Got unprocessed message type: 1 Jan 11 09:47:55.515 MSG: Got unprocessed message type: 1 Jan 11 09:47:55.482 [core.ecm] 0.1: try system Cardclient (091f) id 0000 with ecm 321 (cached) (pri=-15) Jan 11 09:47:55.615 [cardclient.core] cc-loop Jan 11 09:47:55.649 [cardclient.core] now trying client Newcamd (192.168.1.92:34000) Jan 11 09:47:55.520 [core.au] 0: chain caid 091f -> Cardclient(-15) [0030-82/ff/00] Jan 11 09:47:55.544 [core.ecm] 0.2: triggered SID -1/1102 idx -1/2 mode -1/0 - Jan 11 09:47:55.749 [core.ecm] 0.2: new caDescr: 09 04 09 1F E3 22 Jan 11 09:47:55.783 [core.ecm] from cache: system Cardclient (091f) id 0000 with ecm 322/80 Jan 11 09:47:55.816 [core.ecm] 0.2: CA descriptors for SID 1102 (len=6) Jan 11 09:47:55.850 [core.ecm] 0.2: descriptor 09 1f e3 22 Jan 11 09:47:55.891 [core.ecm] 0.2: found 091f(0000) (Fake-NDS) id 0000 with ecm 322/80 (already present) Jan 11 09:47:55.716 [core.au] 0: starting chain 091f Called cSascDvbDevice::SetCaDescr Jan 11 09:47:56.042 CAM: Sending key(-1) E 1 81...4a Jan 11 09:47:56.075 CSA: Got command(1): E idx: 1 pid: 0 key: 0801...4a Called cSascDvbDevice::SetCaDescr Jan 11 09:47:56.176 CAM: Sending key(-1) O 1 00...0 Jan 11 09:47:56.209 CSA: Got command(1): O idx: 1 pid: 0 key: 0000...00 Jan 11 09:47:56.243 [core.ecm] 0.1: correct key found Jan 11 09:47:56.244 CSA: Creating csa for rb: 1 Jan 11 09:47:55.959 [core.ecm] 0.2: try system Cardclient (091f) id 0000 with ecm 322 (cached) (pri=-15) Jan 11 09:47:56.335 [cardclient.core] cc-loop Jan 11 09:47:56.360 [cardclient.core] now trying client Newcamd (192.168.1.92:34000) Called cSascDvbDevice::SetCaDescr Jan 11 09:47:56.611 CAM: Sending key(-1) E 2 36a1...a4 Jan 11 09:47:56.636 CSA: Got command(1): E idx: 2 pid: 0 key: 36a1...a4 Called cSascDvbDevice::SetCaDescr Jan 11 09:47:56.711 CAM: Sending key(-1) O 2 00...0 Jan 11 09:47:56.736 CSA: Got command(1): O idx: 2 pid: 0 key: 0000...00 Jan 11 09:47:56.762 [core.ecm] 0.2: correct key found Called cSascDvbDevice::SetCaDescr Jan 11 09:47:58.370 CAM: Sending key(-1) E 1 81...4a Jan 11 09:47:58.395 CSA: Got command(1): E idx: 1 pid: 0 key: 0801...4a Called cSascDvbDevice::SetCaDescr Jan 11 09:47:58.471 CAM: Sending key(-1) O 1 00...0 Jan 11 09:47:58.496 CSA: Got command(1): O idx: 1 pid: 0 key: 0000...00 Called cSascDvbDevice::SetCaDescr Jan 11 09:47:58.880 CAM: Sending key(-1) E 2 36a1...a4 Jan 11 09:47:58.913 CSA: Got command(1): E idx: 2 pid: 0 key: 36a1...a4 Called cSascDvbDevice::SetCaDescr Jan 11 09:47:59.015 CAM: Sending key(-1) O 2 00...0 Jan 11 09:47:59.049 CSA: Got command(1): O idx: 2 pid: 0 key: 0000...00 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:04.833 CAM: Sending key(-1) O 1 2fbf...f7 Jan 11 09:48:04.866 CSA: Got command(1): O idx: 1 pid: 0 key: 2fbf...f7 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:04.983 CAM: Sending key(-1) O 2 8137...8f Jan 11 09:48:05.025 CSA: Got command(1): O idx: 2 pid: 0 key: 8137...8f Called cSascDvbDevice::SetCaDescr Jan 11 09:48:14.833 CAM: Sending key(-1) E 1 5b9b...29 Jan 11 09:48:14.867 CSA: Got command(1): E idx: 1 pid: 0 key: 5b9b...29 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:14.976 CAM: Sending key(-1) E 2 4b22...62 Jan 11 09:48:15.009 CSA: Got command(1): E idx: 2 pid: 0 key: 4b22...62 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:24.818 CAM: Sending key(-1) O 1 5f60...d Jan 11 09:48:24.843 CSA: Got command(1): O idx: 1 pid: 0 key: 5f60...0d Called cSascDvbDevice::SetCaDescr Jan 11 09:48:24.968 CAM: Sending key(-1) O 2 67b3...8 Jan 11 09:48:24.994 CSA: Got command(1): O idx: 2 pid: 0 key: 67b3...08 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:35.277 CAM: Sending key(-1) E 1 fdd6...ee Jan 11 09:48:35.302 CSA: Got command(1): E idx: 1 pid: 0 key: fdd6...ee Called cSascDvbDevice::SetCaDescr Jan 11 09:48:35.428 CAM: Sending key(-1) E 2 969...ff Jan 11 09:48:35.453 CSA: Got command(1): E idx: 2 pid: 0 key: 9609...ff Called cSascDvbDevice::SetCaDescr Jan 11 09:48:44.820 CAM: Sending key(-1) O 1 7e78...27 Jan 11 09:48:44.845 CSA: Got command(1): O idx: 1 pid: 0 key: 7e78...27 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:44.987 CAM: Sending key(-1) O 2 5eb9...9c Jan 11 09:48:45.021 CSA: Got command(1): O idx: 2 pid: 0 key: 5eb9...9c Called cSascDvbDevice::SetCaDescr Jan 11 09:48:54.829 CAM: Sending key(-1) E 1 59b4...39 Jan 11 09:48:54.863 CSA: Got command(1): E idx: 1 pid: 0 key: 59b4...39 Called cSascDvbDevice::SetCaDescr Jan 11 09:48:54.988 CAM: Sending key(-1) E 2 2cd3...61 Jan 11 09:48:55.022 CSA: Got command(1): E idx: 2 pid: 0 key: 2cd3...61 Jan 11 09:48:55.529 [core.auStats] EMM packet load average (1/4/10min) 85 21 8 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:49:04.840 CAM: Sending key(-1) O 1 7d9f...23 Jan 11 09:49:04.874 CSA: Got command(1): O idx: 1 pid: 0 key: 7d9f...23 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:04.999 CAM: Sending key(-1) O 2 9869...6b Jan 11 09:49:05.032 CSA: Got command(1): O idx: 2 pid: 0 key: 9869...6b Called cSascDvbDevice::SetCaDescr Jan 11 09:49:14.849 CAM: Sending key(-1) E 1 e9d3...77 Jan 11 09:49:14.874 CSA: Got command(1): E idx: 1 pid: 0 key: e9d3...77 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:14.992 CAM: Sending key(-1) E 2 69ab...51 Jan 11 09:49:15.017 CSA: Got command(1): E idx: 2 pid: 0 key: 69ab...51 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:24.817 CAM: Sending key(-1) O 1 b471...40 Jan 11 09:49:24.842 CSA: Got command(1): O idx: 1 pid: 0 key: b471...40 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:24.968 CAM: Sending key(-1) O 2 7580...59 Jan 11 09:49:24.993 CSA: Got command(1): O idx: 2 pid: 0 key: 7580...59 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:34.826 CAM: Sending key(-1) E 1 63e4...81 Jan 11 09:49:34.851 CSA: Got command(1): E idx: 1 pid: 0 key: 63e4...81 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:35.085 CAM: Sending key(-1) E 2 83a...b6 Jan 11 09:49:35.119 CSA: Got command(1): E idx: 2 pid: 0 key: 083a...b6 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:44.835 CAM: Sending key(-1) O 1 80c2...b8 Jan 11 09:49:44.869 CSA: Got command(1): O idx: 1 pid: 0 key: 80c2...b8 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:44.994 CAM: Sending key(-1) O 2 31b...b0 Jan 11 09:49:45.028 CSA: Got command(1): O idx: 2 pid: 0 key: 031b...b0 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:54.886 CAM: Sending key(-1) E 1 6df6...e7 Jan 11 09:49:54.920 CSA: Got command(1): E idx: 1 pid: 0 key: 6df6...e7 Called cSascDvbDevice::SetCaDescr Jan 11 09:49:55.037 CAM: Sending key(-1) E 2 f361...c9 Jan 11 09:49:55.071 CSA: Got command(1): E idx: 2 pid: 0 key: f361...c9 Jan 11 09:49:55.557 [core.auStats] EMM packet load average (1/4/10min) 85 42 17 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:50:04.863 CAM: Sending key(-1) O 1 674f...6 Jan 11 09:50:04.896 CSA: Got command(1): O idx: 1 pid: 0 key: 674f...06 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:05.007 CAM: Sending key(-1) O 2 eaa7...47 Jan 11 09:50:05.032 CSA: Got command(1): O idx: 2 pid: 0 key: eaa7...47 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:14.832 CAM: Sending key(-1) E 1 3eed...af Jan 11 09:50:14.857 CSA: Got command(1): E idx: 1 pid: 0 key: 3eed...af Called cSascDvbDevice::SetCaDescr Jan 11 09:50:14.982 CAM: Sending key(-1) E 2 30c5...10 Jan 11 09:50:15.008 CSA: Got command(1): E idx: 2 pid: 0 key: 30c5...10 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:24.824 CAM: Sending key(-1) O 1 8ed7...fa Jan 11 09:50:24.849 CSA: Got command(1): O idx: 1 pid: 0 key: 8ed7...fa Called cSascDvbDevice::SetCaDescr Jan 11 09:50:24.975 CAM: Sending key(-1) O 2 34eb...76 Jan 11 09:50:25.000 CSA: Got command(1): O idx: 2 pid: 0 key: 34eb...76 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:34.842 CAM: Sending key(-1) E 1 c971...80 Jan 11 09:50:34.875 CSA: Got command(1): E idx: 1 pid: 0 key: c971...80 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:34.993 CAM: Sending key(-1) E 2 f2d...ab Jan 11 09:50:35.026 CSA: Got command(1): E idx: 2 pid: 0 key: 0f2d...ab Called cSascDvbDevice::SetCaDescr Jan 11 09:50:44.843 CAM: Sending key(-1) O 1 98fd...34 Jan 11 09:50:44.876 CSA: Got command(1): O idx: 1 pid: 0 key: 98fd...34 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:44.994 CAM: Sending key(-1) O 2 4264...a0 Jan 11 09:50:45.027 CSA: Got command(1): O idx: 2 pid: 0 key: 4264...a0 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:54.861 CAM: Sending key(-1) E 1 9e4...58 Jan 11 09:50:54.894 CSA: Got command(1): E idx: 1 pid: 0 key: 09e4...58 Called cSascDvbDevice::SetCaDescr Jan 11 09:50:55.011 CAM: Sending key(-1) E 2 d99d...5d Jan 11 09:50:55.045 CSA: Got command(1): E idx: 2 pid: 0 key: d99d...5d Jan 11 09:50:55.579 [core.auStats] EMM packet load average (1/4/10min) 85 64 25 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:51:04.845 CAM: Sending key(-1) O 1 2d21...73 Jan 11 09:51:04.879 CSA: Got command(1): O idx: 1 pid: 0 key: 2d21...73 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:04.996 CAM: Sending key(-1) O 2 37d0...e1 Jan 11 09:51:05.029 CSA: Got command(1): O idx: 2 pid: 0 key: 37d0...e1 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:15.056 CAM: Sending key(-1) E 1 42d0...1 Jan 11 09:51:15.081 CSA: Got command(1): E idx: 1 pid: 0 key: 42d0...01 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:15.206 CAM: Sending key(-1) E 2 b4a9...6c Jan 11 09:51:15.232 CSA: Got command(1): E idx: 2 pid: 0 key: b4a9...6c Called cSascDvbDevice::SetCaDescr Jan 11 09:51:24.832 CAM: Sending key(-1) O 1 4eba...44 Jan 11 09:51:24.857 CSA: Got command(1): O idx: 1 pid: 0 key: 4eba...44 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:24.991 CAM: Sending key(-1) O 2 9760...7d Jan 11 09:51:25.024 CSA: Got command(1): O idx: 2 pid: 0 key: 9760...7d Called cSascDvbDevice::SetCaDescr Jan 11 09:51:34.841 CAM: Sending key(-1) E 1 49ce...2e Jan 11 09:51:34.875 CSA: Got command(1): E idx: 1 pid: 0 key: 49ce...2e Called cSascDvbDevice::SetCaDescr Jan 11 09:51:34.992 CAM: Sending key(-1) E 2 75f9...a5 Jan 11 09:51:35.025 CSA: Got command(1): E idx: 2 pid: 0 key: 75f9...a5 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:44.851 CAM: Sending key(-1) O 1 29e7...2 Jan 11 09:51:44.884 CSA: Got command(1): O idx: 1 pid: 0 key: 29e7...02 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:44.993 CAM: Sending key(-1) O 2 dfed...90 Jan 11 09:51:45.026 CSA: Got command(1): O idx: 2 pid: 0 key: dfed...90 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:54.851 CAM: Sending key(-1) E 1 755...4 Jan 11 09:51:54.885 CSA: Got command(1): E idx: 1 pid: 0 key: 0755...04 Called cSascDvbDevice::SetCaDescr Jan 11 09:51:55.002 CAM: Sending key(-1) E 2 f716...70 Jan 11 09:51:55.035 CSA: Got command(1): E idx: 2 pid: 0 key: f716...70 Jan 11 09:51:55.619 [core.auStats] EMM packet load average (1/4/10min) 85 85 34 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:52:04.852 CAM: Sending key(-1) O 1 65b9...84 Jan 11 09:52:04.878 CSA: Got command(1): O idx: 1 pid: 0 key: 65b9...84 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:04.986 CAM: Sending key(-1) O 2 9545...17 Jan 11 09:52:05.012 CSA: Got command(1): O idx: 2 pid: 0 key: 9545...17 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:14.845 CAM: Sending key(-1) E 1 39c2...42 Jan 11 09:52:14.870 CSA: Got command(1): E idx: 1 pid: 0 key: 39c2...42 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:14.997 CAM: Sending key(-1) E 2 27d2...e Jan 11 09:52:15.031 CSA: Got command(1): E idx: 2 pid: 0 key: 27d2...0e Called cSascDvbDevice::SetCaDescr Jan 11 09:52:24.848 CAM: Sending key(-1) O 1 f751...aa Jan 11 09:52:24.881 CSA: Got command(1): O idx: 1 pid: 0 key: f751...aa Called cSascDvbDevice::SetCaDescr Jan 11 09:52:24.998 CAM: Sending key(-1) O 2 626c...87 Jan 11 09:52:25.032 CSA: Got command(1): O idx: 2 pid: 0 key: 626c...87 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:34.848 CAM: Sending key(-1) E 1 d9a1...1a Jan 11 09:52:34.882 CSA: Got command(1): E idx: 1 pid: 0 key: d9a1...1a Called cSascDvbDevice::SetCaDescr Jan 11 09:52:35.007 CAM: Sending key(-1) E 2 a6fe...17 Jan 11 09:52:35.041 CSA: Got command(1): E idx: 2 pid: 0 key: a6fe...17 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:44.858 CAM: Sending key(-1) O 1 751...a8 Jan 11 09:52:44.891 CSA: Got command(1): O idx: 1 pid: 0 key: 0751...a8 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:45.017 CAM: Sending key(-1) O 2 dce4...24 Jan 11 09:52:45.059 CSA: Got command(1): O idx: 2 pid: 0 key: dce4...24 Called cSascDvbDevice::SetCaDescr Jan 11 09:52:54.851 CAM: Sending key(-1) E 1 9d73...6e Jan 11 09:52:54.884 CSA: Got command(1): E idx: 1 pid: 0 key: 9d73...6e Called cSascDvbDevice::SetCaDescr Jan 11 09:52:54.993 CAM: Sending key(-1) E 2 7435...ef Jan 11 09:52:55.018 CSA: Got command(1): E idx: 2 pid: 0 key: 7435...ef Jan 11 09:52:55.654 [core.auStats] EMM packet load average (1/4/10min) 85 85 42 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:53:04.835 CAM: Sending key(-1) O 1 2631...be Jan 11 09:53:04.860 CSA: Got command(1): O idx: 1 pid: 0 key: 2631...be Called cSascDvbDevice::SetCaDescr Jan 11 09:53:04.994 CAM: Sending key(-1) O 2 7bf6...c4 Jan 11 09:53:05.019 CSA: Got command(1): O idx: 2 pid: 0 key: 7bf6...c4 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:14.853 CAM: Sending key(-1) E 1 7e9b...3 Jan 11 09:53:14.878 CSA: Got command(1): E idx: 1 pid: 0 key: 7e9b...03 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:15.003 CAM: Sending key(-1) E 2 67c6...93 Jan 11 09:53:15.028 CSA: Got command(1): E idx: 2 pid: 0 key: 67c6...93 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:24.855 CAM: Sending key(-1) O 1 84f3...f3 Jan 11 09:53:24.889 CSA: Got command(1): O idx: 1 pid: 0 key: 84f3...f3 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:25.006 CAM: Sending key(-1) O 2 3ef3...2 Jan 11 09:53:25.040 CSA: Got command(1): O idx: 2 pid: 0 key: 3ef3...02 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:34.898 CAM: Sending key(-1) E 1 5bff...4b Jan 11 09:53:34.939 CSA: Got command(1): E idx: 1 pid: 0 key: 5bff...4b Called cSascDvbDevice::SetCaDescr Jan 11 09:53:35.048 CAM: Sending key(-1) E 2 df35...29 Jan 11 09:53:35.083 CSA: Got command(1): E idx: 2 pid: 0 key: df35...29 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:44.865 CAM: Sending key(-1) O 1 d2a...11 Jan 11 09:53:44.899 CSA: Got command(1): O idx: 1 pid: 0 key: 0d2a...11 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:45.008 CAM: Sending key(-1) O 2 316...86 Jan 11 09:53:45.041 CSA: Got command(1): O idx: 2 pid: 0 key: 3106...86 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:54.841 CAM: Sending key(-1) E 1 3fb7...f4 Jan 11 09:53:54.866 CSA: Got command(1): E idx: 1 pid: 0 key: 3fb7...f4 Called cSascDvbDevice::SetCaDescr Jan 11 09:53:54.992 CAM: Sending key(-1) E 2 3b8a...b2 Jan 11 09:53:55.017 CSA: Got command(1): E idx: 2 pid: 0 key: 3b8a...b2 Jan 11 09:53:55.674 [core.auStats] EMM packet load average (1/4/10min) 85 85 47 pks/s Called cSascDvbDevice::SetCaDescr Jan 11 09:54:05.384 CAM: Sending key(-1) O 1 f477...26 Jan 11 09:54:05.409 CSA: Got command(1): O idx: 1 pid: 0 key: f477...26 Called cSascDvbDevice::SetCaDescr Jan 11 09:54:05.535 CAM: Sending key(-1) O 2 1db8...d1 Jan 11 09:54:05.560 CSA: Got command(1): O idx: 2 pid: 0 key: 1db8...d1 Called cSascDvbDevice::SetCaDescr Jan 11 09:54:14.868 CAM: Sending key(-1) E 1 b5ff...3e Jan 11 09:54:14.893 CSA: Got command(1): E idx: 1 pid: 0 key: b5ff...3e Called cSascDvbDevice::SetCaDescr Jan 11 09:54:15.028 CAM: Sending key(-1) E 2 dcfe...9b Jan 11 09:54:15.061 CSA: Got command(1): E idx: 2 pid: 0 key: dcfe...9b Jan 11 09:54:22.814 CAM: Got MSG_RESETSID Jan 11 09:54:22.815 CSA: Removing csa for rb: 1 Jan 11 09:54:22.844 [core.pids] 0: update SID 1102 (zero=0 noshift=0) Jan 11 09:54:22.911 [core.pids] 0: pids typ5=0195 typ5=012e Jan 11 09:54:22.945 [core.pids] SimplyCa entry pidCa=0 Jan 11 09:54:22.980 [core.pids] prgca: <empty> Jan 11 09:54:23.021 [core.pids] pidca 0195: <empty> Jan 11 09:54:23.063 [core.pids] pidca 012e: <empty> Jan 11 09:54:23.105 [core.pids] SimplyCa exit pidCa=0 Jan 11 09:54:23.147 [core.pids] prgca: <empty> Jan 11 09:54:23.180 [core.pids] pidca 0195: <empty> Jan 11 09:54:23.222 [core.pids] pidca 012e: <empty> Jan 11 09:54:23.256 [core.pids] 0: SID=1102 zero=0 | sid=2/1102/0 zero=-/-/- idle=-/-/- Jan 11 09:54:23.289 [core.pids] 0: found handler for SID 1102 (0.2 idle=0 idx=2) Jan 11 09:54:23.323 [core.pids] 0.2: pids on entry typ5=012e typ5=0195 typ5=01f6 Jan 11 09:54:23.356 [core.pids] 0.2: pids after delete typ5=012e typ5=0195 Jan 11 09:54:23.390 [core.pids] 0.2: pids after add typ5=012e typ5=0195 Jan 11 09:54:23.423 [core.pids] 0: update SID 1102 (zero=0 noshift=0) Jan 11 09:54:23.448 [core.pids] 0: pids typ5=012e Jan 11 09:54:23.474 [core.pids] SimplyCa entry pidCa=0 Jan 11 09:54:23.499 [core.pids] prgca: <empty> Jan 11 09:54:23.524 [core.pids] pidca 012e: <empty> Jan 11 09:54:23.549 [core.pids] SimplyCa exit pidCa=0 Jan 11 09:54:23.452 [core.ecm] 0.2: triggered SID 1102/1102 idx 2/2 mode 3/0 sync Jan 11 09:54:23.599 [core.ecm] 0.2: new caDescr: <empty> Jan 11 09:54:23.574 [core.pids] prgca: <empty> Jan 11 09:54:23.650 [core.pids] pidca 012e: <empty> Jan 11 09:54:23.675 [core.pids] 0: SID=1102 zero=0 | sid=2/1102/0 zero=-/-/- idle=-/-/- Jan 11 09:54:23.700 [core.pids] 0: found handler for SID 1102 (0.2 idle=0 idx=2) Jan 11 09:54:23.725 [core.pids] 0.2: pids on entry typ5=012e typ5=0195 Jan 11 09:54:23.750 [core.pids] 0.2: pids after delete typ5=012e Jan 11 09:54:23.775 [core.pids] 0.2: pids after add typ5=012e Jan 11 09:54:23.801 [core.pids] 0: update SID 1102 (zero=0 noshift=1) Jan 11 09:54:23.805 [core.ecm] 0.2: triggered SID 1102/1102 idx 2/2 mode 3/0 sync Jan 11 09:54:23.851 [core.pids] 0: SID=1102 zero=0 | sid=2/1102/0 zero=-/-/- idle=-/-/- Jan 11 09:54:23.876 [core.pids] 0: found handler for SID 1102 (0.2 idle=0 idx=2) Jan 11 09:54:23.901 [core.pids] 0.2: pids on entry typ5=012e Jan 11 09:54:23.926 [core.pids] 0.2: pids after delete Jan 11 09:54:23.951 [core.pids] 0.2: pids after add Jan 11 09:54:23.985 [core.ecm] 0.2: is idle now Jan 11 09:54:24.018 [core.pids] 0: update SID 1101 (zero=0 noshift=0) Jan 11 09:54:24.052 [core.pids] 0: pids typ5=012d Jan 11 09:54:24.085 [core.pids] SimplyCa entry pidCa=0 Jan 11 09:54:24.119 [core.pids] prgca: <empty> Jan 11 09:54:24.152 [core.pids] pidca 012d: <empty> Jan 11 09:54:24.186 [core.pids] SimplyCa exit pidCa=0 Jan 11 09:54:24.219 [core.pids] prgca: <empty> Jan 11 09:54:24.253 [core.pids] pidca 012d: <empty> Jan 11 09:54:24.286 [core.pids] 0: SID=1101 zero=0 | sid=1/1101/0 zero=-/-/- idle=2/1102/1 Jan 11 09:54:24.320 [core.pids] 0: found handler for SID 1101 (0.1 idle=0 idx=1) Jan 11 09:54:24.353 [core.pids] 0.1: pids on entry typ5=012d typ5=0191 Jan 11 09:54:24.387 [core.pids] 0.1: pids after delete typ5=012d Jan 11 09:54:24.420 [core.pids] 0.1: pids after add typ5=012d Jan 11 09:54:24.454 [core.pids] 0: update SID 1101 (zero=0 noshift=1) Jan 11 09:54:24.466 [core.ecm] 0.1: triggered SID 1101/1101 idx 1/1 mode 3/0 sync Jan 11 09:54:24.521 [core.ecm] 0.1: new caDescr: <empty> Jan 11 09:54:24.554 [core.pids] 0: SID=1101 zero=0 | sid=1/1101/0 zero=-/-/- idle=2/1102/1 Jan 11 09:54:24.589 [core.pids] 0: found handler for SID 1101 (0.1 idle=0 idx=1) Jan 11 09:54:24.623 [core.pids] 0.1: pids on entry typ5=012d Jan 11 09:54:24.656 [core.pids] 0.1: pids after delete Jan 11 09:54:24.690 [core.pids] 0.1: pids after add Jan 11 09:54:24.723 [core.ecm] 0.1: is idle now Jan 11 09:54:24.748 [core.ecm] 0.1: stop Jan 11 09:54:24.774 [core.ecm] 0.2: stop Jan 11 09:54:24.795 [core.ecm] 0.1: triggered SID 1101/-1 idx 1/1 mode 3/-1 sync Jan 11 09:54:24.799 [core.au] 0: stopping chain 091f Jan 11 09:54:24.812 [core.ecm] 0.2: triggered SID 1102/-1 idx 2/2 mode 3/-1 sync Jan 11 09:54:24.849 CSA: Got command(1): I idx: 0 pid: 0 Jan 11 09:54:24.899 CAM: Got MSG_REMOVESID with sid: 1102 Jan 11 09:54:24.925 CAM: Got MSG_REMOVESID with sid: 1102 Jan 11 09:54:24.950 CAM: Got MSG_REMOVESID with sid: 1102 Jan 11 09:54:24.975 CAM: Got MSG_REMOVESID with sid: 1101 Jan 11 09:54:25.000 CAM: Got MSG_REMOVESID with sid: 1101 Jan 11 09:54:34.795 [general.debug] SC cleanup done Jan 11 09:54:34.875 : Exiting... Start settings are: sasc-ng arguments: -j 0:1 -b 20000000 -l /tmp/sasc.log -d 0x30000000 --sid-allpid --sid-nocache --cam-budget --cam-dir /etc/camfiles/ cardclient connection to newcs: newcamd:192.168.1.92:34000:0:XXXX:XXXX:0102030405060708091011121314 Strange thing is that it doesnt report any error.. Just stops and waits for 10 sec.. Like the keys sasc got are not valid or something like that.. Maybe a solution would be to make sasc "ask" for the keys faster? Maybe u can see something in log file, but i see nothing! :( Strange.. And once more.. With Conax or Nagra3 there are no problems at all!! One more thing.. We did one more test.. We put the same setings on other computer now.. So 2 PC with same hardware.. Everything is the same (software and hardware).. They stream same transponder (NDS encrypted).. After few minutes one stops for 10 sec, another one works as a charm.. then after some time another stops and so on and so on.. There is no rule.. I did this because i tought maybe there is a problem with key.. But in can not be the case while then would both servers stop at the same time.. Right? So i am totaly confused now! Please help.. Thank you in advance.. -
SASC-NG Problem
Hi there.. Thank you for answering me.. I will create a log file in the next 15 minutes and paste it here.. In the mean time we came to one more conclusion.. The problem is there only when sasc-ng descrambles the NDS coded streams.. With Nagra3 or Conax there are no problems at all.. Everything works smoothly.. As the channels we need are NDS enrypted we just made a test with those other channels.. With them the server was running all night long without any problems.. as soon as we switch to NDS the simptoms are back again.. As i said will paste u the log file in the next 15 minutes.. We just started decryption.. Thanx once again.. -
getstream
тему ответил в Mechanic пользователя Vladimir_BG в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
попробовал загрузить ядро с параметрами (в грубе): комп завис, ну или по крайней мере стал недоступным по сети. I guess that this is the same problem i have.. :( That is the post #37 in this thread.. I dont know how he solved it!? Does any1 have an idea? Thank you in advance.. -
Hi there.. I have already wrote about this "getstream" thread, so please dont be mad because i am not sure where to put this.. :) ------------- Hi there .. Sorry for writing in English but i dont speak Russian altho i understand a lot :) So here is the problem i have. Sorry for writing in English but i dont speak Russian altho i understand a lot:) So here is the problem i have. We are planing on building a small IPTV system here in our Student Camp here in Bulgaria.. We are planing on building a small IPTV system here in our Student Camp here in Bulgaria .. We are using getstream in combination with sasc-ng and a card sharing server .. We are using getstream in combination with sasc-ng and a card sharing server .. So with free channels there is no problem, everything works as a charm. So with free channels there is no problem, everything works as a charm. Problem is with a few encrypted channels that we also want to multicast.. Problem is with a few encrypted channels that we also want to multicast .. They are scrambled in NDS Videoguard. They are scrambled in NDS Videoguard. So the problem is: So the problem is: getstream starts to stream using a sasc virtual adapter Everything works for about 10 minutes and then stops.. getstream starts to stream using a sasc virtual adapter Everything works for about 10 minutes and then stops .. Sasc doesnt decript for exactly 10 sec. Sasc doesnt decript for exactly 10 sec. and then starts again. and then starts again. For thoose 10 sec, picture is froozen.. For thoose 10 sec, picture is froozen .. This goes in rounds and is pretty anoying.. This goes in rounds and is pretty anoying .. We have two separate computers with 4 cards.. We have two separate computers with 4 cards .. 1 PC has 3 cards and multicasts only FTA channels.. A PC has 3 cards and multicasts only FTA channels .. It is an celeron on 2 Ghz. It is an celeron on 2 Ghz. The second one has only one SkyStar2 card and is a Core2Duo E6750.. The second one has only one SkyStar2 card and is a Core2Duo E6750 .. This one should decode those channels (7 of them).. This one should decode those channels (7 of them) .. There will be a total of 40 channels in the camp.. There will be a total of 40 channels in the camp .. Server is running Ubuntu 10.10, we use the latest sasc-ng (not open sasc), NewCS 1.67, CCCam 2.1.4 And thats pretty much it. Server is running Ubuntu 10.10, we use the latest sasc-ng (not open sasc), NewCS 1.67, CCCam 2.1.4 And thats pretty much it. The same thing happen with NewCamd, cccam or radegast protocol.. The same thing happen with NewCamd, cccam or radegast protocol .. I believe there is something wrong with the sasc :( Can anyone help? I believe there is something wrong with the sasc: (Can anyone help? Thank you in advance.. Thank you in advance .. --------------------
getstream
Hi there.. Sorry for writing in English but i dont speak Russian altho i understand a lot :) So here is the problem i have. We are planing on building a small IPTV system here in our Student Camp here in Bulgaria.. We are using getstream in combination with sasc-ng and a card sharing server .. So with free channels there is no problem, everything works as a charm. Problem is with a few encrypted channels that we also want to multicast.. They are scrambled in NDS Videoguard. So the problem is: getstream starts to stream using a sasc virtual adapter Everything works for about 10 minutes and then stops.. Sasc doesnt decript for exactly 10 sec. and then starts again. For thoose 10 sec, picture is froozen.. This goes in rounds and is pretty anoying.. We have two separate computers with 4 cards.. 1 PC has 3 cards and multicasts only FTA channels.. It is an celeron on 2 Ghz. The second one has only one SkyStar2 card and is a Core2Duo E6750.. This one should decode those channels (7 of them).. There will be a total of 40 channels in the camp.. Server is running Ubuntu 10.10, we use the latest sasc-ng (not open sasc), NewCS 1.67, CCCam 2.1.4 And thats pretty much it. The same thing happen with NewCamd, cccam or radegast protocol.. I believe there is something wrong with the sasc :( Can anyone help? Thank you in advance..
