viva
Пользователи
  • Публикации
  • Зарегистрирован
  • Посещение
О viva
  • Звание
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
  1. Добрый день помогите люди добрые как конфигурнуть свич АТ-8000. В консоль зашел а что делать дальше какие команды набирать не знаю. 100% OK Running from RAM... ********************************************************************* *** Running SW Ver. 1.0.0.23 Date 29-May-2006 Time 07:50:32 *** ********************************************************************* HW version is Base Mac address is: 00:15:77:2d:98:00 Dram size is : 64M bytes Dram first block size is : 43008K bytes Dram first PTR is : 0x1600000 Dram second block size is : 0K bytes Dram second PTR is : 0x4000000 Flash size is: 16M 01-Jan-2000 01:01:05 %CDB-I-LOADCONFIG: Loading running configuration. 01-Jan-2000 01:01:05 %CDB-I-LOADCONFIG: Loading startup configuration. Device configuration: Slot 1 - AT 8000S/16 HW Rev. 1.1 ----------------------------------- -- Unit Standalone -- ----------------------------------- Tapi Version: v1.3.3.1 Core Version: v1.3.3.1 01-Jan-2000 01:01:16 %INIT-I-InitCompleted: Initialization task is completed 01-Jan-2000 01:01:16 %Box-I-SFP-PRESENT-CHNG: SFP# 1 status is - not present. 01-Jan-2000 01:01:16 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 0 01-Jan-2000 01:01:16 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 0 User Name:manager Password:****** console# console# console# нужно затолкать вот эти данные interface ethernet g1 switchport mode trunk exit vlan database vlan 184,2080 exit interface range ethernet e(3-15) switchport access vlan 184 exit interface ethernet g1 switchport trunk allowed vlan add 184 exit interface ethernet e16 switchport access vlan 2080 exit interface ethernet g1 switchport trunk allowed vlan add 2080 exit interface vlan 1 ip address 10.183.216.4 255.255.255.0 exit ip default-gateway 10.183.216.1
