Доброго всем времени суток, господа. Приобрел в недавнем времени такую вещь: Cisco 1751 VoIP E1 Bundle для конвертации трафика с E1 в VoIP. Бьюсь вторую неделю - не могу понять причин неработоспособности.. точнее намеки есть, но хотелось бы быть точно уверенным. Итак, сначала описание:
Конфиг шлюза:
VoIP_cisco#sh run
Building configuration...
Current configuration : 1285 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname VoIP_cisco
boot-start-marker
boot-end-marker
memory-size iomem 25
tdm clock E1 0/0 both export line
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
aaa new-model
aaa authentication login default local
aaa session-id common
ip subnet-zero
ip cef
isdn switch-type primary-net5
voice service voip
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
username admin secret 5 <вырезано цензурой>/
controller E1 0/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.2.50 255.255.255.0
speed auto
full-duplex
interface Serial0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip http server
voice-port 0/0:15
dial-peer voice 1 voip
destination-pattern 5941736
voice-class codec 1
session target ipv4:195.88.76.xx
line con 0
line aux 0
line vty 0 4
privilege level 15
line vty 5 15
privilege level 15
end
Модули:
VoIP_cisco#sh inv
NAME: "1751 chassis", DESCR: "1751 chassis, Hw Serial#: 2472228613, Hw Revision: 0x600"
PID: 1751 , VID: 0x600, SN: JAD064207GW (2472228613)
NAME: "Chassis Slot", DESCR: "1700 Chassis Slot"
PID: 1700 Chassis Slot , VID: , SN:
NAME: "C1751 Mainboard", DESCR: "C1751 Mainboard"
PID: C1751 Mainboard , VID: 0x600, SN: JAD064207GW (2472228613)
NAME: "Daughter card slot:0", DESCR: "1700 DaughterCard Slot"
PID: 1700 DaughterCard Slot, VID: , SN:
NAME: "WIC/VIC 0", DESCR: "One port E1 voice interface daughtercard"
PID: One port E1 voice interface daughtercard, VID: 1.0, SN: 33504710
NAME: "E1 0/0", DESCR: "E1 0/0"
PID: E1 0/0 , VID: , SN:
NAME: "FastEthernet0/0", DESCR: "PQUICC_FEC"
PID: PQUICC_FEC , VID: , SN:
NAME: "Daughter card slot:1", DESCR: "1700 DaughterCard Slot"
NAME: "Daughter card slot:2", DESCR: "1700 DaughterCard Slot"
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 0"
PID: Packet Voice DSP Module Slot 0, VID: , SN:
NAME: "DSP Module", DESCR: "Packet Voice DSP Module with 3 C549 DSPs"
PID: Packet Voice DSP Module with 3 C549 DSPs, VID: 2.2, SN: ICP044002W7
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 1"
PID: Packet Voice DSP Module Slot 1, VID: , SN:
Статус потока:
VoIP_cisco#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 33
Total Allocated ISDN CCBs = 0
Статус DSP:
VoIP_cisco#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
Active Voice Call details
Current total analog signalling channels: 0
Current max allowed digital timeslot for voice: 36
Current number of DSP group: 1
Group 0:
Current allocated analog signalling channels: 0
Current free analog signalling channels: 0
Current allocated digital signalling channels: 30
Current free digital signalling channels: 6
Port(s) served: 0/0
Current Available MIPS: 600
SPMM DSPRM State Image D-sig D-sig A-sig A-sig Mips Voice/Xcode
Dsp Dsp allocate free allocate free Free Chan
0/0 0 UP FLEX6 6 0 0 0 100 0
0/1 1 UP FLEX6 6 0 0 0 100 0
0/2 2 UP FLEX6 6 0 0 0 100 0
1/0 3 UP FLEX6 6 0 0 0 100 0
1/1 4 UP FLEX6 6 0 0 0 100 0
1/2 5 UP FLEX6 0 6 0 0 100 0
Включаем дебаг:
VoIP_cisco#debug isdn q931
debug isdn q931 is ON.
Смотрим:
VoIP_cisco#term mon
И видим при звонке:
"Интересное" выделено жирным. Судя по похожим проблемам трабла в битых модулях PVDM (их там два). Вопрос извечный - кто виноват и что делать? В присланном вместе с бандлом протоколе тестирования значится только инвентаризация (конечно же в ней все есть). Или все-таки у меня что-то напутано в конфиге (не похоже, но все-таки..)?
