Myp
Пользователи
  • Публикации
    5
  • Зарегистрирован
  • Посещение
1 подписчик
О Myp
  • Звание
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
  1. [root@rtr-test ~]# sc init [root@rtr-test ~]# sc list Option "-p" is unknown, try "tc -help". sc: unable to close pipe for /sbin/tc at /usr/local/sbin/sc line 768 main::log_carp('unable to close pipe for /sbin/tc') called at /usr/local/sbin/sc line 997 main::rul_load_u32() called at /usr/local/sbin/sc line 1498 main::cmd_list() called at /usr/local/sbin/sc line 414 main::main('list') called at /usr/local/sbin/sc line 349 Linux rtr-test 2.6.18-194.el5 #1 SMP Fri Apr 2 14:58:14 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux centos 5.5 iptables v1.4.9.1 ipset v4.3, protocol version 4. Kernel module protocol version 4. [root@rtr-test ~]# tc -p Option "-p" is unknown, try "tc -help". [root@rtr-test ~]# tc -V tc utility, iproute2-ss061002
  2. угу, уже пробовалиNeighbor sessions: 0 active, is not multisession capable (disabled)
  3. c7600s72033-adventerprisek9-mz.122-33.SRB2.bin пробовал. кстати, зебра заводится только с neighbor 1.1.1.1 passive
  4. UPD: изучив лог bgp сессии, стало ясно, что extreme ругается unsupported optional parameter. там их 5 судя по http://www.cisco.com/en/US/docs/ios/iprout....html#wp1014616 route-refresh можно отключить в версии 12.3(14)T но что-то я не вижу такого софта для 7606 :( ищу про остальные.
  5. extremeware: Summit1iTx# sh ver Image : Extremeware Version 7.8.1.1 patch1-r9 [ssh] [base] by Patch_Master on 01/25/09 23:28:53 BootROM : 8.2 Summit1iTx# sh bgp neighbor Peer AS Weight State InMsgs OutMsgs(InQ) Up/Down ------------------------------------------------------------------------------- Ee--- 3.3.3.3 65533 1 IDLE 6 12 (0 ) 0:0:26:52 Ee--- 4.4.4.4 65534 1 ESTABLISHED 72 2 (0 ) 0:0:26:52 Peer: (c) send communities, (d) disabled, (e) enabled, (E) external peer (I) internal peer, (m) EBGP multihop, (r) route reflector client # BGP Router Configuration configure bgp AS-number 65535 configure bgp routerid 1.1.1.1 configure bgp add network 2.2.2.0 255.255.252.0 # BGP Peer Group Configuration # BGP Neighbor Configuration create bgp neighbor 3.3.3.3 remote-AS-number 65533 enable bgp neighbor 3.3.3.3 soft-in-reset enable bgp neighbor 3.3.3.3 create bgp neighbor 4.4.4.4 remote-AS-number 65534 enable bgp neighbor 4.4.4.4 soft-in-reset enable bgp neighbor 4.4.4.4 enable bgp cisco 7606: router bgp 65533 neighbor 1.1.1.1 remote-as 65535 neighbor 1.1.1.1 soft-reconfiguration inbound в логах 7606: 001309: Jul 13 14:33:55.335 NSKS: BGP: ses global 1.1.1.1 (0) pas Setting open delay timer to 60 seconds. 001310: Jul 13 14:33:55.335 NSKS: BGP: ses global 1.1.1.1 (0) pas read request no-op 001311: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive rcv message type 1, length (excl. header) 10 001312: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive rcv OPEN, version 4, holdtime 180 seconds 001313: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive rcv OPEN w/ OPTION parameter len: 0 001314: Jul 13 14:33:55.811 NSKS: BGP: nbr global 1.1.1.1 neighbor does not have IPv4 MDT topology activated 001315: Jul 13 14:33:55.811 NSKS: BGP: nbr global 1.1.1.1 BGP nbr does not have BGP_AF_IPv4MDT topology activated 001316: Jul 13 14:33:55.811 NSKS: BGP: ses global 1.1.1.1 (0) pas mdt prepare old peer: BGP_MDT_STYLE_NONE or Internal Problem 001317: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive rcvd OPEN w/ remote AS 65535 001318: Jul 13 14:33:55.811 NSKS: BGP: ses global 1.1.1.1 (0) pas Adding topology IPv4 Unicast:base 001319: Jul 13 14:33:55.811 NSKS: BGP: ses global 1.1.1.1 (0) pas IPv4 Unicast:base NSF Building GR capability. 001320: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive went from Connect to OpenSent 001321: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive sending OPEN, version 4, my as: 65533, holdtime 180 ID 4D6A5FCDseconds 001322: Jul 13 14:33:55.811 NSKS: BGP: 1.1.1.1 passive went from OpenSent to OpenConfirm 001323: Jul 13 14:33:55.815 NSKS: BGP: 1.1.1.1 passive send message type 1, length (incl. header) 60 на 7606 пробовали (как прочитал в http://blog.maddog2k.net/tag/bgp/) router bgp 65533 neighbor 1.1.1.1 transport connection-mode passive neighbor 1.1.1.1 activate толку нет 7606# sh ip bgp neighbors 1.1.1.1 BGP neighbor is 1.1.1.1, remote AS 65535, external link Description: HOMENETWORK Member of peer-group CUSTOMERS-BGP for session parameters BGP version 4, remote router ID 1.1.1.1 BGP state = Idle Neighbor sessions: 0 active, is multisession capable Active open timer running 11264 remaining Default minimum time between advertisement runs is 30 seconds For address family: IPv4 Unicast BGP table version 6618, neighbor version 0/0 Output queue size : 0 Index 6, Offset 0, Mask 0x40 6 update-group member CUSTOMERS-BGP peer-group member Inbound soft reconfiguration allowed Community attribute sent to this neighbor Inbound path policy configured Outbound path policy configured Incoming update prefix filter list is BGP-FILTER Outgoing update prefix filter list is GARBAGE Route map for incoming advertisements is BGP-IN Route map for outgoing advertisements is CUSTOMERS Sent Rcvd Prefix activity: ---- ---- Prefixes Current: 209 0 Prefixes Total: 0 0 Implicit Withdraw: 0 0 Explicit Withdraw: 0 0 Used as bestpath: n/a 0 Used as multipath: n/a 0 Outbound Inbound Local Policy Denied Prefixes: -------- ------- Total: 0 0 Maximum prefixes allowed 500 Threshold for warning message 75% Number of NLRIs in the update sent: max 161, min 0 Address tracking is enabled, the RIB does have a route to 1.1.1.1 Connections established 10; dropped 10 Last reset 00:59:22, due to Active open failed Transport(tcp) path-mtu-discovery is enabled No active TCP connection access-list на summit 1i пока не создавал. ума не приложу, отчего сессия с 7206(Version 12.3(19)), quagga(Quagga 0.98.6) в подобном конфиге устанавливается, а с 7606 нет. у кого-нибудь есть мысли?
