limit
Пользователи
  • Публикации
    12
  • Зарегистрирован
  • Посещение
О limit
  • Звание
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
  1. 1. Мультикастом щас трабла, строию, если дадите рабочий конфиг буду признателен. 2. Какой лог нужен: --- cut --- Jul 11 18:10:31: [stream:Channel 1+1 International]ID:0x1C not supported descriptor in curr ent version Jul 11 18:10:31: [stream:Channel 1+1 International]ID:0x7C not supported descriptor in curr ent version Jul 11 18:10:31: [stream:Channel 2+2]Scan PMT table [pid:6120]: Jul 11 18:10:31: [stream:Channel 2+2] PCR: pid:6121 Jul 11 18:10:31: [stream:Channel 2+2] VIDEO: pid:6121 Jul 11 18:10:31: [stream:Channel 2+2] Scan PMT description for pid:6121 Jul 11 18:10:31: [stream:Channel 2+2]ID:0x11 not supported descriptor in current version Jul 11 18:10:31: [stream:Channel 2+2] AUDIO: pid:6122 Jul 11 18:10:31: [stream:Channel 2+2] Scan PMT description for pid:6122 Jul 11 18:10:31: [stream:Channel 2+2]language: ukr Jul 11 18:10:31: [stream:Channel 2+2] AUDIO: pid:6123 Jul 11 18:10:31: [stream:Channel KRT]Scan PMT table [pid:6150]: Jul 11 18:10:31: [stream:Channel KRT] PCR: pid:6151 Jul 11 18:10:31: [stream:Channel KRT] VIDEO: pid:6151 Jul 11 18:10:31: [stream:Channel KRT] AUDIO: pid:6152 Jul 11 18:10:31: [stream:Channel KRT] Scan PMT description for pid:6152 Jul 11 18:10:31: [stream:Channel KRT]language: ukr Jul 11 18:10:31: [stream:Channel Era FM]Scan PMT table [pid:6186]: Jul 11 18:10:31: [stream:Channel Era FM] PCR: pid:6187 Jul 11 18:10:31: [stream:Channel Era FM] AUDIO: pid:6187 Jul 11 18:10:31: [stream:Channel Era FM] Scan PMT description for pid:6187 Jul 11 18:10:31: [stream:Channel Era FM]language: ukr Jul 11 18:10:31: [stream:Channel L radio]Scan PMT table [pid:6196]: Jul 11 18:10:31: [stream:Channel L radio] PCR: pid:6197 Jul 11 18:10:31: [stream:Channel L radio] AUDIO: pid:6197 Jul 11 18:10:31: [stream:Channel L radio] Scan PMT description for pid:6197 Jul 11 18:10:31: [stream:Channel L radio]language: ukr Jul 11 18:10:31: [stream:Channel Radio Ukraine International]Scan PMT table [pid:6106]: Jul 11 18:10:31: [stream:Channel Radio Ukraine International] PCR: pid:6107 Jul 11 18:10:31: [stream:Channel Radio Ukraine International] AUDIO: pid:6107 2011-07-11 18:10:42.467 stream_http: connection from 195.110.57.78 for /tv/1_1_int 2011-07-11 18:10:57.048 stream_http: dropping connection to 195.110.57.78 for /tv/1_1_int 2011-07-11 18:10:57.065 stream_http: connection from 195.110.57.78 for /tv/tet 2011-07-11 18:12:30.700 dvr: inputstats: 49 pids 24942 pkt/s 4689133 byte/s 2011-07-11 18:13:22.179 stream_http: dropping connection to 195.110.57.78 for /tv/tet 2011-07-11 18:13:22.210 stream_http: connection from 195.110.57.78 for /tv/ru_music 2011-07-11 18:14:30.701 dvr: inputstats: 49 pids 24971 pkt/s 4694682 byte/s 2011-07-11 18:16:30.701 dvr: inputstats: 49 pids 24969 pkt/s 4694309 byte/s 2011-07-11 18:17:38.297 stream_http: dropping connection to 195.110.57.78 for /tv/ru_music 2011-07-11 18:18:30.701 dvr: inputstats: 49 pids 24969 pkt/s 4694195 byte/s 2011-07-11 18:19:05.855 stream_http: connection from 195.110.57.78 for /tv/news_one 2011-07-11 18:19:38.458 stream_http: dropping connection to 195.110.57.78 for /tv/news_one 2011-07-11 18:19:44.038 stream_http: connection from 195.110.57.78 for /tv/a_one 2011-07-11 18:20:30.702 dvr: inputstats: 49 pids 24967 pkt/s 4693904 byte/s 2011-07-11 18:22:30.703 dvr: inputstats: 49 pids 24969 pkt/s 4694253 byte/s 2011-07-11 18:24:30.703 dvr: inputstats: 49 pids 24966 pkt/s 4693717 byte/s 2011-07-11 18:26:30.704 dvr: inputstats: 49 pids 24972 pkt/s 4694775 byte/s 2011-07-11 18:28:30.705 dvr: inputstats: 49 pids 24968 pkt/s 4694118 byte/s 2011-07-11 18:30:30.705 dvr: inputstats: 49 pids 24968 pkt/s 4693993 byte/s -----------
  2. Шары нет. Просто беру с сириуса. Поставил новую версию гестрима 84.
  3. Доброго времени суток, Как проверить, почему у меня не декодирует канал, дело в ключе или нет? SIRIUS 4.8E - - cut - - - adapter 1 { dvb-s { lnb { lof1 9750000; lof2 10600000; slof 11700000; }; transponder { frequency 11766000; polarisation h; symbol-rate 27500000; }; }; stream { name "Channel TET"; input { pnr 6110; biss "19090628117660E7"; }; output-http { url /tv/tet; }; # output-udp { # remote-address 232.1.0.1; # remote-port 1234; # sap { # scope global; # ttl 4; # playgroup "Channel News One Channel"; # }; # }; };
  4. adapter3# ls -l итого 0 crwxrwxrwx 1 root video 212, 193 Июл 21 01:27 audio0 crwxrwxrwx 1 root video 212, 209 Июл 21 01:27 audio1 crwxrwxrwx 1 root video 212, 196 Июл 21 01:27 demux0 crwxrwxrwx 1 root video 212, 212 Июл 21 01:27 demux1 crwxrwxrwx 1 root video 212, 197 Июл 21 01:27 dvr0 crwxrwxrwx 1 root video 212, 213 Июл 21 01:27 dvr1 crwxrwxrwx 1 root video 212, 195 Июл 21 01:27 frontend0 crwxrwxrwx 1 root video 212, 211 Июл 21 01:27 frontend1 crwxrwxrwx 1 root video 212, 200 Июл 21 01:27 osd0 crwxrwxrwx 1 root video 212, 216 Июл 21 01:27 osd1 crwxrwxrwx 1 root video 212, 192 Июл 21 01:27 video0 crwxrwxrwx 1 root video 212, 208 Июл 21 01:27 video1
  5. Есть, я уже грузил по разному... у меня в реальности 2 аддаптера потому я указивал: modprobe dvbloopback num_adapters=2
  6. Да есть и модуль загружен. --- cut --- [ 3129.722035] /usr/local/src/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c: frontend loopback driver v0.0.1 [ 3129.722049] dvbloopback: registering 1 adapters [ 3129.722138] DVB: registering new adapter (DVB-LOOPBACK) -----------
  7. Добрый день уважвемый Алл, Так как не могу найти ответ на свою проблему, при этом перечитав кучу постов, прошу Вашей помощи: При запуске пограмы: ./sasc-ng -j 0:3 выдает следующую ошибку Jul 20 13:32:06.156 frontend: Could not open /dev/dvb/adapter3/frontend1. Error was: 14 Open failed : Bad address Как это можно побороть?
  8. Под впн сервера поставил debian testing. Шифрование ессно используется. впн - PPTP. Мммм... А что это за услуга такая? Это не услуга. Ладно спросим в дугом ракурсе. DHCP применяется у когото в сетке и насколько это оптимально?
  9. Не знаю, у меня стоить Core 2 DUO. Но меня щас интересует не это, а как реазиловать "Главная задача это простота администрирования и главное чтобы потом со временем можно било отдавать такую услугу как хождение между сетками." ???
  10. Ничего такого, но вот когда народу до 60 чел конектится вот тут уже проблемы, резко возрастает загрузка процессора.
  11. Доброго времени суток уважаемый Алл, Подскажите, как лучше организовать доступ к сети Интернет, если (щас народ подключается к Интернету через ВПН туннели – система утопия, жрет много ресурсов): 1. Была и есть сеть раньше человек так 30, щас уже перевалило за 100. 2. Есть также удаление мелкие сети чел так 20, и соедини не скоростными каналами связи до 2 М. Главная задача это простота администрирования и главное чтобы потом со временем можно было отдавать такую услугу как хождение между сетками. Принимаются любые дельные советы вплоть к выбору оборудования. ЗЫ: Сори за такой тупой вопрос. Заранее благодарю, за ответ.
