Имеется свитч - catalyst 3750.
cat3750#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright © 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
cat3750 uptime is 7 weeks, 1 day, 23 hours, 41 minutes
System returned to ROM by power-on
System image file is "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3750G-24T (PowerPC405) processor (revision L0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1005N3GH
Last reset from power-on
4 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:17:0E:52:9D:80
Motherboard assembly number : 73-9679-09
Power supply part number : 341-0048-03
Motherboard serial number : CAT10051G5F
Power supply serial number : LIT100108JP
Model revision number : L0
Motherboard revision number : A0
Model number : WS-C3750G-24T-S
System serial number : CAT1005N3GH
Top Assembly Part Number : 800-25855-01
Top Assembly Revision Number : C0
Version ID : V05
CLEI Code Number : COMR100BRA
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.2(25)SEB4 C3750-IPBASE-M
Configuration register is 0xF
cat3750#
Свитч режет по скорости пользовательские ip. Порт GigabitEthernet1/0/1 идет в Интернет, порт GigabitEthernet1/0/2 идет в мой роутер и дальше к пользовательским ip. Оба порта во влане по умолчанию (влан 1).
cat3750#sh run
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname cat3750
no logging console
no aaa new-model
switch 1 provision ws-c3750g-24t
ip subnet-zero
mls qos
no file verify auto
spanning-tree mode pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
class-map match-all cl.241.1
match access-group name al.241.1
class-map match-all cl.241.2
match access-group name al.241.2
class-map match-all cl.241.3
match access-group name al.241.3
class-map match-all cl.241.64
match access-group name al.241.64
policy-map pm-1
class cl.241.1
police 408000 51000 exceed-action drop
class cl.241.2
class cl.241.3
class cl.241.64
police 208000 26000 exceed-action drop
interface GigabitEthernet1/0/1
switchport mode access
service-policy input pm-1
duplex full
speed 100
interface GigabitEthernet1/0/2
duplex full
speed 100
interface GigabitEthernet1/0/3
shutdown
interface GigabitEthernet1/0/4
shutdown
interface GigabitEthernet1/0/24
shutdown
interface Vlan1
no ip address
no ip classless
no ip http server
ip access-list extended al.241.1
permit ip any host xxx.yyy.241.1
ip access-list extended al.241.2
permit ip any host xxx.yyy.241.2
ip access-list extended al.241.3
permit ip any host xxx.yyy.241.3
ip access-list extended al.241.64
permit ip any host xxx.yyy.241.64
no cdp run
control-plane
line con 0
line vty 0 4
password 123
no login
line vty 5 15
password 123
no login
end
cat3750#
Policy-map pm-1 отрабатывает, ip зарезаются.
Возникла необходимость сделать больше нарезок.
По цисковским докам на порту может быть 64 полисера. А всего на свитч - 255.
Создаю влан (влан 200) и объединяю порты GigabitEthernet1/0/3 и GigabitEthernet1/0/4 в этот влан. Далее соединяю патчкордом порты GigabitEthernet1/0/2 и GigabitEthernet1/0/3. И соединяю порт GigabitEthernet1/0/4 с моим роутером. Вешаю на порт GigabitEthernet1/0/3 policy-map pm-2 с двумя полисерами. Все policy-map-ы отрабатывают, скорость режется на обоих портах. Добавляю в новый policy-map pm-2 еще классов, но через некоторое время он перестает отрабатывать, при этом pm-1 прекрасно работает.
cat3750#sh run
version 12.2
no service pad
hostname cat3750
no logging console
no aaa new-model
ip subnet-zero
mls qos
no file verify auto
class-map match-all cl.241.65
match access-group name al.241.65
class-map match-all cl.241.66
match access-group name al.241.66
class-map match-all cl.241.129
match access-group name al.241.129
policy-map pm-1
class cl.241.1
class cl.241.2
class cl.241.3
class cl.241.64
policy-map pm2
class cl.241.65
class cl.241.66
class cl.241.129
duplex full
speed 100
duplex full
speed 100
switchport access vlan 200
service-policy input pm-2
duplex full
speed 100
duplex full
speed 100
shutdown
interface Vlan1
no ip address
no ip classless
no ip http server
ip access-list extended al.241.65
permit ip any host xxx.yyy.241.65
ip access-list extended al.241.66
permit ip any host xxx.yyy.241.66
ip access-list extended al.241.129
permit ip any host xxx.yyy.241.129
no cdp run
control-plane
line con 0
line vty 0 4
password 123
no login
line vty 5 15
password 123
no login
end
cat3750#
Уменьшаю в pm-2 количество class-ов - не помогает. Вообще снимаю pm-2 с порта GigabitEthernet1/0/3 создаю новый policy-map с одним class-ом - теперь не работает!! Попробовал аналогичную конструкцию на другом каталисте - та же ситуация - сначала работает потом - нет. В чем причина не могу понять.
